Question about Nikon Cameras
My nikon digital camera flash light is not working.When i m using the flash light than my camera not click the pic..and when i m not using the flash light than camera click the pic but the pic quality is becuming good only in day light because in night flash light is not working.my digital camera model no. is coolpix S220 and this is 10 mega pixel.I am staying in chembur mumbai.This is my request that you plz guide me from where i can make it repair.Tell me any good service centre in mumbai . thanks
  • Nikon Master
  • 17,130 Answers
Not to worrry, the possible fault is with the failure of your flash unit. This unit is embedded into the camera and is a very arrangement which is not advisable to be opened by anyone less experienced. The best solution is to get the camera serrviced at the NIkon authorised service centre which is in Mumbai. You can get the exact address from any dealer who is selling the Nikon cameras. Get an estimate before you can give it for service as sometimes the woork may get very expensive.(web search for Nikon service centres in Mumbai -India) If you are choosing any local serivce centre be very careful not to get it tampered for total failure. Otherwise after your review decide on the job or use the camera as far as possible in daylight or you can use good lighting when shooting. Good day
Posted on Aug 03, 2010
Hi, i am using nikon d40 my problem is that i was using 18-55 lens after some years there was green spots on my pics when clicked,i started using 18-105 mm nikkor lens my problem was solved but now af
The D40 is a low end camera, but before you discard it, I would contact the closest Nikon repair depot (see the Nikon website for the location) and ask them for a repair estimate. You will then be able to decide if it is better to have it repaired or replace it with a newer model.
Jan 08, 2013 | Nikon D40 Digital Camera with G-II 18-55mm...
My Nikon D 80 on the same exposure settings in
You have a shutter problem that can only be fixed by a service technician.
Aug 03, 2010 | Nikon D80 Digital Camera with 18-135mm...
Built in speedlight on nikon d70 has stopped working. The light pops up, but no flash
If flash pops up and doesn't fire, little white pin/lever inside flash has lodged up inside flash casing and needs to be eased from where it is stuck. Careful when opening the flash up to dislodge the white plastic pin/lever, there are tiny wires you REALLY don't want to damage....
See how, with pics here:
http://www.stephanmantler.com/blog/d70s-camera-repair/
Sep 12, 2009 | Nikon D70s Digital Camera
Unfocused Pics
If you use the "macro" setting (the flower symbol on the command dial), and are holding the camera steady, it should work. Try to ensure sufficient light by shooting near a window. You should also disable the flash by using the arrow on the dial to go to the "no flash" setting. The main problem is most likely that you are shooting close to the images, so the macro setting is a must. Good luck.
May 23, 2009 | Nikon Coolpix L11 Digital Camera
Nikon CoolPix S5. Red flashing hand. Camera/Lens on/open.
If the shutter is stucked there is no external way to release it Have to show it at camera shop
Mar 15, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Why hasn't my Nikon Coolpix L15 ever really worked?
try rechargeble batteries. i switch to rechargeble batteries and they last much longer than regular batteries.
Dec 20, 2008 | Nikon Coolpix L15 Digital Camera
Nikon Coolpix digital camera L18
The red light is probably the focusing beam. I'd guess that your flash is turned off somewhere in your settings. Go through the menu and if you find that it is not turned on there might be a hardware problem. Also, if the flash is set to automatic, it will not work when it thinks there is enough light to take a good pic.
Nov 07, 2008 | Nikon Cameras
Nikon Coolpix 5700
your flash doesnt work to use the camera turn off the flash also you can get an external flash for less than it takes for them to fix it good luck
Sep 24, 2008 | Nikon Coolpix 5700 Digital Camera
Horizontal lines on image
This is not a solution , but only a work around. If you do at least 1/3 zoom on your lens before clicking a photo, these lines will not appear. But this not not a convenient way I agree.
Also this surely means that the CCD is not the problem otherwise it would have never worked ( electronic parts cant simply dont start to work when you zoom ringht ? ). Surely Nikon is fixing the issue, but cheating the customers by charging for a part is not defective in the first place
Nov 22, 2007 | Nikon Coolpix 8700 Digital Camera
Cameras Logo
168 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
