Question about Gateway FPD1975 19" LCD Monitor
Where do I get the PIN to disable theft mode?
  • 11,361 Answers
1999 oldsmobile cutlass computer will not communicate with car
When the motor was replaced , was the original PCM changed as well ? Did you have the anti-theft system programmed . Theft - system light on -DTC'S - diagnostic trouble codes are stored . Need a factory or professional scan tool read these codes . The other computers on the vehicle will communicate . BCM
Important: Due to component variability, the vehicle theft deterrent (VTD) system must have the learn procedure performed regardless, if the vehicle starts on the first ignition cycle after a VTD repair.
All codes in the theft deterrent module must be cleared for a relearn.
The vehicle theft deterrent system is designed in order to prevent vehicle theft by disabling the fuel injectors unless the lock cylinder is correctly engaged by a mechanical key. The theft deterrent system uses the following 4 components for theft prevention:
• The lock cylinder
• The ignition switch
• The body control module (BCM)
• The powertrain control module (PCM)
When starting the engine, the PCM searches for a password from the BCM through the Class 2 serial data circuit. If the password is not recognized or not present, the PCM will disable the engine. Two modes of tamper detection are provided:
• No password received
The engine will start and stall quickly. SECURITY telltale will flash on the instrument panel cluster (IPC) and then stay ON steady.
• Incorrect or disable password received (More than 3 invalid passwords are received)
The engine is disabled for at least 10 minutes and the SECURITY telltale will illuminate solid on the IPC during the 10 minutes.
After the vehicle has passed theft detection, the PCM will continue normal operation.
DTC B2947 Security System Sensor Power CKT Low
DTC B2948 Security System Sensor Power CKT High
DTC B2957 Security System Sensor Data Circuit Low
DTC B2958 Security System Sensor Data Circuit High
DTC B2960 Invalid Coded Key Present
DTC B3031 Key Decoder Device in Assem Learn Mode
DTC B3033 Security System Indicates Tamper
Does pin # 16 at the DLC have B+ voltage ?
Mar 07, 2018 | 1999 Oldsmobile Cutlass
Monitor message says "Theft Disable
The theft deterrence system can be disabled temporarily by unplugging the monitor's power cord. Then it will start the counter again. (The default is 60 minutes and is set in the EzTune software.) The software locks the monitor to one computer (the one running the EzTune software). To disable the theft deterrent message, enter EzTune and click on the Extras tab. Then select the Theft Deterrence section and enter the PIN. The PIN can be saved online and then you can request it if forgotten: https://pinreg.portrait.com/index.php?OEM=gwy&PRODUCT=dtune&ULANG=enu .
The EzTune software is available here: http://oem.portrait.com/dtune/gwy/enu/upgrade.html .
The user's guide and other documentation is available here: http://support.gateway.com/s/MONITOR/7005574R/7005574Rnv.shtml .
I hope this helps.
Mar 15, 2011 | Gateway FPD1975W 19" LCD Monitor
Power went off and now my gateway monitor displays GatewayWhield theft Deterrence. I never set up a password how do I fix this problem. Connect the monitor to the pc you would think fixes it but no. Help
Disable GatewayShield Theft Deterrence
  1. Launch EzTune.
    View Picture
  2. In the EzTune window, click the Plug-ins tab, and then click Theft Deterrence.
    View Picture
  3. To deactivate theft deterrence, click Disable Theft.
    View Picture
  4. Type the PIN for the monitor in the appropriate field, and then click Accept.
    View Picture
  5. A screen confirms that theft deterrence is now disabled.
    View Picture
Dec 03, 2010 | Gateway FPD1785 Monitor
How to disable anti theft mode
By opening you anti virus from setting you can change the disable the anti theft mode from max 15 min to 2 hours
Aug 11, 2010 | Acer AL1916W 19" LCD Monitor
The LCD keeps turning on and off and it give me an error Theft deferrent mode press menu but when press it turrns off againg
Im going to presume that you are not using the computer that the monitor came with.
You have two options.
1. access the utility and disable the theft deterrent by using the PIN that was entered when it was first accessed.
2. hook it up to the original computer that it was mated to and see if you can disable the "lock", but I believe you will still need the PIN.
you can find more info at the link below
Click Here
Jul 12, 2010 | Gateway FPD1975W 19" LCD Monitor
How to disabled the anti theft mode in acer monitor please solve this problem
Turn the monitor off. Hold in the menu button while powering back up. This permanently disables Anti-theft mode.
May 04, 2010 | Acer AL1916W 19" LCD Monitor
Theft disable menu pops up and won't go away and it keeps turning off my monitor
You need to install EZTUNE from Gateway, but you need to go here first:
Portrait Displays' Theft Deterrence minimizes theft or unauthorized relocation of your display. Theft Deterrence does not prevent the display from being stolen, but hinders the operation of the display once it is removed from the 'Theft Deterrence enabled' host computer.
This site is provided for you to securely store your PIN in the event you should need to retrieve it at some point in the future.
Please select from the following options.
Change your PIN. https://pinreg.portrait.com/change_p...=dtune&OEM=gwy
Forgot your PIN? https://pinreg.portrait.com/remind_p...=dtune&OEM=gwy
User manual:
http://www.retrevo.com/support/Gateway-FPD1975W-Monitors-manual/id/1071ag416/t/2/
Apr 14, 2010 | Gateway FPD1975W 19" LCD Monitor
Theft mode enabled.how i can disable it
if you press the + and - buttons on the front of the monitor at the same time for 10 seconds it disable's it. You can disable it completely by running the software disc and choosing disable Theft Lock.
Apr 15, 2009 | HP Computers & Internet
Theft Deterrance system
If you ever have this problem but cannot get to the 'extras' button, leave the computer on that (hopefully) already has the eztune software installed, pull the power on the monitor (the cord, not just press the power button) and then plug it back it...it should unlock automatically. It ticks me off that I just got off the phone with gateway tech support and they wouldnt tell me that because my monitor is 'out of warranty'...purchased 4/8/08 and problem today 7/15/09...bums. Anyway, they offered to fix for a fee. I got it fixed.
Sep 29, 2008 | Gateway FPD1975W 19" LCD Monitor
Gateway FPD1975 19" LCD Monitor Logo
63 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
