The rubber seal on the kenmore elite he 4t front loader has a rip and water spills on the floor how do i repair it.
  • 1,073 Answers
Remove the top of the dryer, the bottom assess plate the console the frount panel the fbric despenser dwawer, unbolt the door latch best to remove the door from the frount panel pull arround on the lip of the seal the part that is holding it to the frount panel
once the frount of the seal is loose from the frount panel remove the frount panel and set aside
remove the spray tube from the rubber seal center top of seal
remove rear clamp
reinstall in reverse
Posted on Apr 25, 2008
I have a kenmore elite front loader washing machine and the problem is that the rubber gasket ripped causing water leak
Nothing to do there but replace it. Call sears service with your model#, serial# and date of purchase to order one.
Nov 29, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore HE 4t Elite Front Loader Washing Machine
Inside the dispenser drawer, at the bottom there is a tab that you can push down to remove the dispenser drawer. Remove the drawer and check if the dispenser holes are clogged, this is a common cause.
Mar 22, 2008 | Kenmore Elite 45986 Front Load Washer
How do I stop my Kenmore front loader from leaking around the door. I have a Kenmore HE 2plus front loader
If this is a Kenmore FRONT LOADER you need to remove the lower toe panel directly below the door to inspect the cabinet interior for the source of your leak. The following link explains:
The most common source of leaks on a front loader is the rubber door bellow. The bellow can develop cracks, rips or tears with age and needs to replaced. The following link explains how:
If you have any questions about this repair, please let me know so that I may be able to provide you with better assistance. I hope this helps you.
Jan 31, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore HE3 will not HOLD water, drips out into the pedestal
check to see if there are any rips in the door seal,then take the bottom of the washer off you will see 3 screws holding it on. see if the water is coming out of the pump that is right behind the panel that you took off.
Dec 30, 2008 | Kenmore Elite 45986 Front Load Washer
Leaking front loader
If your washer has a rubber seal around the inside of the door and it has a little opening where the detergent comes into the washer put your hand inside the rubber piece and feel all the way around and see if you feel any holes or cracks in it and that is where it will leak from.
Dec 03, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore HE 110.4751 front load
soild metal part fits in groove around door boot spring goes in at bottom they can be tough to get back on after inserting in groove around seal you'll have to stretch the spring and pop it under at the same time band will try to come back out and roll seal back off lip..good luck
Jul 16, 2008 | Kenmore Elite 45986 Front Load Washer
Clothes got tangled with rubber seal inside and ripped it. How do I fix/get a new seal?
This part is a problem on many front-loaders and never really goes away. The rubber seal is a replaceable part and should be supplied under warranty. There is no way to fix it.You should try very hard to get Sears to pick up the labor cost as well.
Mar 14, 2008 | Kenmore Elite 45986 Front Load Washer
Tub seal has rip therefore washer is leaking.
Its pretty comlicated requires dissasembly of the front of the washer. A good tech can do in 1 hour. You may want to pay for it rather than spending all day and possibly damaging something. Let me know if you need further assistance.
Jan 24, 2008 | Kenmore Elite 45986 Front Load Washer
Front loader washing machine = black streaks on clothing
I am a recently retired engineer of 20 years once you have ruled out anything getting inside the machine by accident etc, like something in pockets or greasy overalls, then its likely to be the drum bearings, has the machine started to get noisy on the spin the drum bearings are covered by a rubber seal, this seal gets damaged or worn and water leaks into the bearings themselves washing out the grease back into the drum where the washing is, you could also notice slight water marks on the floor underneath the machine on the floor, take the back off and look for water marks coming from the drum outer casing behind the pulley, these marks will be brown and will originate from a small drain hole, if any of the above change the bearings before any real damage is done, either to the clothes or the machine, as repair can be expensive? sorry, hope i have helped you as to where to look at least,
Sep 18, 2007 | Kenmore 46462 Front Load Washer
Washing Machines Logo
104 people viewed this question
Top Washing Machines Experts
