Question about Honda Electrical Supplies
Hi, i have two honda 5.5 gx 160 generators that run fine but don't give out any power?
    Scholar:
  • 142 Answers
  1. If you check on generators output and you have voltage there, your circuit breakers may have dropped.
  2. If there is no voltage there, you may have:
  • Bad slip rings, brushes, wires to field winding;
  • Bad field supply rectifier;
  • If the field circuit is OK, the magnetic field may need to be recharged
In order to build the magnetic field up again you can connect for a short time (1 - 3 seconds) by a working motor, a 12 V battery to the field terminals, + and - respected. A series diode 10 - 25A to battery can stop the built up field voltage to overcharge the battery.
Posted on Aug 03, 2010
Hi I have a Dunlite UH5 generator coupled to a Honda GX 340 Generator is noisy. Is there a parts list or workshop manual I can get to explain how to identify and repair the generator ?
Hi, You can get parts from "Generator Guru" for your Dunlite generator and your Honda, as it sounds like the anti vibration engine mounts are shot.
Sorry, but I can't help you with the manuals.
Kind regards
David
Jan 16, 2018 | Honda Electrical Supplies
Ihave a honda generator with a gx 390 motor volt drops when i put a load on it what could it be
Voltage regulator, carbon buildup in the cylinders, the carburetor may need overhauling, engine governor may have a stretched spring, Spark plug may need replacing, Timing may be off, air filter may need changing, and lastly, your load may exceed the ability of the generator.Checking this list will uncover the loss of power
Oct 20, 2016 | Honda Electrical Supplies
Gx
carburetor float is either bad or sticking.shut fuel off remove fuel bowl 10 mm bolt once removed pull pin out of float and inspect it at the same time re open fuel valve to allow fuel to push any debris the might be still in the port.re install float and test by slightly pushing the float upward and turn fuel on no fuel should drain unless you release the float if float has any fuel inside replace it if not finish putting it together and problem solved:)
Aug 22, 2014 | Honda 11 HP Engine w/electric start - GX...
Honda eu 3000 won't run, cleane bowl,cleaned filter. fresh oil new plug got spark, will run for 10 seconds, the will not crank again. wait 20 min. it like crank an run 10 seconds?
i usually do a quick test of a small few onzes of fuel down the plug hole and reinstal plag and see if i9 fire up and run for a lil bit. maybe 5 -10 seconds. now i know i have spark . most usually our wonderful fuel is the problem. its just nasty now. it can stick a needle to the seat. it can hold her open . one way ya flood out. the other ya starv out. give it a try.
Oct 15, 2012 | Honda 3000 Watt Portable Generator
Ex 5000 sx generator, no power
Hello dear, would you consider buying a new generator? Generator Diesel Generator Cummins Generator Volvo Generator Perkins...
If you can start your generator normally, you can analyze the reasons through the following article:
Why Diesel Generator Fail to Start
Simple Ways to Deal with Diesel Generator Failure
Hope it works for you.
Sep 21, 2017 | Honda Electrical Supplies
My generator runs fine but quit producing pwer. all cords are fine and tight, breakers are not fliped.
Hi Kenneth,You might need to flash your generator, I recommend the drill method. Here is the link to an article on how to do it. This is a very educational read and the process shouldn't take you longer than 5 minutes, I hope it works for you. Here is the link http://www.endtimesreport.com/dead_gen.html Good luck, Michael Burke
Oct 19, 2011 | Coleman Powermate Subaru 5000W Portable...
Honda GX 160 under 30 hrs from new, is running poorly
try removing the float bowl on the carburator and cleaning, sounds like needle valve is partially stopped up
Aug 02, 2010 | Honda Horizontal OHV Engine for Non Pumps ...
Honda E-1500 Generator misfiring after less than 10 minutes.
hi, i have a portable generator that has Nissan GX 1600 on it,who makes it? and do they have a web site?
Mar 22, 2009 | Electrical Supplies
Electrical Supplies Logo
232 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
