Question about Car Audio & Video
What is the unlock radio code for a 2001 buick regal LS
chiquititas
  • 1010 Answers
SOURCE: Where is the power steering fluid unit found?
It is actually on the passengers side near the engine wall the pump and reservoir are made as one You will need a flash light follow the drive belt down past the alternator to the powersteering pump look for a black lid with a yellow steering wheel on top. The whole steering system takes only 3/4 quart of dextron automatic transmission fluid so do not over fill.
Posted on Jul 06, 2008
  • 11 Answers
SOURCE: 2001 Buick radio Locked after battery change
Most likely there is an anti-theft code for the radio and you must enter that code to enable the radio. This will happen when the is battery is disconnected. If you do not know the code or the procedure for entering it consult your manual. If you do not have the manual or code you will need to have the dealer reset it for you.
Posted on Apr 10, 2009
SOURCE: i have a 1999 buick regal ls dying.
I found the problem. It was the crank position sensor. There was also a cracked vacuum hose connecting to the diaphragm on the fuel rail. Replaced both and my 92 Buick no longer dies. For the guy who's Buick was dying when using the turn signals - replace the crank position sensor. One of my symptoms of my Buick dying was when I used my turn signals. Use of turn signals places a varying load on the electrical system which messes up the crank posistion sensor if it is going bad.
Bob
Posted on Jun 09, 2009
  • 3 Answers
SOURCE: 2001 buick regal ls - mileage dash lights are out
It is your Instrument cluster, see my answers to this question and write me if you have any more questions, it cost me a total of no more than $15 dollars to fix it myself, took be about one hour.
Posted on Jan 07, 2010
SOURCE: 99 Buick Regal LS dual climate control. No heat passenger side.
the motor for the passenger side
blend door is shot
Posted on Jan 12, 2010
2001 Buick Regal LS It started running rough with wildly fluctuating RPM's while driving as well as idling. Gradually getting worse until it won't start at all.
How long since a tune-up? Any applicable trouble codes? To check codes, yourself, at the least, you need an obd2 code reader. Some of the national brand autostores will check codes for free, if there are any.
May 26, 2015 | 2001 Buick Regal
Unlock radio
if you don't know the code . Go to GM dealer for factory code. then you can put your own code after
there is no other way (it's for thiefs)
Sep 21, 2013 | 1998 Buick Regal
2001 buick regal w/ bad ignition coil and clogged catylitic conv.
Hello! The defective ignition coil more than likely contaminated the downstream O2 sensor...If there isn't a trouble code and engine performs in a normal fashion, there's no reason to change the upstream sensor...
Guru........Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Aug 03, 2010 | 2001 Buick Regal
Coolant capacity of a 2001 buick regal ls
the 2001 regal LS holds 11.7qts of coolant. hope this is what you needed, good luck. also it uses dex-cool coolant.
Mar 08, 2010 | 2001 Buick Regal
The battery was dead and the stereo is now displaying LOC. What is the procedure and codes to unlock stereo on this 2002 Buick Regal.
only the Buick dealership can fix this. they have to pull out a 6 digit code from the radio & then call Buick factory to convert this 6 digit code into a 4 digit code in order to unlock the radio.
sorry, you cant do it by yourself.
Nov 03, 2009 | 2002 Buick Regal
Need to unlock the radio in a 1998 Buick Regal
post radio chassis number and make of radio and i will try the code programme for you
Aug 04, 2009 | 2001 Buick LeSabre
Locked radio 1998 buick regal
You will need the radio code. The dealer will have to provide this information unless it is written in your owners manual.
Feb 02, 2009 | 1998 Buick Regal
1999 Buick Regal - need steps to unlock anti-theft (I have my code)
I believe it is the 3 and 5 buttons on the radio it will bring up the #'s keep pushing them until you get your code all typed in.
Oct 24, 2008 | 1999 Buick Regal
Car Audio & Video Logo
83 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
