Question about Dryers
No heat. Vent clear and the cylinder turns. The dryer has not been in use for years but worked fine for about a week when put in use. Help!
  • 1,476 Answers
S. gregg,
You did not mention if this is a gas or electric dryer. I have a tip at http://www.fixya.com/support/r5454665-gas_electric_dryer_troubleshooting which addresses how to troubleshoot and repair both kinds of dryers and where to get the parts.
Thanks for using FixYa and for the Great rating.
hardrocko
Posted on Aug 03, 2010
Takes too long to dry clothes
You may have a clogged air vent, check that the air vent hose is not smashed, if it is not smashed, have your dryer vent cleaned professionally, all the way from where the dryer connects to the wall to where the vent leaves the home,
Recheck the dryer operation, dryer vents should be cleaned every other year for optimum performance
Feb 16, 2014 | General Electric GTDP490EDWS GE 7.0 Cu....
Too long to dry my clothes
HI,
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Jul 01, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Takes several cycles to dry
Whirlpool dryer bad heating element AGAIN
Hi Warren Fink
Try this solution to your problem
A vent clogged with lint can cause the dryer to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
Please take time to rate me
Bud
Oct 18, 2012 | Whirlpool Dryers
Thermal fuse in dryer keeps blowing out
Hi Janet Douglas
Check to make sure your vent is clear, this can cause the overheat problem and blow the thermal fuse.
Also check to make sure the blower is not full of lint also as this can cause the same problem you are having happen.
Another thought:
If the vent's clogged, that new element and thermal can burn out very quickly.
Bud
Oct 14, 2012 | Whirlpool Dryers
WHEN I TURN THE DRYER ON THE HEATING ELEMENT HEATS UP. THE GAS TURNS ON FOR 17 SECONDS THEN TURNS OFF.IN ONE MIN. THE ELEMENT HEATS UP AGAIN THE GAS TURNS ON FOR 7 SECONDS.
the most important think in a dryer is the vent that goes out side,if this is not clean the burner will keep going on and off,try this unplug the vent and then try it,if it works fine then you know its ,your vent clean vent,then put vent back on,all gas dryers have to be vented outside
Sep 12, 2010 | Dryers
GE Profile Gas Dryer - Heat goes on and off
The operating coils get hot and quit. They only cost 20 bucks. Read more about it here:
Gas dryer works then quits then works some more
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 31, 2009 | KitchenAid KGYS850LT Gas Dryer
Dryer takes longer and longer to dry
The dryer vent may be partially blocked. First of all check the outdoor end of the vent to make sure it is not covered with something, in the north snow is often the culprit. If that end is clear, pull out the dryer and disconnect the vent pipe from the dryer then check inside with a flashlight to make sure it is clear. Remove any built up lint. that should do it.
Feb 05, 2009 | Roper REX4634KQ Electric Dryer
GE Electric Dryers Automatic Cycle won't advance/turn off
check the vent probly cloged or vent hose kinked, or heater is broken.
Dec 21, 2008 | GE DPSR610GGWT Dryer
Dryers Logo
43 people viewed this question
Top Dryers Experts
Marvin
Marvin
