Question about Canon iR 2022 Printer
Canon IR2020 Disply showing "System Error E007" Kindly help me
  • 1,219 Answers
these means that the fixing film in copier fixing/heater section is worn out, and the copier is unable to recognize fixing film.
The solution is to change the fixing film - call service!
Also see the : http://www.fixya.com/support/r5454403-canon_ir2016_2020_error_codes
Posted on Aug 03, 2010
How to solve the error of canon iR2016 photocopy system error E003?
How to reset E000, E001, E003, and E007
Canon IR2016, IR2020
Enter the service mode by pressing "additional function" key, "2" and "8" keys in that order. SSSW will display. Press "OK" key.
Change Bit switch 1, bit 0 (might display as the first one on the left using number keys) status, (change 1 to 0 or 0 to 1).
Press "OK" then Press "Stop" or "Additional Function key" to end service mode or restart the machine.
Canon IR2270/IR2870/IR3570/IR4570/IR5070/IR5570/IR6070/IR6570
Enter the service mode (Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again).
Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here you can reset all error codes on by one.
Canon IC-MF6530/6550/6560/6580
No reset procedure is required, replacing the fuser is the only repair.
Canon D860 series
Press Additional Function key and the "#" key in that order. Go to Printer (number 7), select "Set", Select "Printer reset" and press "set".
Canon Printer Support Phone Number
Dec 06, 2017 | Canon Office Equipment & Supplies
Tip
How i do to eliminate code error e007 in canon ir2020
i have a code in my machine canon IR2020, and i dont now what do
on Mar 01, 2010 | Office Equipment & Supplies
How can i reset a system error E007
Good answer here:
http://www.mytechtime.com/2011/10/canon-error-e001e002-e003-e007.html
<quote>
How to reset E000, E001, E003 and E007
Press "OK" than Press "Stop" or "Additional Function key" to end service mode or restart the machine.
</quote>
Jan 20, 2015 | Canon IR2020 Copier
Canon ir2020 system error E007
For the E007.
Did you put back the green jam release lever when you replaced the film.
or did you add a printer kit.
For the E007 check if the new film is rotating in the same speed as the presure roller, check if you mounted the film sensor corectly, and if the sensor is reading the corect end of the film ( it schould be the one whit a white square on it).
Please revert me, if you need more assistance, i would be very glad to assist you more.
If you were satisfied with the solution please rate this sollution.
Thanks For using FixYa!
Vinod Kumar J
Dec 03, 2010 | Canon iR 2016i Black and White Copier
MY MACHINE IR2016J SHOWING AN ERROR MESSAGE SYSTEM ERROR E007.KINDLY LET ME ME WHAT TO DO NOW
E007-0000 ABNORMALLY LOW TEMPERATURE (detected by sub thermistor)
A fixing film sensor failure has been detected.
Fixing film rotation error
C:
Fixing film sensor failure
The fixing film sensor is faulty.
R: - Check the connector of the fixing film sensor.
- Replace the fixing film sensor.
- Replace the DC controller PCB.
if you are not a tech you should call for one to replace the faulty part.
Nov 13, 2010 | Canon iR 2016i Black and White Copier
ERROR E007- CANON IR2020, COMO SOLUCIONO??
You need a new fusing film unit or a new fusing unit
Jan 23, 2010 | Canon imageRUNNER 8500 Copier
Canon IR 2020 showing system Error E007 printer
my canon ir2020 is displaying system error E007
Jun 16, 2009 | Canon iR 2022 Printer
Error E007
 I  HAVE PROBLEM IN CANNON COPIER IR 2016, ERROR CODE E007. KINDLY HELP ME TO SOLVE THIS PROBLEM
Jan 21, 2009 | Office Equipment & Supplies
I have System error E007 problem in my Canon iR-2016 copier machine
System error e007 for canon copier ir2016j copier needs solution
May 23, 2008 | Sharp AR-M350N Copier
Canon iR-2016 System erro E007
hi how do solve this problem system error E007
Dec 04, 2007 | Canon CLC 1140 Copier
Canon iR 2022 Printer Logo
657 people viewed this question
old marine
old marine
