Question about Frigidaire FRS23KF7AB Side by Side Refrigerator
Eurotek freezer why it does not freeze
Eurotek upright freezer why it does not freeze. what are the red and green lights for? I lost our manual so I have nothing to refer to.
I have a eurotek upright freezer. green light is a power on indicator ... reddish light is fast-freeze mode ... i have a copy of the manual... if you have additional queries, you can reach me at citizen_jdc@yahoo.com.ph
thanks
Posted on Sep 28, 2010
Orange light is on instead of green light on freezer what does this mean
Most often the old freezer has three indicator lights.
- Green light : that it is brought to a power source and turned on - Red light : means that the temperature is above -18 degrees - orange light : pressing the so-called S-switch which means that the compressor is running continuously. The S-button switch on a few hours before you begin deep-freeze foods. Freezing time depending on foods quantity (kg). With old freezer must be careful to turn off the switch S (orange light) when the red light goes out or when foods are frozen, otherwise after a few days may burn out the compressor. You should be following the instructions from user manual.
In new freezer managed by the electronics, this function has a predetermined maximum duration, in order to protect the compressor, and can have different marketing names like "shopping".....
Dado
Jan 14, 2014 | AEG 10.35 cu. ft. / 293 liter Upright...
BRADA MF-305 UPRIGHT FREEZER AMBER/YELLOW LIGHT ON
I bought the same freezer and have the same question.
Anybody know? Did you figure this out vemmy?
Aug 03, 2010 | Samsung SRS20DTD Side by Side Refrigerator
Red and Orange light staying on on my whirlpool chest freezer
try a total defrost,to clear any internal ice(every 12 months)then switch on and if you have a rapid freeze button leave on for 24 hours to get back to normal operating temp.if you have hard ice around the door seals then you have an air leak which you must sort out(try using a hot cloth to warm seals back into shape.....seals should fit all round, all the time.
Apr 04, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
I don't know what the lights mean on my Beko chest freezer. Have just found it defrosted and want to make sure the defrost is off. It is switched on at the mains. What lights should be on? I've lost the...
two reds and green are the auto max freeze on indecators the reds go off one at a time when unit drops to safe temp mode.also means unit needs defrosting manually when too much ice is present.
Feb 03, 2010 | Freezers
I have a hotpoint freezer 8742 and the red light came on and it defrosted. how do i get the light to go off and start freezing again
if turning the power off for a short while doesn't work then the unit will need a technicians eye. I would expect it's a thermocouple or thermo switch, but worst case it could be that it's lost gas pressure
Jan 19, 2010 | Freezers
Does the light on the outside of freezer stay on . I bought a used freezer. It is a frigidaire commercial upright (frost free) Does the light on outside of freezer stay on all the time? I have no manual....
Normally there is a Green light showing that power is on
A Yellow one for fast freeze and a Red one for under temperature
The outer casing is well insulated from the inside otherwise the freezer motor would run none stop without cooling the contents so the temperature of the outside casing will reflect the room temperature not the intenal
Aug 21, 2009 | Frigidaire 20 cu. ft. / 566 liter Upright...
Red light on not green ...has to be green to freeze up again
Try to unplug it for about 5 minutes, and then plug it back in
Apr 17, 2009 | Freezers
Whirlpool a class freezer
Red Light : Alarm high temperature.
Amber Light : Fast freeze function (ie ignores thermostat and keeps unit freezing all the time).
Green light: mains power.
If you have lost temperature on a freezer it is usually a major fault either the compressor has failed or you have lost charge (possibly the start relay). If you are able to get to the rear of the unit and check the compressor, if it is hot then it is more likely a major fault. A good fridge guy can normally tell the problem within a short time of inspecting the unit. Sorry to not sound hopeful. Good luck.
Mar 13, 2008 | Refrigerators
Frigidaire FRS23KF7AB Side by Side Refrigerator Logo
270 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
