Question about SMC Barricade 7004VWBR Wireless Router
How to secure my internet connection via smc router
  • 12,061 Answers
If you plan to have a wireless network, you should set it up so that only people you choose can access it. Here are a few options for wireless network security.
Wired Equivalent Privacy (WEP)
WEP is a widely used network security method. When you enable WEP, you set up a network security key. This key encrypts the information that one computer sends to another computer across your network. The receiving computer needs the key to decode the information so that it's difficult for someone on another computer to get onto your network and access files without your permission.
Wi-Fi Protected Access (WPA)
WPA was created to improve the security of WEP. Like WEP, WPA encrypts information, but it also checks to make sure that the network security key has not been modified. WPA also authenticates users to help ensure that only authorized people can access the network. If your networking hardware works with both WEP and WPA security, we recommend that you use WPA.
There are two types of WPA authentication: WPA and WPA2. WPA is designed to work with all wireless network adapters, but it might not work with older routers or access points. WPA2 is more secure than WPA, but it will not work with some older network adapters. WPA is designed to be used with an 802.1X authentication server, which distributes different keys to each user. This is referred to as WPA-Enterprise or WPA2-Enterprise. It can also be used in a pre-shared key (PSK) mode, where every user is given the same passphrase. This is referred to as WPA-Personal or WPA2-Personal.
802.1X authentication can help enhance security for 802.11 wireless networks and wired Ethernet networks. 802.1X uses an authentication server to validate users and provide network access. On wireless networks, 802.1X can work with Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) keys. This type of authentication is typically used when connecting to a workplace network.
IF THIS ALL DOSEN'T WORK TRY THE FOLLOWING:
Wireless network security recommendations
If you have a wireless network, there are some additional security precautions that you should take.
Use a network security key
If you have a wireless network, you should set up a network security key, which turns on encryption. With encryption, people can't connect to your network without the security key. Also, any information that is sent across your network is encrypted so that only computers that have the key to decrypt the information can read it. This can help avert attempts to access your network and files without your permission. Common wireless network encryption methods are Wired Equivalent Privacy (WEP) and Wi-Fi Protected Access (WPA) and WPA-2.
Change the default administrator name and password on your router or access point
If you have a router or access point, you probably used a default name and password to set up the equipment. Most manufacturers use the same default name and password for all of their equipment, which someone could use to access your router or access point without you knowing it. To avoid that risk, change the default administrator user name and password for your router. Check the information that came with your device for instructions about how to change the name and password.
Change the default SSID
Routers and access points use a wireless network name called a service set identifier (SSID). Most manufacturers use the same SSID for all of their routers and access points. We recommend that you change the default SSID to keep your wireless network from overlapping with other wireless networks that might be using the default SSID. It makes it easier for you to identify which wireless network is yours, if there is more than one nearby, because the SSID is typically shown in the list of available networks. Check the information that came with your device for instructions about how to change the default SSID.
Position your router or access point carefully
Wireless signals can transmit a few hundred feet, so the signal from your network could be broadcast outside of your home. You can help limit the area that your wireless signal reaches by positioning your router or access point close to the center of your home rather than near an outside wall or window.
Posted on Aug 03, 2010
3 Suggested Answers
  • 9 Answers
SOURCE: Linksys Wireless-G not connecting to internet
Make sure you are plugging the SMC into the WAN port on the Linksys router and not the LAN ports.  Your internet connection (which is your SMC) should always plug into your WAN port on the Linksys.  Any computers that you may need to plug in, like Desktops that are "wired" and not "wireless", should plug into the LAN ports on the Linksys.  If you are not using the WAN port on the Linksys for your SMC modem, then that would explain why you cannot get to the internet on wireless or wired computers.
Here's why you are getting the "low connectivity" message:
Computers don't understand why the Internet is connecting or not connecting...so the "low connectivity" message you keep receiving has nothing to do with your wireless signal strength.   To a computer NIC, "low connectivity" means your network adapter could not find a DHCP server and receive a valid IP address.  When this happens, your network adapter assigns an IP address to your computer in the following range...169.254.0.0, and will display the "low connectivity" message until it is able to receive a valid private IP address from the DHCP server.  You can verify this by going to START | RUN and typing "cmd" (without the quotes), then hit ENTER.  A black box will pop up....then type "ipconfig" (without the quotes) and hit ENTER.  This will show you your IP address, subnet mask, and gateway address, and you can verify that your IP address is in the 169.254.0.0 range.  A valid private IP address is typically in the 192.168.0.0 range, but could also be in the 10.0.0.0 range, or the 172.16.31.0 range.    Also, make sure you have DHCP server enabled on the Linksys router for the LAN.  This will ensure your "wired" and "wireless" computers receive a valid IP address.
