Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
I have the same problem in DV2601tx as many others. its basically was overheating and then the screen has divideed into 6 X 2 parts.
  • 808 Answers
Clean the fan and replace ur vga
Posted on Aug 03, 2010
1200 BAKKIE OVERHEATED, WATER PUMP IS THE CULPRET, NOW SHE WONT START, WHAT COULD BE WRONG
Depends how hot it became depends on the damage caused - overheating is a very broad term that is often used when "cooked" would be more appropriate.
Mild overheating can burn the oil from cylinders robbing them of compression but seriously cooking an engine can destroy rubber components, weaken valve springs, melt pistons and create serious distortion of metal components.
Only a back to basics systematic approach can estimate the damage...
Sep 06, 2017 | Cars & Trucks
Upon turning on computer, screen remains black, power button, volume, speaker, etc. lights up, fan on, but NUMLock/Caplock LED's blink continuously (no pattern). Was able to get screen to appear after...
that error means BTW, POWER IS TOO LOW. !
one guy said what is power?, I said well, "it runs on DC power, from the power pack and bank of regulators in side, and if power is bad, all is hopeless until fixed. " We test that using magic tool called a voltmeter,guessing zero here. we do tests.
if that is not clear, have it serviced in a shop.
we first clean the PC and get out all that lint that causes overheating.
http://www.pcdied.com/overheated.html
DV7-1232nr
" Was able to get screen to appear"?
what screen? , keep in mind , we are blind here
in a silly text box. post photos of screens?
be like the first ever.?
We do sequenctial tests to fix PC
booting is serial process, so that is the path to proper diagnosis on all PC.
lets see , that now. 6 year old PC, best I can tell
1: main battery out! if PC runs now, the battery is bad. end story. buy one or leave it out for ever.
2: line pack , make sure 19vdc makes it to the MOBO, as for sure , no power there , NO JOY, ever. ok? use a volt meter, to test power or buy a new AC/DC PACK if guessing is the order of the day.
3: BIOS screens are first, forget windows, or what ever OS you run, (unstated by you ,sadly)
4: The BIOS screens are F10 or ESC, older is f10
the PC prompted you for 6 long years, hit F10? to enter setup, so that be it.
Power on and quickly n hammer the F10 key, see BIOS?
5: if the bios screens are dead, no text ever.
our gold is BIOS. first.
then the CCFL H3LL.
PC older than 2010 were NON LED screens and were
CCFL tubes (that sux) the fail, the all fail fast.
in fact left on in 2years the die. longer if LT unused mostly.
your PC has CCLF, they can go dim,blink,go yellow
or die or even go INTERMITTANT.
one day ok, next not this is the magic world of CCFL, all do that , now or soon ,for sure.
see the flash light trick yet.
as seen here
http://www.pcdied.com/monitors.html#flashlighttest
Lets say the LCD is truely dead not just back lamp dead. what then
I told you its serial process , and is.
next is what, well the PC told you power was bad.
in fact so bad the LCD data part is dead.
the PC can not compute at all.
due to low power.
we then stip the PC down to its basic parts.
from easy to harder in every case.
labor, hard. dig. LT sux to work on, a fact,
i pull the CD drive (testing boots each time)
I pull the HDD drive.
pull all memory but one testing each 1 by 1 for hope. deal.
my mobo in my laptop has 6 or 7 modules. (i dont pull CPU)
keep in mind any thing there seen can short. right?
you do know shorting will overload your regulators.
a fact of life
so pull them all, wifi card,modem card, express card, blu-tooth module ,well pull all that can be pulled. after all again, learn that all things inside can short out.
beyone here, is mostly main board doom.(mobo)
some 2008 PC had solder ball failure,
seems im not sure last your your was made, hoping not 2008., PC from H3ll MADE THEN.
i can not for he life of me unstand the afraid comment..
does that mean the PC runs ok after fiddling it
you never said that. only the fiddling parts.
Oct 10, 2017 | HP Pavilion DV7-1232nr Notebook
I have a 6 year old whirlpool dryer (GEW9250PW0) that needs the sensor for the air flow and heat to be replaced approximately every 6-8 months. The repairman (certified) replaced this part last monday and...
Barone1997,
By-passing any devices on a dryer or any other appliance is risky as doing this can void warranties and could create a dangerous condition.
If then dryer is overheating, check the venting for excessive lint build up and clean the vent as well as any hoses or other vent piping. Also check and clean the lint screen frequently.
There is also a limit to the length of the vent line and the number of bends that the vent line should have.
It's possible that the dryer vent may be damaged or kinked, so check that too.
Apr 18, 2011 | Whirlpool Dryers
I have a Samsung TXN3075, makes great video from laptop or cable input...for about 5 minutes, then its good audio, black video, until it cools down then it will work a bit. Could someone give me a bit of...
The screen is overheating, due to either a malfunction or poor engineering/assembly. It shuts itself off (as it's the HOTTEST part of any TV) to keep itself from basically bursting into flames.
Contact the manufacturer and have their tech support guys help you out with it. They may have other similar cases and perhaps even have some sort of warranty extension/free replacement based upon that specific problem.
Jun 04, 2010 | Samsung TXN3075WHF 30" TV
Overheating
hi dont go buying any new parts yet as you say its an old car it could be that overtime your rad has become blocked with silt etc drain your rad first easy way is to take off bottom hose when its cool fill up your rad with rad flush and follow the instructions on the bottle i hope this helps
Dec 03, 2009 | 1992 Toyota Tercel
Hp Pavilion dv2601tx Quick play not working
uninstall with revo uninstaller and install 3.2 back
Oct 25, 2009 | HP Pavilion dv9000z Notebook
HP PAVILION dv2601tx
ok...go here, find the HP icon, and get a set of device drivers for your model number..they are unique to your computer, not the o/s
Mar 30, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Hp dv2601tx
Unfortunately that is your hard drive heating up, they all do it, what you might consider,rather than a "chill Pad" usb fan system is an internal pcmcia card bus fan.
Mar 29, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Bios problem
dead hardrive would be my guess
Nov 08, 2007 | Computers & Internet
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
63 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
