Question about Sony Ericsson M600i Cellular Phone
I tried to calibrate the toych screen, but it always say you are far away from point 2. touch screen is not working.its very serious.please advice me......
2 Suggested Answers
  • 34 Answers
SOURCE: sony ericsson M600i touch screen not working,not calibrating
it can be touch pad problem.
Posted on Jun 21, 2009
How to reset SC544 for Ricoh MPC 3000 when the keyboard is faulty
Maybe TOUCH panel doesn't work.
Try to calibrate it:
Yellow -->1-->9-->9-->3--> Press Stop(red one) 5 times.
1 - Touch screen adjustment!!! Follow instructions on the screen.
After calibrating exit and try again to enter service mode.
Good luck
Prepare to by new TOUCH Panel
Pifonski
Sep 30, 2015 | Ricoh Aficio Office Equipment & Supplies
Radio stations
There is a radio option to recalibrate your touch screen. Please press the following three hard keys simultaneously RADIO/MEDIA, SEEK UP, NAV (AUDIO on REN). Once you begin to recalibrate the touch screen you must finish. Audio confirmation prompts are provided for each of the three points of calibration, one beep for the first, two for the second and three for the third. The calibration needs to be precise as possible and a PDA stylus would be recommended. The MyGIG radio requires the user to repress each calibration point to confirm the calibration process. A green crosshair indicates proper calibration.You must not start with the "+" but with the "+1", then goto "+2" and last to "+". Repeat this until all crosses are green and exit with pushing the menue or any other key. Done
Jul 20, 2012 | 2008 Dodge Grand Caravan
My nokia touch screen is not working. Everything else on the phone seems to be fine, just that when I touch the screen there is no response. Please can you help?
Hello there,
There are two major reasons that could be causing the touch screen not to be responding. The first is if the phone fell and the sensor board got bad, and the best solution is to replace the sensor board. To replace the sensor board is quite sensitive so i will strongly advice you seek advice from a specialist that can assist you with that. But if you intend to fix it DIY way, then you can ask and i will direct you through the steps.
On the other, it might be the screen is weak and needs calibration. To calibrate the screen. I will advice you go through the user manual for the steps to calibrate the screen of your phone. If you cannot get any response from the screen, i will advice you replace the sensor board. Because calibration requires you to touch the screen and since it is not responding to touch, it will be pointless trying to calibrate.
Thank you for using fixya.
Caseytech
Sep 21, 2011 | Cell Phones
How to fix screen calibration on the phone?
Go to Menu>Settings>Phone>Calibration
Note: it doesn't always calibrate on the first touch on each point. It might take you many tries to get it to move to the next point.
It is best to do this operation with a Q-tip, which resembles a finger to the Eternity's software more than a sharp point, but is also more accurate than a finger.
To test the calibration, dial *#0*# and press "9"
If this did not fix your problem, or you think you have a hardware issue
Feb 28, 2011 | Samsung Eternity Cell Phone
Hp pavillon tx1000 12.1 inch touch screen cursor stays at bottom left hand conrner
Clean the screen with a clean soft cotton cloth is the step #1
Step 2:
SEE FULL instruction HERE
Calibrate the touch screen
The command buttons and fields are displayed on the screen image at specific pixel points. To initiate a response, the touch screen interface needs to recognize exactly where a fingertip or pen touches the screen relative to the pixel position of the display. Each user has a slightly different hand-eye coordination response. Calibrating the touch screen allows the interface to compensate between where the program is expecting a touch and where the touch actually occurs. To calibrate the touch screen, place the tablet notebook in the desired orientation and do the following actions.
  1. Click or tap Start > Control Panel > Tablet PC Settings to open the Table PC Settings window.
  2. On the General tab, select the option to display the menus in either the Right-handed or Left-handed position.
  3. On the General tab, select the desired screen orientation from the drop-down menu, and click or tap Calibrate . Follow the instruction to touch the screen at the specified points. Repeat this calibration action for all four of the screen orientations, then click or tap Apply .
  4. On the Handwriting Recognition tab, select the Use the handwriting personalization option.
  5. At a later time, you can return to review the Go to Pen and Input Devices and Go to Input Panel Settings options to make using the touch screen to control programs and input text easier and more accurate.
Compare your version of the firmware to the latest one at HP offical site HERE
Always get the latest firmware to avoid problem.
Always keep the screen clean!
Jul 11, 2010 | HP Pavilion TX1000Z 12.1" Touch Screen...
Calibrating touch screen
calibrating touch screenProblem with Pioneer AVH-P5750DVD Car DVD Player
May 20, 2010 | Pioneer AVH-P5700DVD Car DVD Player
Nintendo ds calibrating
I`ne been working on my dauthers now for a few days.
I have found that in the calibrate screen, if i click the first point (top left), then click the second (bottom right), but instead if clicking the third (middle), i click 4 squares to the right. It puts me in to the test screen....... Now if i play around in the calibration screen, i can ajust where the points of contact happen. I have a feeling that its like a mirror, each one can be turned in different directions, reflecting where to pick up the stylist. If any one finds this help to them, and finds out what excatly what to do...... please, please can you leave a post, expaining what to do
Nov 27, 2007 | Nintendo DS Console
Sony Ericsson P900 touch screen Not working
You Might want to calibrate the screen.
just go to control panel -> display
Sep 06, 2007 | Sony Ericsson P900
P990i touch screen problem
I encountered the same problem but was able to fix it. Just don't know if it's just temporary. Go to tools, control panel, other, set up wizard, tap yes, tap the second button before cancel, keep on clicking to the right direction until the numbers 1, 2, 3 and 4 appears. Tap the center of each number until blinking stops, save settings. For the first few steps you may use the jog dial found on the left side of the phone if the touch screen does not follow your tappings.
Aug 24, 2007 | Sony Ericsson P990i Cellular Phone
Sony Ericsson M600i Cellular Phone Logo
13 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
