Question about IBM eServer xSeries 235 (867131xj)
Tring to find out if my ibm xseries 235 can have processor upgrade to dual core. Currently has two xeon 604 mpga processors. Hoping to go to dual core to get em64 support. I have had a look and there is a 604 mpga processor that is dual core but will adding this to the system give the em64 support I was hoping for? I have searced high and low and have not found anything..
  • 188 Answers
SOURCE: cpu upgrade for zv6000
Most of the newer processors use a different socket.
The Socket 939 chips go up to an Athlon 64 X2 4400+.
However: keep in mind that your computer's bios may not be setup to use newer CPU's. The only way to tell is to check compaq's web site for updates or just to buy a CPU and try it.
Posted on Dec 24, 2007
McIndia
  • 131 Answers
SOURCE: ibm x346 single 2.4 intel xean processor
Hold down F & J keys when booting your server.
Posted on Feb 23, 2008
  • 12 Answers
SOURCE: While installing debian on IBM Xseries 306m it can't detect HDD
Have you initialized the disk from within the BIOS ? if not when you boot the server it says there are no hard disks.
Posted on May 07, 2008
SOURCE: IBM ThinkPad T41, Upgrade my Intel Centrino Processor
make sure that the socket supports your new max Intel.
Posted on Feb 05, 2009
luis356
  • 53 Answers
SOURCE: Ibm server xseries 326
It is not detecting the HDD because the windows install does not have the necessary drivers. On the windwos install you must press F6 or F2 I don't remember which one but it prompts you for them to load external drivers fro SCSI or other type of drives, you must download the right drivers for the type of HDD the server has probably fromt eh IBM support website, put them in a floppy and load them from the floppy into the windows install so it recognizes the drives..
Posted on Jun 02, 2009
Can run windows 8 on IBM intellistation z pro ?
IBM IntelliStation zPro came with different CPU chips through 1997 to 2006. Depending on which year or type your machine is will determine if you can upgrade to Windows8.
The chips used were
IntelliStation Z Pro
Type 6899 (March 1997 to ??)
Type 6865 (October 1998 to April 2000)
Type 6866 (January 2000 to March 2002)
Type 6894 (May 2001 to June 2002)
Type 6221 (November 2002 to February 2005)
  • Dual Intel Xeon at 2.4, 2.67, 2.8 or 3.2 GHz
Type 6223 (August 2004 to March 2007)
  • Dual Intel Xeon with Intel 64 (formerly EM64T) at 3.0, 3.2, 3.4, 3.6 or 3.8 GHz
Type 9228 (June 2006)
  • Dual Intel Xeon Model 5130, 5140, 5150 or 5160
Windows 8 If you want to run Windows 8 on your PC, here's what it takes:
  • Processor: 1 gigahertz (GHz) or faster with support for PAE, NX, and SSE2 (more info)
  • RAM: 1 gigabyte (GB) (32-bit) or 2 GB (64-bit)
  • Hard disk space: 16 GB (32-bit) or 20 GB (64-bit)
  • Graphics card: Microsoft DirectX 9 graphics device with WDDM driver
As you have Type 6223 which a Xeon faster than 1GHz it should work with Windows 8 but not all Xeon processors are compatible depending on which one you have. See this Microsoft site after you check your Xeon chip family on the motherboard or through the Windows system command. Search for xeon.
Processors What processors support Windows 8
Aug 15, 2014 | IBM IntelliStation Z Pro 6223-42U PC...
CAN I INSTALL XEON 5540 WITH LGA1366 MOTHERBOAR
NOT ON JUST ANY MOTHERBOARD, that's a quad core, the mother board has to have quad core clocking. You need a server board. All the desktop boards are only dual core clocking.
Feb 20, 2014 | IBM Xeon E5540 FCLGA1366 2.53G 8MB 45NM...
Single core 2.8ghz xeon to quad core cpu
http://en.wikipedia.org/wiki/Xeon#Prestonia
"In 2002 Intel released a 130nm version of Xeon branded CPU, codenamed "Prestonia". It supported Intel's new Hyper-Threading technology, and had 512KB L2 cache. This was based on the "Northwood" Pentium 4 core."
Meaning it is a Single-Core processor.
http://en.wikipedia.org/wiki/List_of_Intel_Xeon_microprocessors#.22Prestonia.22_.28130_nm.29
Scroll down.
400MegaHertz Front Side Bus. (400MHz FSB)
http://en.wikipedia.org/wiki/Xeon#7300-series_.22Tigerton.22
"The 7300 series, codenamed Tigerton (product code 80565) is a four socket (packaged on Socket 604) and more capable ->
QUAD-CORE processor.................."
http://en.wikipedia.org/wiki/List_of_Intel_Xeon_microprocessors#.22Tigerton.22_.2865_nm.29
1066MegaHertz Front Side Bus. (1066MHz FSB)
The motherboard uses the Intel E7505 motherboard chipset,
http://en.wikipedia.org/wiki/Intel_Xeon_chipsets#NetBurst-based_Xeon_chipsets
Note the - Processor FSB supported -
533MegaHertz
ONLY supports Single-Core processors, too.
The answer is No
Regards,
joecoolvette
Dec 17, 2012 | Computers & Internet
Can i put dual core processors in my intel se7505vb2 motherboard?
http://www.intel.com/support/motherboards/server/se7505vb2/sb/cs-007399.htm
Page 16 of the Technical Product Specification guide;
3.1.1 Processor Support
"The Intel Server Board SE7505VB2 supports one or two processors in the 604-pin FCPGA package."
