Question about Xante Accel-a-Writer Laser Printer
FUSER UNIT REQ
We need to purchase a new FUSER UNIT for an Xante Accell-A-Writer and need to find the Xante UK office to purchase this. Can you help?
Rgds - Clive A
3 Suggested Answers
  • 5 Answers
SOURCE: e fuser message
http://www.xante.com/support/aw3ndn/manuals/PDF/complete.pdf
Posted on Sep 08, 2009
SOURCE: xante accel-a-writer 4g for mac OSX 10.6
I haven't checked in a while. Xante told me when I called them that they were not planning to make updates past the current version of the 4G OS X drivers, as the machine was no longer in production. They said the driver should perform adequately on current versions of OS X even though it was not initially designed for them (as they did not exist when the driver was created).
I found this to be untrue in my case. The drivers did not allow me to print consistently from 10.5.8 on an Intel Mac Pro.
My solution was to activate the print server on an Xserve running the Tiger server version of OS X, install the Xante driver there (since it was designed to run on that version of the OS), and now my newer macs can use the printer without issue.
Posted on Jul 25, 2011
Xante screenwriter 5 will not go thru the fuser when printing. Paper seems to roll there. manual does not give instructions on removing fuser and visual inspection shows no paper caught in path.
Check for media jams in the paper exit area under the fuser cover.
SEE 8-13 for diagram of fuser cover location.
http://www.xante.com/download/Legacy-Color-Products/Colour-ScreenWriter-Series/Colour-Laser-Series/ColourLaser/Manuals/Troubleshooting%20-%20English/cl_troublesh.pdf
Hopefully this is all it is other wise it may be more sinister like the fuser roller has fused together -
I have had this happen on another printer . Because I did not remove the power before I removed the fuser unit in a different model and make of printer. And fused the rollers together like melted together in the fuser. I think you would get an error code if this was the case !
Apr 10, 2018 | The Office Equipment & Supplies
Xante fuser reset fuse
That fuser is behind the cover of the fuser. Not easy to get to it, I do not recommend taking it apart unless you have a new one standing by, cause you are going to need it. Drum and transfer belt ok not so with the furser assy.
Jun 24, 2014 | Xante Office Equipment & Supplies
How do I replace a fuser for a Xante Accel-a-Writer 4G?
dear please find back cover and open it found big unit of printer called printer fuser assembly.removed it carefully you need one Philips screw driver,losses the two screw after that you removed screws slide it right side if you stand back of the printer,however after remove the fuser assembly you can installed it new in the Xante 4G printer when you install slide fuser to left side and alignment carefully,hope you understand.
thanks.
Jun 19, 2014 | Xante Accel-a-Writer 4G Laser Printer
We bought a new iMac, running MacOs 10.6. Where can I find a driver for Xante Accel-a-Writer 3N Laser Printer
Go to this link and under Drivers, English select MAC OS X and download the drivers: http://www.xante.com/support/aw3ndn/
Sadly, the application drivers for MAC OS 10.6 are mot supported for this printer.
Feb 10, 2011 | Xante Accel-a-Writer 3N Laser Printer
My Xante Accel-a-Writer is not communicating with my macmini. I understand that OSX 10.6 doesn't support appletalk, and have configured the xante as an LPD printer and entered its IP address. The mac...
First, I would recommend that you connect the Xante Accel-a-Writer to a Windows OS computer (xp/vista). Observe if it will function perfectly. This will determine whether you are doing something wrong or if the problem is from the Xante Accel-a-Writer or if they don't support each other.
You can test the Xante Accel-a-Writer on a friends windows OS computer if you don't have one.
Let me know the out come so that I can direct you further.
Good luck.
Oct 19, 2010 | Office Equipment & Supplies
I need a new toner cartridge for my Accel-a-Writer3 G. Where do I find one and how much does it cost
Try superwarehouse.com
or Xante in Mobile, AL (xante.com)
or some of the paper suppliers that supply commercial and local printers might also carry the toner.
May 11, 2010 | Xante Accel-a-Writer Laser Printer
You can probably go to the Hewlet Packard site or to Office Max or Office Depot the price varies between 113.00 to 150.00
this is depending on a refilled cartridge or a new one, This will also depend on the model and it use.
Mar 18, 2010 | Xante Accel-a-Writer Laser Printer
Screenwriter 3 Fuser Problem
go here to the 3N section, email these guys and see if they can help you.
hope this helps
thanks for your rating
Jan 08, 2008 | Xante Accel-a-Writer 3N Laser Printer
Xante Accel-a-Writer Laser Printer Logo
46 people viewed this question
Top Xante Office Equipment & Supplies Experts
Marvin
Marvin
Jose Pino
Dudeman321
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
