Question about Philips 27PT6441 27" TV
No power tv loss all power while watching, fuse ok. power light on front of tv doesn't come on.
  • 138 Answers
There is a install kit 483531057673 for this model when the set is dead. The kit will contain 7404 and the Horizontal Driver Transformer 5402 along with resistors that will limit stress on 7404 and includes complete instructions
Posted on Aug 19, 2008
Power loss
plug off the power for 24 hours
Jun 09, 2008 | Hitachi UltraVision 55HDS52 Television
46LA45R RCA 46" TV does not power up following a power loss
If a power loss someone needs to open set and see if when power came back it popped the line fuse, follow power cord inside to the fuse which it goes directly to.
Dec 11, 2012 | RCA 46 46LA45RQ LCD TV
VIZIO VS470 WON'T TURN ON
do you mean the power indicator at the front panel doesn't light.ok this kind of trouble is in power supply section since the stand by doesn't work. the first place to be check is the fuse if blown. if blown with darkened color that was an indication that has other component part that get shorted. at this time you will need a proper trouble shooting using the a device like a digital or analog tester. if you don't have enough idea on how to do the job and necessary tools, just send it to the trusted service shop to fix the problem.thanks for using the fixya.
Aug 13, 2012 | Vizio VO370M LCD TV
I HAVE A 50 INCH PLASMA TV THAT WAS GIVEN TO ME WITH NO POWER PLUG OR REMOTE . I WENT AND BOUGHT A POWER PLUG ,PLUG IT IN AND NOTHING HAPPENED . DO I NEED THE REMOTE TO OPERATE THE TV ON AND OFF/
Hi
If the set doesn't power ON, what is the use with a remote control? If it power ON properly, the power indicator light at its front panel will light up. Look for this. If it doesn't, make sure that you have got a set which has to be repaired. If it does power up, just get a remote control to operate it. OK.
Jul 11, 2011 | Hitachi P50H401 50 in. Plasma HDTV
Loss of power
Check the fuse first! It is located inside TV on the PCB.
If the fuse blows again after replacing, there is a power supply circuit fault in your TV.
Mar 29, 2010 | Panasonic PV-DM2792 Triple Play 27 in....
50" vizio hdtv will not turn on and light in front not on
If TV is completely dead, no green/orange light, no any clicking sounds after you unplug it from the wall outlet and plug it back in - it is a problem with Power Board. Best case scenario - It's just a fuse that needed to be replaced. You have to remove back cover and locate fuses (1-4) on the board that power cord is attached to. You have to use multimeter to check it. If fuses are OK - next step is to replace whole power board. But before you do anything - make sure you got power out of the wall outlet and/or your power strip is in working condition.
Mar 10, 2010 | Vizio Televison & Video
My HD,panasonic tv.quit working,no sound,no video,nothing,even no pilot light "on"on the front panel,manual switch doesn`t work either,fuse is ok,what could be the problem?
That happened to my TV and it ended up being that the screen overheated and blew. Best Buy Geek Squad was going to order a new screen but replaced the TV instead.
Mar 01, 2010 | Panasonic PT-51HX41 51" Rear Projection...
Ticking sound
ticking sound (like a Watch) coming from around the Flyback Transformer but I don't see a spark is called EHT voltage . if eht voltage is ok 1 check filament is glowing or not if it is ok check voltages on crt. 2 if it is ok check luminance section in chroma section. if filament is not glowing check for low eht due to hor section check power supply output also. good luck
Sep 18, 2007 | GE 25GT270 TV
Philips 27PT6441 27" TV Logo
44 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