-> Socket 604,
http://en.wikipedia.org/wiki/Socket_604
-> Intel XEON processors ONLY
"When two processors are installed, all Processors MUST be of identical revision, core voltage, and bus/core speed."
-> Means you really should use two IDENTICAL processors.
"When only one Processor is installed, it should be in the socket labeled CPU1, and the other socket must be empty."
-> Self-explanatory.
That's the processor socket furthest away from the black AGP graphics expansion slot, and closest to the outside edge of the motherboard.
(Page 104, and 105)
ONLY supports Intel Xeon processors with a 400MHz, or 533MHz FSB.
Dual-Core Xeon's start at 667MHz, and wouldn't work anyway; due to different Core architecture, and Instruction Sets.
667MHz, 800MHz, 1066MHz, and 1333MHz, for dual core Xeon's,
http://en.wikipedia.org/wiki/List_of_Intel_Xeon_microprocessors#Xeon_.28UP.2FDP.29.2C_Dual_Core_2
(Scroll down just a touch, to get the Wikipedia 'banner' out of the way, or click on it's X)
Scroll down the page, look at the charts. Starts with 800MHz FSB for Dual Core, then goes 667MHz, 800MHz, 1066MHz, and 1333MHz, Front Side Bus.
Use Dual Core processors?
No.
Two Single-Core processors.
Product Guide for the Intel Server Board SE7505VB2,
(Motherboard manual),
http://download.intel.com/support/motherboards/server/se7505vb2/prod_guide.pdf
The above is a direct link to the PDF file, motherboard manual.
If it doesn't work just by clicking on it, then copy it; and paste it in your browser address bar. Press the Enter key.
(This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above link, or press the Enter key; it may take up to 30 seconds before the first page comes up.
Didn't want you to wait a few seconds, and think nothing is happening)
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 29, 2012 | Computers & Internet
Can i up grade my single core cpu pen4 550 3,4GHz to a Quad core or dual core either one would help
Depends on the socket type.. Socket 423 and 478 do not support core duo or quad core processor types. However, if you have LGA 775 (aka socket T) your motherboard will support the following:
Intel Pentium 4 (2.60 - 3.80 GHz)
Intel Celeron D (2.53 - 3.60 GHz )
Intel Pentium 4 Extreme Edition (3.20 - 3.73 GHz)
Intel Pentium D (2.66 - 3.60 GHz)
Pentium Extreme Edition (3.20 - 3.73 GHz)
Pentium Dual-Core (1.40 - 3.33 GHz)
Intel Core 2 Duo (1.60 - 3.33 GHz)
Intel Core 2 Extreme (2.66 - 3.20 GHz)
Intel Core 2 Quad (2.33 - 3.00 GHz)
Intel Xeon (1.86-3.40 GHz)
Intel Celeron (1.60 - 2.40 GHz)
Mar 22, 2011 | HP Pavilion a775c (A775CB) PC Desktop
I have an IBM thinkcentre m51 that I am trying to upgrade to a dual core processor. It seems that it won't take it. Is there a setting on the bios that will allow the motherboard to support a dual core...
Most major manufactures use motherboard designed to their specs and upgrades to the processor are limited. You can use software such as Belarc Advisor, to determine what motherboard you have and then you can search the net to determine what processors are compatible with it.
Nov 08, 2009 | IBM ThinkCentre M51 PC Desktop
I have a Question for upgrading my machine. I havent had the chance to dabble with Dual-Processors.... This will be my first time. Q: Is it possible to utilize a Xeon 2.66GHz x3330 Processor and a Pentium...
You can only mix the same family processors with different stepping and speed. Pentium D is not in the same family as a Xeon. So no, you can not. For as long as the processors are in the same family, you can mix dual core with quad core and even different speed.
Sep 02, 2009 | Intel Quad Core Xeon X3330, 2.66 GHz
Upgrade Intellistation Z Pro 6121 w11 to 64bit Xeon Processors
It helps if you give the right specification - the W11 is the 6221, not the non-existent 6121.
You have 2 x 2.4 Xeon in a Socket 604 package. The only CPUs these could be are the Tigerton - it certainly does support 64-bit operation, as well as VT.
You have little choice in processors - Tulsa, Tigerton and Dunnington.
The Tigerton is a little ripper! 2 x 4MB on-die cache, 1066 internal FSB, wide voltage range and low power consumption (80W).
http://ark.intel.com/Product.aspx?id=30779
You have a 4 processor 64-bit box - if it isn't poweful enough for you (and I can't see why - I run 50 concurrent VM users on less), you can only go to the 2.93 Tigerton as an upgrade. The other CPUs have more horsepower, less torque!
Don't get hung up on processor speed - for 64-bit big cache rules.
Aug 05, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
Dual E5345 Xeon -Upgrade?
Hi there.
If you note down the make and model of the motherboard you will be able to check to see if you can upgrade to better processors and which type of processors the motherboard supports.
If you want me to source the info please post the make and model of the board.
Thanks for using FixYa!!
May 22, 2009 | HP Hewlett-Packard Intel Xeon Quad-Core...
Cpu upgrade for zv6000
Dec 03, 2007 | IBM ThinkPad T22 2647 Notebook
IBM eServer xSeries 235 (867131xj) Logo
116 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
