Question about Nokia E63 Cell Phone
White light solution - Nokia E63 Cell Phone
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 185 Answers
Put your hand over the screen
Posted on Aug 03, 2010
Want to attach a harbor breeze light kit to an existing hunter fan. switch housing has 3 white wires hooked together with a blue connector cap and a single black and white wire(labeled for light). there...
White to white ( single white ) & blue from light kit to Black with white stripe. Also make sure the black with white stripe coming out of TOP of fan is connected to the hot wire.
Aug 26, 2013 | Hunter 52" Ceiling Fan With Light And...
Bulbs blinking fast with light on. it cieling fan has white black green and a black n white wire?does the black and white wire get wired with black or white wire
black to black and white to white. black is hot wire, and white is the nuetral wire. the reason why lights are blinking is there is a watt governor in fan for lights its a little black box. if you remove box, and wire direct for lights. this should take care of the problem. have a good day !!
Dec 12, 2010 | Hunter Ceiling Fan Control Switch
Wiring schematics for a kenwood kdc-mp145 to a 1998 ford ranger
Battery light green to yellow
Accessory yellow/black red
ground black black
Illumination light blue.red orange/white
Power antenna amp=blue blue
LF + orange/light green white
LF - light blue/white white/black
RF + dark green/orange gray
RF - white/light green gray/black
LR + gray/light blue green
LR - tan/yellow green.black
RR + orange/red violet
RR - brown/pink violet/black
Sep 21, 2010 | Car Audio & Video
Need factory wiring codes for a 1999 jeep grand cherokee
battery red/white
accessory white/red
ground black
LF - light green/green
LF + light green/red
RF- light blue/ black
RF+ light blue/red
RR- tan/dark green
RR+ white/violet
LR- white/dark green
LR+ dark green/white
Dimmer orange
This wiring is for the standard audio system
Sep 17, 2010 | Car Audio & Video
Wiring instructions are terrible. Ceiling wires = Red, Black, White, Copper. Fan wires = Black, White, Copper. Remote wires = Neutral in(Black), Live In(Black), Light out(White), Fan out(White),...
That is dificult to follow .. here is the usual wiring plan for ceiling fans .. green to green or bare and mounting bracket ... ceiling black and red are live from the switches, fan and light.with a remote you really only need one of these , so cap off the red and use the black as your input to the remote .. the neutral to the remote should be the white .. there are only 3 wires from the fan so I am assuming that there is no light , or the light will be activated from the remote .. the black for the fan and the black for the lights connect to marked wires on the remote. .. lights out, fan out
or looking at your description .. ((Remote wires = Neutral in(Black) white ceiling wire, Live In(Black) blaxck ceiling wire, Light out(White) blue Fan/Light wire, Fan out(White) black fan/light wire, Common(White) white ceiling and white fan/light wires.
May 21, 2010 | Hunter 27148 Remote Control
I'm installing a vanity light in the bathroom. The old one had a dimmer attached. For the new fixture, attached two white from the wall to the white in the fixture. attached two white from the wall to...
Get a test light, a bulb in a socket with a black and a white wire. disconnect both the black and the red. Also have access to the white or the ground. Then with the power hold the white test light wire to the white of the house and the black to the black. .turn the dimmer on and off and see if it controls the light. NEXT do the same with the red, that is test light black held to red and test light white held to house white. once again check the dimmer.
Typically when you have a hot red and a hot black in a fixture the black is on the dimmer and the red is always on because it is connected to an outlet built into the light. OR the light can be controlled from two locations, one regular switch and one dimmer switch.
Mar 01, 2010 | Electrical Supplies
I'm using a Leviton 1755 combo 3 switch for a bath light/fan combo and then onto a vanity light. Basics: wires from ceiling light/fan: black, red, white, ground. Wires to vanity light: black, white,...
remove white switch one and connect to incoming white ground--all whites should be connected [hooked] together these are grounds-- switch 1 black from fan ,leave switch 2 red from fan ,switch 3 vanity black
Feb 22, 2010 | Leviton 003-1755-W Three Rocker Switches
Need diagram for hunter fan with light kit. Three
Black to black. from fan
Blue to Black and white. from fan
White to white. from fan
The input is from ceiling supply
the black wire from fan is for motor.
the black and white is for the light.
Jan 02, 2010 | Hunter 52" Ceiling Fan With Light And...
Wiring diagram to hook-up remote starter on 1996 dodge caravan
Constant 12V+ Red or Pink/Black - Ignition Switch Harness
Starter Yellow - Ignition Switch Harness
Ignition Dark Blue - Ignition Switch Harness
Ignition 2 Black/White - Ignition Switch Harness
Ignition 3 Dark Green/Red - Ignition Switch Harness
Accessory Black/Orange - Ignition Switch Harness
Tach Gray Or Blue/Tan PCM Coil 2.4 Liter - Engine
Neutral Safety Wire Black/White - Power Control Module
Brake Switch White/Tan - Brake Switch
Trunk Pin Tan/Black - 40 Pin Connector at Fuse Panel
Parking Lights Light Green/White (-) - Head Light Switch Harness left of Column
Head Lamp Green/Orange - Light Switch
Factory Disarm White/Dark Green - (665 Ohm) left Connector bottom of Fuse Panel
Door Trigger Brown/White (-) - Lower right Gray Connector at Fuse Panel
Door Lock White/Dark Green - BCM at Fuse Panel
Door Unlock White/Dark Green - White Connector B58 Connector
Horn Wire Black/Red - Steering Column
Windows Up LF=Light Green, RF=Brown/White, LR=Blue, RR=Gray
Windows Down LF=White, RF=Purple/White, LR=Red/White, RR=Dark Green
Your R/S instructions should tell you what goes where.
Thanks for using FixYa - a FixYa rating is appreciated!!
Jan 31, 2009 | Vehicle Parts & Accessories
White Balance
What is White Balance? The human eye captures white as white, red as red and blue as blue, regardless of whether you are outside under the sun or inside under incandescent lighting. Although this is something that we take for granted, the human eye actually adapts to correct the changes in color under different light sources. In reality, when light sources vary, colors caught as the reflection of those light sources also vary. For instance, films for cameras that use film are designed to capture the most appropriate coloring outside under the sun. Thus when you take pictures under incandescent or fluorescent lighting without using a flash, the colors in the resulting picture may seem strange. Digital camera and digital camcorders are equipped with a handy feature called "White Balance" that corrects the changes in color under different light sources, just like the human eye. One of the white balance settings, "Auto White Balance" (AWB) automatically adjusts to correct the changes in color under different light sources. White Balance and Coloring The White Balance feature on Canon digital cameras and camcorders is set to "Auto White Balance" at the time of purchase. If you prefer different coloring, if you want to adjust the coloring more in detail, or if you want to change the coloring on purpose, we recommend that you change the white balance setting.
Sep 04, 2005 | Canon GL2 Mini DV Digital Camcorder
Nokia E63 Cell Phone Logo
170 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
