Got a new 160 GB Seagate Hard disk. Formatted and installed Windows XP SP3 on it. But the problem is it gets hanged randomly every time i boot it. Tried re-formatting it, but it gets hanged even at this point. The same hard disk works fine with Ubuntu 8.04. Couldn't trace out what the problem is? Any help on this is really appreciated!
  • 12,061 Answers
I suspect that this is NOT a HDD issue but a driver one. I suspect that you may have some driver conflict. Try booting in Safe Mode, if it does OK, then this proves it. you will then have to go through the drivers one by one until you find the bad one. Often it is the Video driver.
Try a reinstall with XP SP 2 FIRST, then upgrade as necessary, some PC's just don't play well with SP3 installs.
It MUST be a windows/driver/setting issue as you relate it works on linux.
Posted on Aug 03, 2010
Replacing acer aspire hard drive
use the ultimate boot cd to fix hdc
or boot os disk then hit f6 for third party drivers then load mass storage driver for your laptop so replaces the one on the new hard drive. video on ultimate boot cd in link advance to 52:41
PC Diagnosis and Repair
Jul 13, 2017 | Acer Computers & Internet
Can i reformat a xbox 360 seagate harddrive to windows xp??
Yes, your can format the hard drive and install Windows this drive
If you have the Windows XP disk it will partition the drive also
The drive must be fully formatted to work properly.
Sep 23, 2010 | Seagate Barracuda 7200.7 40 GB Hard Drive
How to make partition in a new seagate freeagent Go 320 GB
Here is a link to Microsoft on how to get to and use disk management. I do not know what operating system you are using but disk management has not changed a lot. The link below references XP and if you follow this step by step it will work great.
http://support.microsoft.com/kb/309000
Mar 10, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Gowthaman
Check if the jumpers on the hard disks are in the right position.
Apr 10, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Troubling in sata connection
  • I suppose there is a jumper(beside the power pin) on your new HDD,
  • if its true the your HDD supports 3GB/s mode but your motherboard does not .
  • So place the jumper on the HDD on 1.5GB/s combination.
then
  • Disconnect the 80 GB,
  • Connect the new HDD,
  • Boot from any bootable xp or vista or any disk tool like erd commander and try to format the new HDD.
  • Then connect the new HDD and boot from it.
Tell me what happened.
Jan 31, 2009 | Seagate 20PK 320GB SATA 3GB/S 3.5 7200RPM...
Disk manager for seagate 160 gb sata barracuda hard disk
windows xp setup not creat the partation.
and not show the tha harddisk,but harddisk are showing the bios setup.
my system is ACER ASPIRE tower Casing.
Jan 10, 2009 | Seagate (ST3160827AS) 160 GB Hard Drive
Xp pro repair/reinstall problem
check the connection of your hard disk, its properly conect or not
change the cd of windows and check it,
Sep 28, 2008 | Maxtor Hard Drive
Maximum size of hard disk supported
Hi Bijay.
Neither is at fault. Please click on this Seagate link:
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=How_To_Install_and_Troubleshoot_ATA_Hard_Drives&vgnextoid=559e5b1142aec010VgnVCM100000dd04090aRCRD
Scroll down to: Partitioning the drive in Windows XP / Windows 2000 (for systems where this is the 2nd drive in the system).
Follow the instruction on the web site.
This Seagate web site will help you setup the Seagate 160 drive.
If you feel the drive is still at fault you can run Seagate’s SeaTools. Click on the next link:
http://www.seagate.com/www/en-us/support/downloads/seatools
This software will check the 160GB drive.
(Follow the online instructions for), SeaTools for DOS.
In a Windows XP system & using a FAT 32 & a cluster size of 16kb instead of NTFS. Windows will see the total size of the drive but can only access 149GB of drive space. 11GB of drive space will be used by the FAT. File Allocation Table. The FAT is windows guide to every cluster on the drive.
XP uses NTFS & sets each cluster to 4kb. This 4kb size lowers the total usable GB size & uses more GB's for the FAT. You're 127GB size may be correct for a Win XP system using a NTFS file system. The FAT is using 33GB of drive space as a locator for every cluster on the 160GB drive.
Help with understanding the NTFS file system: http://www.microsoft.com/windowsxp/using/setup/expert/russel_october01.mspx
Bijay if you are still having trouble understanding please post any questions here.
Mike
Aug 12, 2008 | Intel D845GLLY Motherboard
Seagate 160 gb capacity problem
the harddrive size is in another measurement system and the actual size of the drive is exactly what you are seeing 152.
here you can see how my disks show
894a905.jpg 160GB disk - 152,66GB
1000GB disk - 931.51GB
that is correct.
Jun 15, 2008 | Seagate (ST3160827AS) 160 GB Hard Drive
Disk not being Recognised: Windows XP asking for driver
s cuase u r using ur hard disk with different mother board so u need to format it or u need to get teh mother board cd an dchange the boot sequence as cd-rom and run it
Oct 31, 2007 | Seagate Barracuda 7200.7 40 GB Hard Drive
Computers & Internet Logo
Alun Cox
David Payne
David Payne
