Question about Maytag M6Q10F2A Air Conditioner
I have new Samsung 1.5 Ton Window AC ( around one month old). Whenever AC is switched on in FAN or Cool mode the AC (probably FAn motor) make irritating Humming Noise. The noise slightly reduces after awhile. The noise level reduces when lower Fan speed is selected. This problem was not present in first few days of operation. Whether Compressor is on or off does not make any change in noise level. Noise level is same when AC is run in fan mode as well. We have contacted the manufacturer but their representative is yet to visit.
  • Maytag Master
  • 17,130 Answers
It is possible that your AC is not getting the right voltage or frequency and hence is trying to scavenge in gettting the current. It will be good if you can check on the mains voltage or on the wiring for a good 15 amp supply line. If there is any reduction or load onthe wire then the voltage can drop considerably. So in the first place kindly check this out. If this seems in order you will have to check for the fan or the compressor motor to be humming. If your cooling seems fine then you can check on the capacitor of the fan or the starter motor. I am sure since this is in warranty you must make a claim to get a free replacement. Hope you find my advice useful Good day
Posted on Aug 03, 2010
Hiiiii..... I have samsung Thermostat AC, But i dont know how to use the warmer / heater for the same. I dont know about the model number but its one of the old AC written thermostat. Now help me out how...
Symbolsin remote: To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
Jan 03, 2011 | Samsung AW1203B Air Conditioner
Our window AC/heat unit fan only buzzes when turned on- no matter whether you turn on fan only or heat or cool mode.
so the fan does not spin and blow air? it could be a stick broken fan try free spinning it make sure its turned of. if fan spins freely its probably your start capacitor which is not to expensive.
Nov 10, 2010 | LG Heat cool Window Air Conditioner
LG 8008R compressor runs one minute then fan blows 3 minutes
You need to have an AC tech come out and do some preliminary testing on this.
May 12, 2017 | LG Heat cool Window Air Conditioner
My AC unit wont blow the cold air.
if the ac outside is working, but not the furnace, means there is a control problem with the furnace, check wires in the furnace, make sure there is a blower wire plugged into the contact marked cool on the control panel of the furnace
Jul 09, 2009 | Fedders A&B Chassis A1A07W2B Air...
Ac do not drop down the tempture of room.
I have the same problem. Sounds like the unit is stuck in "Dry Mode". Dry Mode runs the compressor for short intervals (like one minute at a time). Mine is only 2 months old and worked great until a few days ago.
Jun 25, 2009 | LG Heat cool Window Air Conditioner
Samsung 1.5 ton slpit AC.the out door unit is very noisy
Check to see if the noise is coming from the fan, could be bad bearings. Replace the fan motor if that is the case. If the noise is coming from the compressor, the only other place besides the fan, then your compressor has some issues and will probably stop working soon, maybe line up for a replacement before you are left with a hot house.
Jun 11, 2009 | Fujitsu 24C1 Air Conditioner
Fan Stops blowing air
Isthis a window unit? It sounds like it. There could be a problem with your fan switch or the fan motor itself? Multi-speed motors can lose one speed at a time. It really sounds like the fan motor is bad. If the compressor starts in the cool mode, and the fan doesn't, the fan motor could be locked up. See, if you can spin the motor by hand? If you can, then something is bad within the motor. Now, if the motor has a capacitor, check for a loose or burned wire. Good luck.
May 18, 2008 | Maytag Heating & Cooling
Window AC Unit
Hi, Sitting for a year or more don't hurt them but bugs dirt and water could. Depending a lot on the size and quality of the unit, there are usually no charge ports on a window unit and the parts and tools to charge it would probably be about the price of a new unit. If the fan motor is running and the compressor is running and it wont cool, I would call around and see what someone would charge to repair the leak and recharge it. The price would be better if you delivered it to their shop for repair. If the fan runs with no compressor, probably needs a thermostat or switch. No fan, Needs a fan motor or has something blocking the fan motor from turning, stick, dirt daubers nest, whatever. In most cases though, if its not a simple fix, A new unit would probably be your best bet. Hope this helps. kstfas
Aug 27, 2007 | Fedders AEQ07FBG Air Conditioner
Maytag M6Q10F2A Air Conditioner Logo
158 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Marvin
Marvin
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
