Question about LG 24 in. LD-12BW5 Free-standing Dishwasher
It seems the pump has stopped working, there is a 2-3 litre amount of water in the bottom of the dishwasher. My wife put a jar in the dishwasher with a label on it. The label was washed off. I am guessing that this clogging the pump. Any ideas on how to fix this ??? (I was thinking a strong cleaner to dissolve the paper)
    Problem Solver:
  • 11 Answers
A small label like that shouldn't be the problem the motor may have just burned out. if it still sprays then is a solenoid that changes the valve to pump out. If it doesn't spray you may have a more serious issue.
Posted on Aug 03, 2010
Bosch dishwasher 4 weeks old comming up with check water
Should still be under warranty. Contact retailer. Don't try doing anything else to it in case you void the warranty.
Aug 09, 2014 | Bosch Dishwashers
My whirlpool dishwasher is not draining completely. It runs through the entire cycle with no problems, except that after it has finished, there is a layer of water on the bottom of the diswasher.
Hi, there will always be some water in the bottom the tub. This is called the sump. When your pump stops draining, all the water that's up in the hose will drain back into the sump. You failed to tell me how much water is there. If a small amount then it's normal, however if it's a large amount that covers 1/2" or so then you indeed have a problem and snaking out the lateral should clear it up.
Jun 28, 2011 | Whirlpool Dishwashers
F14 code Miele Dishwasher
This fault is low pump pressure. more than likely you have some foreign particles jammed in the circulation pump. you would have to remove the unit, tip it on its side and remove the bottom plate and remove the circulation pump and clear the blockage. the unit will start and stop and not work until the pump is clear.
Aug 14, 2010 | Miele Premier-Plus Built-in Dishwasher
GE Dishwasher no water upon start, humming, blinking lights
Seems like the anti flood is activated when water (even a small amount) appears on the bottom of the machiene. This is usualy a leaking pipe but can also be caused by a clogged pipe. Most machiens do have a plastic pipe that (from the flat water tank) feeds water to the bottom of the machiene in case of an internal fault. The anti flood is normaly a polystireen float with micro switch on the base of the washer. This automatically puts the outlet pump on to drain the water. The machiene does not work exept the outlet pump in this mode.
Jan 18, 2010 | Dishwashers
Candy dishwasher 2 program lights keep flashing after program starts then stopas and flashing starts
My candy dishwasher Model No CDI 3015-S retains water in the bottom of the machine at the end of the program. I have checked the filter which is clear so do not know what else to do to clear the problem. Anyone faced this problem or know what might be the cause?
Jan 18, 2010 | Candy 17 in. CS455 Built-in Dishwasher
My wife started the dishwasher normally. Water
Quite possibly something lodged in the pump, locking it up. Control sensors don't advance timer because unit is not running.
Sep 11, 2009 | Maytag Dishwashers
My Maytag Quietseries 300 has suddenly stopped draining H2O
My Maytag Quietseries has the same problem after less than 2 years. Mine is caused by using granular dishwasher detergent, which is the most common type of detergent. I took apart the entire pump inlet section (need a torx scew driver and a small socket for the impeller) and found the white abrasive material from the detergent (Cascade in my case) was packing in and pluging up all areas of the inlet. After I cleaned it all out & reassembled, dishwasher was back to 100%. Also noticed the normal cycle worked much better as well.
Jul 22, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Water pooling on bottom of dishwasher
Check the drain pump for debris that might be stopping the drain pump from working. Also could be faulty drain pump.
Feb 20, 2009 | GE 24 in. GSD4320Z Built-in Dishwasher
Water pump doesnt stop running
bottom tray under dishwasher holds a cut out switch.this is activated when there is a leak from unit which fills the undertray.
Dec 14, 2008 | Indesit 23 in. DV62 IX Built-in Dishwasher
Kenmore Elite - Flooded bottom
this is a necht dishwasher under one year old the problem is as follows. machine switche on make the normal noises to start with after about two minutes it beeps for about twenty seconds machine then stops. The water does not seem to be coming into the machine but a small amount of water does come in at the botom of the machine ie. where the waste is. Please can you help.
Thanks
Nov 19, 2007 | Kenmore 24 in. 16302 Built-in Dishwasher
LG 24 in. LD-12BW5 Free-standing Dishwasher Logo
55 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
