Question about Music
Hello good day sir please help me what to do with my DigiTech GNX3 my brother use a 9vdc to my gear instead of 9vac,my GNX3 is dead nothing lights on the display. pls help
  • Music Master
  • 5,603 Answers
The 9VDC adapter should NOT have done ANY harm to your equipment if it was supposed to be 9VAC.
If it was the other way around damage could be done to the stuff.
Posted on Aug 03, 2010
Digitech gnx3 makes cracking noise and the clip indicator comes on when it does
Hi Chris,
This is a discontinued product for the work station. Digitech does have a firmware update on their website. Have you tried that? Other then that, usually a bad guitar cord, dirty input jack or faulty input jack caused the cracking sound. These units sit on the floor where dirt and dust collect. Try spraying the input jack with a good quality conduct cleaner. (Radio Shack?) Make sure your guitar jack is also clean and then "exercise" the input by plugging the cord in and out several times. I am assuming this may help since it is the most simple approach. Otherwise, it may be a component issue and that cannot be addressed via email.
Mar 02, 2017 | The Music
My digitech looper phrase sampler will not turn on
A common problem is that somebody has paired the WRONG power adapter to this unit.
The REQUIRED adapter should be 9VAC (not DC) at 1300ma or 1.3 amps.
Note that UNIVERSAL replacement adapters will NOT work with the Vocalist.
Feb 06, 2011 | Digi-Tech Digitech Vocalist Live 4...
The foot pedal (not the switches) on my "DigiTech RP90 Modeling Guitar Processor does not work...it will move but it changes nothing.
All DigiTech expression pedals use an optical system instead of potentiometers.
Either the light is broke, or the filter.
The filter protrudes from the bottom of the pedal, and is darker at the top and gradually fades to clear at the bottom. If this breaks off, then there's nothing to limit the amount of light to the optical system.
If it is the light, then you'll have to have it serviced by someone qualified to work on it. Your local music shop should be able to help you out.
Hope that helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
Jan 13, 2011 | Music
The screen is very very dim
Make sure you have the correct power adapter. It should be 9VAC at 1.3Amp (1300ma).
Jan 09, 2011 | DIGITECH VOCALIST LIVE 2
It lights up but doesnt put out sound
A friend of mine had the exact same problem. In his case the pedal is only good for hammering nails now. If it still has it warranty I'd say look into that, if not you've got nothing to lose. Open it up, look for unattached wires. Also, try using a battery instead of an AC adapter..
Oct 26, 2009 | Digi-Tech Digitech X-Series Synth Wah...
I need the pin out details of a digitech rp6 guitar effects pedal
Try contacting the service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply which is PS0912.
May 25, 2009 | DIGITECH VOCALIST LIVE 2
Digitech RP90 Expression Pedal
Same thing happened to me but i didn't drop the pedal.Try to recalibrate the pedal cause mine worked after that.Look in the Owner's Manual at the recalibration section.Hope this will work for you.Good luck with it!
Mar 29, 2009 | Music
Music Logo
176 people viewed this question
Top Music Experts
Michial Gueffroy
Marvin
Marvin
Are you a Music Expert? Answer questions, earn points and help others
