Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
My Whirlpool Refrigetor's copmressor is continuesly on , what is solution , is there is problem with thermostat
  • Whirlpool Master
  • 17,130 Answers
Yes since your compressor is running continuosly the first case of the fault could be the thermostat. So you might have to trace the wires to the thermostat including the bimetal / sensor. Check for breaks in the wires as due to frost build up the wires may disintegrate in due time. If not you will have to go with confirming the thermostat. Hope your fridge is working fine otherwise and you have not noticed any other anomalies because if the compressor runs continuosly the cooling can also drop which will therby make a chain reaction for not lettting the thermostat reach the temperature. So inthis case the timer could also be a suspect. So please check all these factors. Good day
Posted on Aug 03, 2010
Testimonial: "Thank you very much"
Hi,my GE refrigerator have alot of ice in the frezer comparment hoy can i fix? Refrigetor side not cold. Thanks
First off,
Ice build-up in the freezer compartment is an indicator that the defrost system is not working properly.
The defrost system is composed of the defrost heater and the defrost thermostat. If one of them is not working, ice will build up in the freezer compartment.
You need to do a continuity test on the defrost heater and if it is good, very likely the culprit is the defrost thermostat. Just replace the thermostat
Aug 02, 2017 | GE Refrigerators
Hi, I have subzero side by side refrigetor. Building up on back panel on refrigetor side . I defrost it clean and in week again ice building up ? Ho to resolve ? Thanks
check aall your seals on your doors and make sure they are sealing tight. Your compressor is working extra hard and freezing up. Also check the thermostat and make sure its not turned down to low, that will also cause compressor to run hard
Oct 09, 2015 | Refrigerators
Dometic refrigetor won,t cool
Have you adjusted the temperature setting? Try adjusting it to a cooler setting and wait about 24 hours to see if it is getting cool. If not, it may need a new thermostat.
Aug 22, 2013 | Refrigerators
My fridge is freezing food
HI,IF YOU REFRIGETOR IS FREEZING FOOD CHECK YOUR TEMP CONTROL OR THERMOSTAT AND THE AUTODAMPER (airflow control) PROPERLY CONDITION,,IF THE TEMP CONTROL IS BAD THE COMPRESSOR WILL BE WORKING ALL THE TIME,IF THE AUTODAMPER IS BAD WILL BE COOLING TOO MUCH..
Feb 21, 2011 | Refrigerators
Refrigetor not cooling and not diposing water or ice
check your compressor overload meybe your compressor is not running thats why it wont withdraw ice... or meybe check you thermostat settings meybe the thermostat is busted
Aug 09, 2010 | Samsung RS2630ASH
Whirlpool Refrigetor service centre in kolkata
Please check on the website of Whirlpool for all service centres located in your region.there is a toll free number where you can register your complaint and get follow up. Chek this out. Helpful ? Have a nice day.
Jul 02, 2010 | Whirlpool ED2FHEXN Side by Side...
The deforst timer didn't work and got ice
Does the timer move? If you can, try rotating the timer to the defrost postion when the frigorator turns off and see if the defrost emement starts to heat up. If it doesn't then you could have a bad thermostate. easy to replace.
Jul 15, 2009 | Whirlpool ED5FTGX Side by Side...
Wirlpool refrigetor model ed2chqxkl05
try these tips. http://www.hometips.com/home_probsolver/hps03/09_refrig/hps_refrig09.html
Aug 23, 2008 | Whirlpool GD2SHGX Refrigerator
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
297 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
