Question about Canon PIXMA MP810 All-In-One InkJet Printer
My Cyan cartridge is producing streaky results - have cleaned and deep cleaned - still the same. Possibly related the automatic print head alignment fails. Canon PIXMA MP810
  • Canon Master
  • 6,826 Answers
Are you using genuine Cyan cartridge from Canon? or aftermarket?
Posted on Aug 03, 2010
HP Officejet 6310 will not print cyan
The Cyan print head nozzle maybe blocked.
If deep cleaning does not fix it then you need a new print head.
The cost of a new print head is expensive and it maybe better to get a new printer.
Oct 15, 2012 | HP Officejet 6310 All-In-One InkJet...
Printing colour is wrong, colours come out pink. Nozzle check indicates cyan colour is not printing. I have carried out cleaning, deep cleaning. I've cleaned the print head and finally just replaced the...
> replaced the print head
Did you replace the tri-colour ink-cartridge, or did you replace the print-head mechanism?
Are you sure that the CYAN part of the ink-cartridge is not empty?
Mar 09, 2011 | Canon i9900 InkJet Photo Printer
Canon PIXMA iP3000. I have completed a nozzle check, but have odd results... BLACK-Perfect CYAN-4 EQUALLY SPACED WHITE LINES...NO DROP OUTS PALE CYAN-PERFECT MAGENTA- 4 EQUALLY SPACED WHITE LINES...NO DROP...
Inkjet printers do not like being left unused for long periods.
Some of the color print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked print nozzles.
If none of this works then the print head needs to be replaced.
A new cartridge will not solve this problem.
NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Nov 17, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Will not print cyan
The cyan print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked cyan print nozzles. Also check the cyan cartridge, make sure it is not empty.
If none of this works then the print head needs to be replaced. NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Nov 13, 2010 | Canon I960 InkJet Photo Printer
I am running a csss system on a canon mp 190 printer.My problem is that I am getting alot of lines in my prints,this has only started recently.I have cleaned and deep cleaned many many times and I have...
Assuming you have aligned the head to produce the minimum noticeable amount of white streaks and gioven all the cleaning, deep cleaning and alignment you have done there are two conclusions.
1. If the printer has been performing OK and using the same ink supply in the CISS and the actual printed results are OK then simply continue withthe setup as is.
2. If the setup as is is producing unacceptable results then you will have to consider changing the print head for a new one.
Oct 23, 2009 | Canon Office Equipment & Supplies
Canon MX700 with new cyan cartridge very faint
The print head needs a chemical solution. You have to soak it to chemical solution to unclog it. It should be a chemical solution that is really use for print head. If it does not work, the worse thing to do is to buy a new print head.
Sep 24, 2009 | Canon MX700 Office All-In-One InkJet...
Koday Easyshare 5300 color printin problems
check first the type of paper that you are using if it is compatible in your printer
if you are connected online, try first to update your firmware, you can do that by downloading it in kodak website www.kodak.com/go/drivers, the latest version is 71.650837, then install it in your computer.
after the upgrade restart your printer, then try to calibrate then deep clean of your printhead then print demo page. if it still producing the same result or problem.
contact AIO Tech Support 1-800-421-6699
by Ebrown
Sep 24, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Canon PIXMA  MP810 All-In-One InkJet Printer Logo
392 people viewed this question
old marine
old marine
