Question about KitchenAid KSCS23INSS Stainless Steel Side by Side Refrigerator
What tool do I need (Allen or Star wrench) to remove the door handles on KitchenAid Stainless refrigerator KSRK25FVMS01
    Problem Solver:
  • 12 Answers
This is a #10 torx
Posted on Aug 03, 2010
LFX25975sw
There are Allen set screws on each end of the handles (Top/bottom for the refrigerator doors, left/right for the freezer compartment.) These screws are accessed through small holes in the side of the handle with a 2.5 mm (3/32") Allen wrench. There are on the bottom side of the freezer handle as it's installed. There are also mounting brackets under the handle that can be tightened with a 1/4" Allen wrench with the handle completely removed.
For pictures of the handle hardware, see page 9 of the manual for the LFX25975SW. This is page 10 of the pdf here: http://www.managemylife.com/mmh/owner_manuals/2228/LG-Bottom-Mount-Refrigerator-L0906255 . This link should display in your browser.
I hope this helps.
(Allen wrenches (Hex keys) are L-shaped tools with a hexagonal design where it contacts the screw head. You'll need the long side to get into the holes. Do not overtighten the screws - this can strip the threads. Then you'd need to replace the entire handle unless you can work a new screw into the spot.)
Apr 26, 2012 | LG LFX25975SW (247 cu ft) Bottom Freezer...
The handle of my side by side Kitchen Aid refrigerator is loose. The model number is KSCS25INSS00. It has circular open holes on the handle, no screws? How do I tighten it?
Use an allen wrench (hex) to remove loosen the set screws in the two handle holes. Once removed, tighten the mounting lug. Replace the handle and tighten the hex set screws.
May 21, 2010 | KitchenAid KSCS23INSS Stainless Steel Side...
How do i remove exterior handel from door?
put ur head inbetween handles really close and open door fast , lol just playin no but look on inside upper and lower of handles might be easier if open door and u will notice an upper and lower allen wrench set screw inside just have to find the right allen wrench that fits that and just loosen each one enough until handl comes off... hope this helps let me know
Apr 08, 2010 | GE Profile PSW26P Stainless Steel Side by...
I have a ksbp25fkss side by side fridge and the door handle on the freezer is loose, but the handle is not the one depicted in the manuel. the handle must be tightened from the back or inside of the door....
you should have trim below and above the handle if not then and its a stainless steel door then there is small round opening on the side of the handle you'll need allen wrenches once you loosen the allen the handle slides up or down then you will be able to tighten the stud post screw then reverse the mounting -----------------be cautious of scratching the stainless steel door when removing the handles
Sep 01, 2009 | KitchenAid KSCS25FKSS Side by Side...
The door handle on the freezer of my GE Profile Bottom Freezer Refrigerator came off.
Hi, Please get me the model # from the label inside the refrigerator and I will look this up for you. Most handles have a set screw that tightens down.
Vic
Jul 11, 2009 | General Electric Profile PFSS2MIXSS...
Door Handle Loose and tightening with allen wrench does NOT work ...
Just did this on mine today. Use an allen wrench to back off both the upper and lower set screws (Note: you do not need to back them all the way out). The handle will then easily pull away from the door. With a 1/4" socket, tighten the screws holding the upper and lower lugs on the door. Place the handle back on and tighten the upper and lower set screws.
Jul 25, 2008 | KitchenAid Superba Architect KSCS25INSS...
Freezer door handle loose
Use a 3/32 Allen wrench to tighten the screw on the side of the door handle
Jul 16, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Handle loose on Refrigerator
To fix this you will need an Allen wrench small one there are 2 set screws on the inside part of the handle (on side toward the center) you wil need to tighten these to fix your problem
Feb 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
How do I fix loose handle?
havnt worked on that but... most times theres a cap or piece that will come off hiding the screw not sure what yours is cant find anything on it .. hope that may help some
Sep 02, 2007 | GE Monogram ZDWC240NBS Stainless Steel...
KitchenAid KSCS23INSS Stainless Steel Side by Side Refrigerator Logo
59 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
