Question about Microsoft Office Professional 2007 Full Version for PC
I can not run my microsoft office professional2207
  • 808 Answers
Something wrong in ur registry that doesn`t allow to run it so make ur registry clean with a authentic or legal software like reginout and then try again i hope it will work Best of luck
Posted on Aug 03, 2010
  • 415 Answers
Try this first uninstall complete office suite then download ccleaner run cleaner and reg fix then reinstall office suite and see how it goes.
(Error code: 0xE000003D) IN ONE NOTE
hey, you may follow the below steps:
Steps to Fix/Resolve/troubleshoot the error code 0xE000003D:
1 - Repair your Office app
Error Code 0xE000003D will be fixed when Office repair tool replaces all the corrupted system files. Follow the steps below to run repair tool to fix the error.
  1. Open Control Panel using Start.
  2. Click on Programs and select Programs and Features.
  3. Click on the Office product that you want to repair.
  4. Click Change.
  5. Select Quick Repair and click on Repair. If Quick Repair didn't fix the Error Code 0xE000003D, select Online Repair and click on Repair.
Note: If Office Repair did not fix this error code, then remove and reinstall the Office installation to fix this Error Code 0xE000003D.
2 - Steps to remove Office
In case if the error persists even after running Office repair tool, uninstall Office from your computer.
  1. Click on Programs and select Programs and Features.
  2. Select Office Suite and click on Remove.
Note: If Office installation failed or it didn't fix the error, a manual installation is required to completely remove the Office Suite.
3 - Steps to remove Office manually to fix the Error Code 0xE000003D
If the error code 0xE000003D is re-occurring, proceed with the following steps to manually remove Office program from your computer.
Step 1: Remove the Windows Installer packages
  1. Find the Office 16 installation folder, typically located in C:\Program Files\.
  2. Right-click the Microsoft Office 16 folder and select Delete.
Step 2: Remove the Office scheduled tasks
  1. Open a Command Prompt window as an administrator.
  2. At the command prompt, type the following commands and press Enter after each one:
schtasks.exe /delete /tn "\Microsoft\Office\Office Automatic Updates"
schtasks.exe /delete /tn "\Microsoft\Office\Office Subscription Maintenance"
schtasks.exe /delete /tn "\Microsoft\Office\Office Click To Run Service Monitor"
Step 3: Use Task Manager to end the Click-to-Run tasks
  1. Open Task Manager.
  2. Click the Process tab
  3. If the following processes are running, right-click each one, and then click End task after you select each process.
  • .exe
  • setup*.exe
Step 4: Delete the Office files
  1. Press Windows logo key + R to open the Run dialog box.
  2. In the Open box, type %ProgramFiles%, and then click OK.
  3. Delete the "Microsoft Office 16" folder.
  4. Delete the "Microsoft Office" folder.
  5. Open the Run dialog box, type %ProgramFiles(x86)%, and then click OK.
  6. Delete the "Microsoft Office" folder.
Step 5: Delete the Office registry sub keys
  1. Open Registry Editor.
  2. Delete the following registry sub keys:
  • HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\ClickToRun
  • HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\AppVISV
  • HKEY_CURRENT_USER\Software\Microsoft\Office
  • Then Delete the Office key.
Step 6: Delete the Start menu shortcuts
  2. Type %ALLUSERSPROFILE%\Microsoft\Windows\Start Menu\Programs, and then press Enter.
  3. Delete the "Microsoft Office 2016 Tools" folder.
4 - Download and install Office
1. Sign in to your My Account page using the link https://go.microsoft.com/fwlink/p/?LinkId=613327
2. Choose Install.
3. Click Run or the equivalent depending on the browser you're using.
4. When you see "You're good to go", click All done.
Error Code 0xE000003D for Microsoft Office Outlook and Windows Updates
Dec 26, 2012 | Computers & Internet
For Microsoft office 2007 home and student edition I have entered a product key which I got from the internet, it was accepted but icons are still unavailable, it cannot be activated, what can I do?
  1. http://www.mydigitallife.info/hack-to-activate-microsoft-office-2007-evaluation-trial-version/
    Run Register Editor by clicking on Start -> Run, and then type "regedit" in the Open box and press Enter key.
  2. Navigate to the following registry key:
    HKEY_LOCAL_MACHINE\Software\Microsoft\Office\12.0\Registration
    Note that inside the registry key, there should be another subkey that resembles the following:
    HKEY_LOCAL_MACHINE\Software\Microsoft\Office\12.0\Registration\{90120000-0030-0000-0000-0000000FF1CE
    or
    HKEY_LOCAL_MACHINE\Software\Microsoft\Office\12.0\Registration\{91120000-0011-0000-0000-0000000FF1CE
  3. If there is more than one registry entries or subkeys that reference Microsoft 12.0 registration, open up each subkey, and then identify the product by the ProductName value data until you locate the subkey for the product which you want to remove the existing product license key.
    For example:
    ProductName=Microsoft Office Professional Plus 2007
    ProductName=Microsoft Office Enterprise 2007
  4. Once found the correct registry subkey, delete the following values:
    DigitalProductID
    ProductID
May 15, 2011 | Microsoft Office Equipment & Supplies
Can i install microsoft office by downloading?
Yes, off course Microsoft office can be installed on your PC after downloading. I recommend you Microsoft Office 2010 and you can download it from the Microsoft office site with following URL.
http://office.microsoft.com/en-us/try/try-office-2010-FX101868838.aspx?WT.mc_id=MiG_HomePage
Have a nice day!
