Question about Thomson LCDB 03B 27 in. Television
I have a Thomson 27LB130S5U TV - have connected to my laptop with a VGA connector (both ends) but no picture coming through to the TV. Same laptop with a different TV no problem. Am I missing something?
  • Thomson Master
  • 17,130 Answers
It is possible that the VGA interface in the Thompson TV could be deffective. You will need to check for any break in the connectors, bend pins or within the printed circuit board. Since the TV is working fine there is a possibility only to find such a break or a failure of the VGA interface IC. Take help to make a test before you can replace. Hope the selection on the thompson was selected to VGA and still you did not receive the signal Please check this out. Good day
Posted on Aug 03, 2010
I want to connect my sony tritron tv to my hp laptop
If you Sony TV has a VGA video input socket then connect a VGA video cable to the TV and the other end of the VGA cable to the VGA video connector on your laptop.
Power up the TV and go to the Input selection Menu and select PC connector then boot up your laptop and the Windows video data will automatically to the TV.
You can toggle between the TV the LCD or both by pressing Fn key plus F4 key.
May 29, 2012 | HEWLETT-PACKARD G71340US Laptop
We are trying to set up a dual monitor system so that we cn watch movies via the pc [not laptop] we have plugged in all the cables but still zilch
if you want to set up a dual tv monitor system using via pc as a source you will need a VGA splitter usually 2 or more output. now how are you going to connect the 2 monitor and PC to the VGA splitter. first make sure your tv monitor is supported by service input for PC unit. then prepare the accessories needed. the VGA splitter and VGA cable. vinceisaac_30.jpg vinceisaac_31.jpg sample image for VGA splitter VGA cable or connector how are you going to hook up the splitter and VGA cable to the tv monitor and PC
  • you need 3 vga connector and 1 splitter to connect a dual monitor system.
  • connect one end of the vga connector to the pc unit and the other end to the input port of splitter.
  • now the 2 remaining vga connector connect to the output of splitter either of the port, then the 2 end wire you must connect to the input port ( pc service port ) of the 2 tv monitor. make sure you set up the right input either with the remote or at the tv unit to recognized the pc source.
  • you almost done the connections now at this point plug the tv monitors, plug the dc adapter supply of the vga splitter and lastly turn on the pc unit to view movies. i hope it will help you just ask me if you have further questions thanks for choosing the fixya.
Jun 05, 2011 | Televison & Video
I want the pictures of VGA CABLE of Samsung Sync Master 798 MB plus
Hey,
All VGA cables going to a CPU are essentially the same. Although, you may come across two types of cables. Picture 1 shows male-to-male connections. One end goes to the monitor and the other one to the CPU. The 2nd picture shows a male-to-male connector. It's always male-to-male connectors. However, you may use a male-to-female connector if you want to extend the existing VGA cable. Before buying it, just check what type of connection your CPU and monitor have at the back, for safety sakes.
Picture 1: .hak26_0.jpg
Picture 2: x hak26.jpg Hope this helps.
May 03, 2011 | Computers & Internet
Hi how do i connect my samsung r519 laptop to the tv using a vga/hdmi cable
hi
this link could be the cable that you are looking for
http://cgi.ebay.co.uk/GOLD-1-5M-HDMI-MALE-SVGA-VGA-M-CONVERTER-A-V-CABLE-/270549100366?pt=UK_Computing_CablesConnectors_RL&hash=item3efdfba74e
if the link dont work copy the link and paste it into your search engine
then connect the vga end onto the blue connector on the back of the laptop
and the other end into the hdmi slot in the tv
hope this is what you meant
Jan 29, 2011 | Samsung Computers & Internet
Can it connect to tv
You can connect your laptop to your TV by getting a VGA connector( male on both ends, see figure 2) provided that your TV has a vga port at the back of it. Once they're connected hold down the shift key and press f5
For more user guide info you can visit: http://support.acer.com/acerpanam/manuals/acer/0000/userguides/AS5610_UG_EN.pdf
Nov 26, 2010 | Acer Aspire 5610-4648 Notebook
How can I connect the Asus K50IN laptop to a TV?
if your tv is a newer hdtv it might have a 15 pin female vga connector in the back. I just use a vga cable from my notebook to my tv. make sure the vga cable is female on both ends. works great!
Oct 10, 2009 | ASUS Computers & Internet
Howto connect a ficture/film from computer to tv
there is a wireless signal sender that you can connet to the tv from your computer and it will send the signal so you can use your home tv as a computer monitor from any room in the house. search the internet
Sep 09, 2009 | Televison & Video
VGA and Audio cables connected to PC but no audio through TV
if your tv has vga input there should be a "line in" input very near it. VGA can only get its audio source through a "line in" connecting to the coaxial audio inputs will apply the music stream to a different video input on your tv. your tv has video 1, video 2, vga, and so on, but the vga cannot show video and then audio from the video/audio coaxial inputs. you will need something like a dual male tipped 3.5mm audio connector.
Good luck and pls rate this post
Mar 16, 2009 | HP Pavilion dv2000t Notebook
How do i hook up a tv monitor to my campaq computer
usually laptops have vga conector for external display, you may need a cable, vga cable.
vga cable varies depends on the connection that you have on the tv, if your tv supports vga connectors thats great, some tv doesnt have that option, thats where adapters go in to adapt what ever ports or connections you have on your tv.
some of the cable adapters that you might need.
vga to hdmi.
vga to rca.
vga to dvi.
hope that helps.
Oct 17, 2008 | HP Compaq Presario V2000 Notebook
Thomson LCDB 03B 27 in. Television Logo
279 people viewed this question
Top Thomson Televison & Video Experts
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