The WAN port on your Linksys router should be configured to "Obtain an IP address automatically using DHCP".
Cheers!
Posted on May 01, 2009
  • 5 Answers
SOURCE: cannot set up security on wireless router "wireless card nt found
Are you trying to configure the router wirelessly. Connect your computer to the router with a lan cable and then access the router and change its wireless settings. since you cannot change the wireless settings wirelessly as you will get disconnected.
Posted on Sep 07, 2009
My internet service is with Suddenlink, I have a SMC wireless router, but I can't connect my Acer Aspire computer to it wirelessly.
Hi - My name is Tina and I am with Suddenlink. Are you leasing the SMC Router from Suddenlink? I'd be happy to help resolve this issue for you -- please contact me directly via email at tina@suddenlink.com. Thanks!
Apr 05, 2011 | Computers & Internet
I have an SMC wireless router and have lost the security Key. How do i find it? Thanks alot, Paul model: SMCWBR14-G2 part number: 752.86707
If by security key you mean the one to connect to the router and use it (also called a WEP/WPA key) - you can find this inside the router config, login to the router via the web login page (you'll need to connect to the router via lan cable to do this) and once your inside you'll find the key somewhere in its settings, you can change it in there too.
Oct 29, 2010 | Computers & Internet
Can I use a USB Modem (cricket) on the USB Port on SMC Barricade SMCBR14UP Router ? Thanks
No, this SMC router is designed for Broadband connection via RJ-45 connection thru WAN port.
The USB is there for USB printer as Printserver.
Jul 27, 2010 | SMC Barricade SMCBR14UP Router
Currently Connected to internet with to Telefonica through ethernet, and SMC Wireless router will not work. Router worked a few days ago, but now will not function either via ethernet or wireless. Our...
It appears the SMC router is faulty. The router is getting an IP address from the IPS because they can can PING your router and get a reply BUT the router's PPoE/DSL light is not on, it means it is not connecting with the ISP's WEB server and therefore you cannot get into the Internet.
Feb 25, 2010 | SMC Barricade g SMC2804WBRP-G Wireless...
Cannot set up security on wireless router "wireless card nt found
Sep 03, 2009 | SMC Barricade g SMC2804WBR Wireless Router
Cant connect my SMC to other home computer and have a netgear router, how do i connect my smc adapter
Most hardware like an Network Adaptor you install the software CD 1st. Then plug in the hardware.
Then if you configured wireless (wifi, 802.11) settings on your SMC - you should fine the network NAME when you try to connect. You will be asked for the security key for WEP or WPA or WPA2 that you used in the SMC.
SMC should... then assign IP Settings automatically. If the SMC has Internet, you should have Internet.
Jul 07, 2009 | SMC EZ Connect g SMC2862W-G 802.11g/b...
Two router home network problem
Can you still connect to the Internet with the Linksys router? I suggest that you go ahead and reset the SMC router to clear up your previously configured settings. Then before reconnecting it to the linksys router, make sure that you can access its web interface via 192.168.1.1. Don't disable DHCP as your computer won't be able to obtain an IP address from it automatically. Do not change other settings. Next, disconnect the ethernet cable and check if you can access the router interface wirelessly. Once done, connect SMC's WAN port to Linksys' numbered port. Make sure SMC's WAN light is on, as well as the light for the port you used on the Linksys router. Check if you can get online.
With this configuration, the linksys router is now acting like a modem, and the SMC as your router. As long as you're online when wired to the linksys, you should also be able to access the net on the SMC once you physically connect them.
Dec 22, 2008 | SMC2804WBR Wireless Cable/DSL Broadband...
Problems with SMC2804WBRP-G not detecting/connecting with Windows Vista
i have a similar problem with SMC7904WBRA2 Barricade router. I can only intermittently connect from my Vista Home Basic PC to the router. Most times I am unsuccessful.
Feb 19, 2008 | SMC Barricade g SMC2804WBRP-G Wireless...
SMC Barricade 7004VWBR Wireless Router Logo
654 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
J John
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
