Question about Akai Televison & Video
Vertical problem - Akai Televison & Video
    President:
  • 1,099 Answers
All plasma an lcd tv have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times reseating the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em.
Good luck.
Posted on Aug 03, 2010
Mitsubishi VS-55609 top left screen has folded over
chk for any electricity or magnetic interferanc. change the location to the TV. switch of the tv fro 5 min and restart it again back.
Jul 03, 2008 | Mitsubishi VS-55609 55" Rear Projection...
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
How do you remove vertical blinds
Vertical Blind Removal - YouTube
? 1:42
https://www.youtube.com/watch?v=DzjFN-6Ggsg
Aug 21, 2012 - Uploaded by Victory Curtains and Blinds
Vertical Blind Removal. Victory Curtains and Blinds ... How To Replace Vertical Blinds Changing Headrails ...
How to Remove and Install Vertical Blind Vanes - YouTube
? 0:44
https://www.youtube.com/watch?v=2FsauNXkRdw
Jun 10, 2013 - Uploaded by fixmyblinds
This short video will walk you through an easy way to bothremove and install the vanes on your Vertical ...
How To Replace Vertical Blinds Changing Headrails Taking ...
? 11:08
https://www.youtube.com/watch?v=XPgtms7rnQ0
Dec 15, 2015 | BrylaneHome Embossed Vertical Blinds...
Vertical lines
check the filter near vertical ic and also check the vertical ic if it is good and also check the if there is 24v supply to vertical ic.!
Feb 05, 2013 | Televison & Video
My sony tv model no. kv-ha21m80 is on standby mode & its LED is blinking four times that means it has some problem in vertical section.But when I tried to check voltages of its vertical IC AN5522
Disconnect Vertical supply and so that your Horizontal system run check all voltages before connecting vertical again ...should the protection come in again when vertical connected ...replace Vertical Ic and safety resistor in line
Apr 21, 2012 | Televison & Video
Vertical line
Most probably the vertical deflection amplifier is failing. The most common part that fails is the vertical output transistor.
The set is too old to find documentation on part numbers and descriptions. Probably the part is no longer available and you will need the assistance of someone who can help you find an equivalent transistor that will do the job.
Of course, without testing we cannot be certain the failure is the output transistor. It could be from something else such as the voltage regulator that feeds the dc line to the vertical section. Could be the vertical synchronous level that goes too low to trigger the vertical sweep generator.
Other bad parts in vertical deflection circuit though there are not that many parts that would kill the deflection entirely.
Loss of power to vertical deflection circuits. Check for blown fusable resistors/fuses and bad connections.
Loss of vertical oscillator or vertical drive signals
Good luck.
Jun 01, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
HYUNDAI COLOUR TV HCT3740 (37CM)
No vertical is always an affordable fix.
- failed (dried out) electrolytic caps in the vertical circuit
- failed vertical IC
- failed power to the vertical circuit.
Hope Ya Fix It
Feb 07, 2008 | Televison & Video
Screen only showing single line of video in center.
hi there, is the single line horizontally or vertically? if horizontal line, you do have a vertical section problem, check some parts at vertical section, the vertical ic, the power source of vertical section ie diode & resistors. ty
Dec 26, 2007 | Zenith Z32X31D 32" TV
Veltical is not open wade the hole peature
if it is not showing whole vertically means your problem is in vertical output section.
please check
  • supply to vertical output section.
  • any capacitor or low value resistor failure in vertical output section
  • loose contact in vertical output section
  • vertical output ic failure.
  • hope this will help
  • good luck.
Oct 14, 2007 | RCA 20F512T 20" TV
Televison & Video Logo
69 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