Aug 01, 2010 | Microsoft Office Basic Edition 2003 with...
Microsoft Power Point has disappeared from my computer. I have tried re-installing Microsoft Office 2003, but it makes no difference. My computer was bought in 2004. It runs Windows XP Home Edition.
open my computer local drive - program files - microsoft office - office 11 - look for power point if have make a shortcut on desktop if no then next step
stsrt - run in run type powerpnt.exe see if its open if no then next
clickon start - control panel- add an remove - highligh microsoft office - the clickon change - highlicght add an remove features - once you click on that if you getting various office component check mark all off tham and then clickon update or continue other wise if its prompt for installation option then clcikon microsoft office and then run all from my computer
let me knaoe the results
thanks
Mar 04, 2010 | Microsoft Office 2003 Basic Edition...
I accidently deleted microsoft office
Uninstall the Microsoft Office from the Add Remove Program's then restart ur computer & install the Microsoft office again.
Nov 06, 2009 | Microsoft Office Standard for PC
My microsoft word will not up load,but the rest of mymicrosoft loads fine
Hello
For Microsoft Office 2003, run one of the programs (Excell, etc.) Drop down menu Help->Detect and Repair>
For Office 2007
Start
All programs ->Microsoft Office->Microsoft Office Tools->MS Office Diagnostics.
Hope it helps
Aug 29, 2009 | Microsoft Windows XP Professional
Microsoft powerpoint
Microsoft PowerPoint is a presentation program developed by Microsoft. It is part of the Microsoft Office system, and runs on Microsoft Windows and the Mac OS computer operating systems. The Windows version can run on the Linux operating system, under the Wine compatibility layer.
PowerPoint is widely used by business people, educators, students, and trainers and is among the most prevalent forms of persuasive technology. Beginning with Microsoft Office 2003, Microsoft revised the branding to emphasize PowerPoint's place within the office suite, calling it Microsoft Office PowerPoint instead of just Microsoft PowerPoint. The current versions are Microsoft Office PowerPoint 2007 for Windows and 2008 for Mac.
You can learn more here:
http://en.wikipedia.org/wiki/PowerPoint
Regards
Jan 22, 2009 | Microsoft PowerPoint for PC
What are the uses of microsoft powerpoint?
Microsoft PowerPoint is a presentation program developed by Microsoft. It is part of the Microsoft Office system, and runs on Microsoft Windows and the Mac OS computer operating systems. The Windows version can run in Linux operating system, under the Wine compatibility layer.
PowerPoint is widely used by business people, educators, students, and trainers and is among the most prevalent forms of persuasive technology.Beginning with Microsoft Office 2003, Microsoft revised the branding toemphasize PowerPoint's place within the office suite, calling itMicrosoft Office PowerPoint instead of just Microsoft PowerPoint. Thecurrent versions are Microsoft Office PowerPoint 2007 for Windows and2008 for Mac.
Nov 25, 2008 | Microsoft Office Outlook 2003 for PC
Microsoft Office Trial Version and Upgrade
I bought an upgrade version and it doesn't work. What should I do?
First, please confirm you meet the qualifying criteria for an upgrade purchase. To qualify for an upgrade you must have a valid license for one of the following products: Office Standard Microsoft® Works 6.0-10; Works Suite 2000 –2007; Any Office 2000-2007 (any program or suite), Office XP (any suite) Office Small Business Microsoft® Works 6.0-10; Works Suite 2000 –2007; Any Microsoft Office 2000-2007 (any program or suite), Microsoft OfficeXP (any suite) Office Professional Microsoft® Works 6.0-10; Works Suite 2000 –2007; Any Microsoft Office 2000-2007 (any program or suite), Microsoft Office XP (any suite) Project Professional Microsoft® Office Project Professional 2000-2003; Project Standard 2000-2007 Visio Professional Microsoft® Office Visio® Professional 2000-2003; Microsoft Office Visio Standard 2000-2007 Visio Standard Microsoft® Office Visio® Standard 2000-2003; Microsoft® Office Visio® Professional 2000-2003 Live Groove Microsoft® Office Live Groove® 2003; Microsoft Works 6.0-10; Works Suite 2000 – 2007; Microsoft Office 2000–2007 (any suite), Microsoft Office XP (any suite) Publisher Microsoft® Office Publisher 2000-2003; Microsoft Publisher Deluxe 2000; Microsoft Publisher with Digital Imaging 2003; Microsoft Works 6.0-10; Works Suite 2000 – 2007; Microsoft Office 2000–2007 (any suite), Microsoft Office XP (any suite) Small Business Accounting/Office Accounting Professional Microsoft® Office Small Business Accounting®2006; Microsoft Works 6.0-10; Works Suite 2000 – 2007; Microsoft Office 2000–2007 (any suite), Microsoft Office XP (any suite)
Found here:
http://us20.trymicrosoftoffice.com/faq.aspx?culture=en-US
May 28, 2008 | Computers & Internet
Microsoft equation
Microsoft Equation is an optional component and is not automatically installed. To install Microsoft Equation, you have to run the Office Installer, and select Custom Installation. The installation wizard will present you with the optional components to install. Find Microsoft Equation, and make sure the Run this in my computer option is selected. Then continue with the installation. Office will configure itself to include the Microsoft Equation program.
Sep 21, 2007 | Microsoft Office Standard for PC
Microsoft Office Professional 2007 Full Version for PC Logo
26 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
