Question about Antec Phantom 500 (PHANTOM500) 500-Watt Power Supply
Can not turn radio up and down - Antec Phantom 500 (PHANTOM500) 500-Watt Power Supply
I believed you chose the wrong product, we cant help you.
Posted on Jun 22, 2008
Horn buttons works the radio
Suspect a short circuit in the steering column wiring
Jun 20, 2016 | Cars & Trucks
Turn down the dead ky
there is a vr for turning it up and the same one turns it down
Feb 16, 2014 | Galaxy Radios DX-99V 40-Channels Base CB...
Dont know how to turn the voulume down
  • Hi, to turn the radio up or down just press the up or down arrow while in standby mode (listening) or while receiving. Let me know if you have any other questions.
  • Hope this helps.
Nov 12, 2011 | Midland LXT310 2-Way Radio
Hi, I have a LXT380/385. I find out haw to turn
I had the same issue here is the quote from the owners manual: To increase/decrease the volume level, press the up or down button during RX or STANDBY mode. With both radios on the same channel hold down the transmit or "PTT" button--this will put the other radio in the RX mode. While holding down this PTT or side button on one radio then you can adjust the volume on the other radio using the up or down arrows. (This is how you do it on RX mode. I'm not sure yet how to enter Standby mode.)
Oct 30, 2010 | Midland LXT365VP3 Two Way Radio
Antenna will not go up or down,but still has
Have the antenna motor tested re place it if not working if antenna motor is working you will need a new antenna mast and antenna cable to remove this unscrew the washer nut at the base of the antenna and turn radio on antenna should push up and play out he cable to replace insert new cable and turn radio off it will draw cable in and antenna tighten washer nut and your dne
Aug 07, 2009 | 1993 Chevrolet Corvette
Modulation with my linear
the radio you are trying to fry your amp with is driving the amp to hard. that radio has a toshiba 80 watt final inside the radio you are killing your radio with the dead key at 2 watts it causes the final to overheat and shut down because it is not built to be turned down that much. its best to turn the radio back up and use the radio.
Mar 07, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
I can't get the alarm to go off as the radio.
To turn off, hold down the mode button until the alarm/radio symbols disappear. To turn off nap, hold down nap button. Is the alarm volume controlled by the radio volume?
Oct 29, 2008 | RCA RP3711 Clock Radio
Uhf radio cb tranciever
Hello Are You using the correct antenna?,when you turn the squelch down do you hear static sound?, are you using squelch codes? if it is just a CB radio that works on Citizen Band (11 Mts) this radios does not have squelch codes.
Let me know the brand, model of the radio.
Dec 18, 2007 | Radio Communications
Motorola FV500 2 way radio can send/cant receive
Do you hear the Beeps on the speaker? Check for the QT and the code squelch are the same in both radios, try to set code squelch in "0". Make sure that the radio is not receiving or the other one is not transmiting, with two radios will see the same.
Aug 09, 2007 | Motorola FV500 2-Way Radio
Antec Phantom 500 (PHANTOM500) 500-Watt Power Supply Logo
Top Antec Computers & Internet Experts
Steven Wander
Steven Wander
Dimitar Todorov
Julie Endres
Are you an Antec Computer and Internet Expert? Answer questions, earn points and help others
