Question about Dualit 20247 2-Slice Toaster
TImer stuck burning toast - Dualit 20247 2-Slice Toaster
  • 1,711 Answers
Unfortunatly this a very popular problem with the timers and the only solution is to replace the timer knob complete.
Their are in ebay, very good price and they wll arive to you in a couple of days.
Posted on Sep 01, 2010
The timer has started to stick...causing toast to burn if you leave it. It could easily start a fire. is this common.
This one of the most frequent problem of dualit toaster. Timer is also power electric switch whith contacts which from long time use they stuck due to sparking during contact. You need to replace the timer switch . you can find one at ebay is the same for all models. just take care the voltage 120v or 240 v. Als take a picture before remove the wires on the timer since you might forget how to put them back on the new switch.
Jul 17, 2011 | Dualit 40352 4Slice Toaster
The timer keeps stopping when toasting so have to stand over the toaster or else it burns the toast Can this be repaired?
Yes the part is availible on ebay you need a new timer. Just be sure to get the right one there are 2 types available. The timer is not cheap and it will have to come from England. But it is an easy fix and the new timer seem to be better made then OEM
Jan 08, 2011 | Dualit Kitchen Appliances - Others
My Dualit Toaster is 2 yrsold this Christmas (I have the receipt) the timer dial sticks and won't move on and the toast the toast burns.
You need a new timer should be free from dualit but is not. Its a common problem . I would consider it a design flaw. They at the very least should make it available in the states at a resonable price. You can get a new one on ebay pricey
Dec 28, 2010 | Dualit 20084 2Slice Toaster
Dualit 20237 toaster timer gets stuck and toast is burnt. Can this be solved easily?
Aug 28, 2010 | Dualit 20237 2Slice Toaster
Their are in ebay amazon com, very good price and they wll arive to you in a couple of days.
The time clock does not always turn off resulting in the toast be
Probably needs a New timer best price I have found, with instructions http://www.mcssl.com/store/electra-craft/catalog/product/522920765afa4d168f30d465bed95c1a
Jul 12, 2010 | Dualit CTS4E 4-Slice Toaster
Intermatic t101p201 gets stuck when timer should
Interesting why the timer motor blew the breaker. with this size, less than 1/20 hp, the winding would have easily burnt out. You must have this circuit already load to the max. At this point, I would say that the motor is toast. you can get the guts (motor and switches combined) online from intermatic or order it from your local electrical supply distributor.
Jun 05, 2010 | RTO Intermatic T101P201 Timer Switch Two...
The timer stops, the toaster keeps toasting, burning the toast.
The timer is also a electrical contact switch. When the timer goes to zero an internal spring force the electrical contact to open so the heating elements to stop heating.
So either the spring stuck so it can not open the contacts anymore or the electrical contacts have been stuck together by elctrical sparking during the on and off.
In any case you must replace the timer switch with a new one since they does not worth to anything else with it.
The operation does not need any profetional skills since it can be remove easyly by removing the bottom panel and be carefull to remove the wires conected to it with clips make some notes so you will put the wires in the same position of the new timer switch.
If you don't fill comfortable with above then let an electrician do it for you.
Good Luck
Apr 01, 2010 | Dualit Vario 20293 2-Slice Toaster
The toaster oven does not toast. the oven and timer work, though
Your selector switch may be broken if the oven works on selections other than toast.
Jan 05, 2010 | Black & Decker TRO390 1200 Watts Toaster...
Dualit 20247 2-Slice Toaster Logo
245 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Herve Boissonnault
Herve Boissonnault
Angel Joseph Jr.
Angel Joseph Jr.
Ross Keen
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
