Question about Sharp AR-5316 Advanced Digital Imager Copier
The screen is showing H and 4 - Sharp AR-5316 Advanced Digital Imager Copier
    President:
  • Sharp Master
  • 1,447 Answers
When your copier run on abnormal power or heater lamp is not on then show H4 signal is blinking.
You can reset it .
Press # interrupt 0 interrept press 14 press print key then machine ready position.
Posted on Aug 03, 2010
  • Sazeed Computer
    Sazeed Computer Aug 03, 2010
    You can reset it .
Display shows E
In my case, the screen showed an 'E' lower left of screen, and the 'Print' and '5/4' at the top of the screen. I pressed the D/# key (just below 5/4 key) and then pressed the P/NP key (not sure if I pressed them at the same time). Also pressed the D/# key and 5/4 key.
Hope this helps.
Sep 19, 2013 | Texas Instruments TI-5006 II Calculator
Partial showing on screen of numbers -- 4 shows up without upper front piece. 3/4 shows 0.15 instead of 0.75. Any ideas for how to reset screen characters?
replace the battery if this dose not solve the problem then the calculator is damaged and needs to be repaired. i however do not believe that the parts can be purchased
Mar 05, 2011 | Texas Instruments TI-25X Solar Calculator
How to change the fax speed on a CLX 3175
To Change Fax speed you must enter into Tech Mode:
Press: Menu # 1 9 3 4 OK Menu
Tech Mode / Tech Menu should now be shown on screen
Press: OK
DataSetup should now be show on screen
Press: OK
Right Arrow 4 times
Modem Speed should now be show on screen
Press: OK
Right Arrow to desired Speed
Press: OK
Press: back arrow 3 times to return to main screen
Dec 07, 2010 | Samsung CLX-3175FW Multifunction Laser...
Where is the constant factor key on a Canon P170-DH?
How to do constant multiplication or division on the Canon P170-DH calculator
This process actually requires fewer keystrokes than other calculators. Basically, just do the first problem
and then do the next items with just the next number and the EQUAL key. For example,
*** Constant Multiplication ***
2 (multiply key)
10 (= key)
(The answer 20 shows on the screen. Note, the 2 is still stored as a constant without doing anything, just continue)
4 = (shows the answer 8 on the screen)
20 = (shows the answer 40 on the screen)
100 = (shows the answer 200 on the screen)
*** Constant Division ***
10 (divided by key)
2 =
(shows the answer 5 on the screen, the 2 is still stored as a constant without doing anything, just continue)
100 = (shows the answer 50 on the screen)
500 = (shows the answer 250 on the screen)
4 = (shows the answer 2 on the screen)
Feb 26, 2010 | Canon P170-DH Calculator
When i turn my tv on 3/4 of the right side of the
The problem is most likely in the image processor area, or the backplane circuitry on the screen itself.
The service rep would be equipped to properly service your set. You should call LG to find out who in your area is able to service your set.
If the set is out of warranty it could be fairly expensive to service.
Jerry G.
Dec 16, 2009 | Samsung LN-T4671F 46 in. LCD Television
How do I expand my Tv screen
If the physical size of your screen is 4:3 the only thing it can show is a compressed version. The screen is physically not able to show the true 16:9 version. The true 16:9 HD signal has been developed to show on a screen that is twice as wide as it is long or 16:9 ratio. Your screen is almost square or 4:3 ratio. I hope this helps. Thanks for using fixya.
Dec 13, 2009 | Philips Televison & Video
Cannot find the constant key for multiplication
This process actually requires fewer keystrokes than most other calculators. Basically, just do the first problem
2 (multiply key)
10 (= key)
10 (divided by key)
2 =
Also note! There is no K visible on the screen to indicate a constant is set.
Nov 17, 2008 | Canon P170-DH Calculator
Lintrl
if it shows in the control panal in system its fine if not change in bios
Oct 30, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Processor
Not showing on the screen in the sense, is the Operating System [assuming XP] system properties window not showing the processor details? If its the case, generally some processors will have some issues with the Operating system.You can fix it by downloading some "hot fixes" from Microsoft.
Try this: 1.Open the "run" dialog box [Windows key + R] 2.Type "dxdiag" [without quotes] 3.Press enter. 4.You will be able to see the processor configuration in that window.
If not succesfull, please post. I will suggest another method.
Oct 29, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
4 Scrolling black boxes with the picture showing in the background
PIP DISPLAYED IN ALL FOUR CORNERS OF PIX. UNPLUG UNIT MOMENTARILY TO RESET. or the pip modual has failed.
Mar 16, 2008 | Televison & Video
Sharp AR-5316 Advanced Digital Imager Copier Logo
96 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
