Question about Westinghouse Refrigerators
LCD display is not working on the side by side fridge
  • Mike Smith
    Mike Smith Aug 04, 2010
    Before any correct solution can be given , your brand and complete model number is needed .
  • Westinghouse Master
  • 17,130 Answers
Two faults can be thought of in such a case. First of all the LCD display itself could have failed and in this case all your functions will be working fine except the display. So if this is the case you will have to order for the display unit. Secondly if there is no power coming at all to the unit then you will have to check for failure of the power section from the base unit. You will need to open and ttrace the lines and if so replacement of the power/control unit is required, However a voltage test can only prove this correct. Hope you try this out Good day
Posted on Aug 03, 2010
Lcd display numbers incomplete on side by side freezer. Can't tell temp of fridge or freezer . Tried reset and unplug .
Sounds like the LCD is on its way out and the display may need replacing, but it could be a bad connection to the panel although that is less likely. Put a thermometer in the fridge or freezer so you can check all is ok with the settings. If acceptable it might be worth just putting up with it as it is.
Sep 28, 2015 | Refrigerators
Whirlpool fridge/freezer LCD replacement
What is the model number listed inside the refrigerator section?
Nov 17, 2012 | Refrigerators
Samsung fridge freezer SR2028CVW not cooling or freezing
If you have used it since 2004, it probably is worn out.
May 02, 2017 | Samsung Refrigerators
GE profile fridge : cannot reset non-LCD display
Did you ever figure out a fix for this? Mine is now doing the same thing.
May 11, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My westinghouse sid-by-side fridge is freezing
the mother board located inside the lower rear portion of the unit is bad,if you have recently had lights blow out this can cause a surge and ruin the mother board,also if there are relays clicking and lights are blinking dimly this is a good sign the board is bad
Jan 16, 2010 | Refrigerators
My NEW GE side by side fridge died today!
The display off because your power board is faulty. (Under gaurentee i hope. Need to call the warrenty repair guy out.
Sep 21, 2009 | GE Energy Star PDS22SIS Stainless Steel...
Filter changed but still 1% on display panel
Is this a side by side fridge freezer? Most Whirlpool models with LCD display on front- reset filter indicator to display 99% by pressing and holding 'OK' button until filter resets to 99%. If you have a different model, or of this doesn't work, advise on model number and I can instruct further
Aug 10, 2009 | Whirlpool Freezers
DISPLAY LIGHTS NOT WORKING
If the display is burnt out then the low voltage board will have to be replaced.
Feb 02, 2009 | Viking 48 in Built In Professional...
Side by side fridge freezer
Based on your weird display issues I'd lean toward the control board problem. At least that can be "one" of a couple problems...
Feb 01, 2007 | Samsung RS2578BB Side by Side Refrigerator
Refrigerators Logo
216 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
