Question about Canon PIXMA iP2000 InkJet Printer
Canon Injet PIXMA iP2000 - USB001 printer will not print. Container for extra ink is full, how change the container for extra ink.
57 varieties
  • 1653 Answers
SOURCE: Hi, Waste Ink asorber is full on my Canon PIXMA
Removing & Cleaning the Absorbent pads.
The printer has 2 ink absorber pads that are located under the ink cartridges.
1. With power off the head assembly / cartridges can be moved into the middle for access.
2. Each of the 2 ink absorber pads are seated in a rubber retainer. The pads can be easily removed cleaned or replaced.
3. Carefully remove the pads using long nose pliers or tweezers.
4. Clean the using with running warm water, or use an isopropyl alcohol bath, or an isopropyl alcohol based aerosol if they are really dirty. DO NOT USE ANY SURGICAL SPIRIT OR ANY OIL BASED CLEANERS. At a push you can use a warm water mild washing up liquid bath but be sure to thoroughly rinse out the solution after cleaning. The pads should be white when they are clean.
5. Dry the pads – it may take some time and placing them in a warm environment or near a warm radiator will speed this up.
6. Clean away any ink on the retaining rubbers using a cotton bud or clean and soft lint free cloth.
7. Replace the DRY pads in the rubber retainers.
8. Replace the Ink cartridges.
9. Power on the printer and print a test page and clean and realign the heads as required.
Posted on Oct 21, 2009
  • 83 Answers
SOURCE: Ink waste absorber is full. Canon IP2000. How do I repair it?
Well, at some point you will need to either replace or wash the absorber pads in the printer - but you can reset the warning as follows:
1) Turn the printer off
2) Press and hold the <resume>button
3) Press and hold the <power> button
4) While holding down <power> release <resume>
5) With the power button still held down, press <resume> twice more
6) Release the power button
7) Press and release the <resume> button 4 times
8) Press and release the <power> button twice
At this point, the printer should come back online with the waste ink warning reset
Personally, I would only do this once before actually changing the ink absorber pad...
Posted on Aug 31, 2009
nethload
  • 22 Answers
SOURCE: The message 'waste ink absorber' nearly full
solution found!!
> this is copy paste from some other message and it works
> and for now it's not only temporary.
> I have a temporary fix (doesn't keep without power):
> 1:Unplug power and USB
> 2 Open door and hold power button.
> 3: Connect power.
> 4: Close door, then release power button
> Connect USB and an press power to use.
> Print instructions and stick it to your printer
Posted on Oct 27, 2009
pineworks
  • 4041 Answers
SOURCE: My Canon PIXMA iP2000 photo printer Waste Ink Absorber
Hi there try see if this will work
Reset ip2000
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 13, 2010
pineworks
  • 4041 Answers
SOURCE: How can fix if waste ink absorber is full for
Hi there Ok. Canon PIXMA IP2000
You may RESET the printer code first if you like or do it after you clean the pad
In some cases you may need to REMOVE THE PRINT HEAD FIRST or the reset code will not work. This was true of the S900 and i960 so, remove the print head first before doing this reset.
This is the correct code for the S and I (like i960) series of printers. (M series below this)
1) Power off printer
2) Hold RESUME button then press and hold POWER. (The beeper MAY sound once, or may not depending on your model.)
3) Hold POWER and Release RESUME.
4) Press RESUME twice then release both POWER and RESUME buttons.
5) When the indicator lights steady, press RESUME 4 times (for the S900, 3 times for the 8200 apparently).
6) Press power to set data.
7) Print away!
For other codes for other printers and more info go here to this big forum (but try the above first) Fix Your Own Printer Generally many of Canon's models use exactly this same code, the i models use the same code, all the s models use the same code.
Posted on May 01, 2010
I am getting E 2 and E 7 and a message comes up saying ink absorber is full?
Compare it to having a garbage-bin in your kitchen.
Eventually, it gets full, and you must take its contents, and put them into the garbage-bin outside your home.
Similarly, when your printer prints, some "extra" ink is produced (in addition to that ink that reaches the paper), and that ink is saved inside the printer, in an absorbent container. That container is monitored, and the printer is reporting that the container is full.
So, "empty" the container, by replacing it, or getting a qualified printer technician to replace it.
Apr 05, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Container for extra ink full.
www.printersiam.com/.../Canon%20Waste%20Ink%20Tank%20Reset%20Procedures... -
That above link tells you how.
Mar 28, 2010 | Canon BubleJet i965 InkJet Printer
How will i clean the ink waste absorber and reset it
use this link click here
this wil help you in cleaning the waste ink
you can also take halp of the following link
Jul 27, 2009 | Canon PIXMA iP2000 InkJet Printer
My printer, the Canon, Pixma Ip2000 stopped printing. It was giving me the message "the waste ink absorber is full". I took it to the only canon dealer in the city, and he reccommended that I replace the...
Reset Printer Canon IP2000 / IP3000
By pelda
1. Turn off printer
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
http://freeresetterprinter.wordpress.com/2008/09/05/reset-printer-canon-ip2000-ip3000/
Mar 26, 2009 | Canon PIXMA iP2000 InkJet Printer
How do I reset the printer after washing the ink absobers
how do i clean the ink waste absorber of canon pixma ip2000 printer
Mar 24, 2009 | Canon PIXMA iP2000 InkJet Printer
WASTE INK ABSORBER IS FULL FOR CANON PIXMA iP2000
The machine needs to be taken in for the waste ink absorber to be replaced
Oct 03, 2008 | Canon PIXMA iP2000 InkJet Printer
Pixma ip2000
waste ink absorber is full what can i do
Nov 29, 2007 | Canon PIXMA iP2000 InkJet Printer
Change of language
you need to uninstall the driver from the computer and then reinstall it in the english language, the printer itself has no language, the interface is the computer, if it is spashing ink on the paper it is probably the ink or the ink head, try change the ink and i strongly suggest genuine ink, not that cheap shit that clogs up the print head
Oct 28, 2007 | Canon PIXMA iP2000 InkJet Printer
Canon PIXMA iP2000 InkJet Printer Logo
241 people viewed this question
old marine
old marine
