Question about Dyson DC07 All Floors Bagless Upright Cyclonic Vacuum
My dyson is starting to blow out the dirt/dust leaving an burning smell, i've checked the belt which is fine, i've cleared all blockages, can you advise
  • 30 Answers
SOURCE: Burning smell and smoke
I ran into a scenario similar to this at work. With the burning smell and smoke combined, it leaves only one problem remaining; the motor. The motor and the pulley that enables the belt to spin could be malfunctioning (causing friction between the 2 parts) and thus causes the burning smell and the smoke. I'd highly advise not to touch either part after having the unit on (YOU WILL BURN YOURSELF).
The only other likely possibility is to make sure there aren't any hairs caught in or around the motor and the bearings of the agitator.
Posted on Mar 08, 2008
chrispurs1
  • 372 Answers
SOURCE: Dyson cut out
Hi
new motor required easy job to do go to this site for service manual.
http://dysonmanuals.llc.nu/index.htm
Posted on May 18, 2008
DAZ4161
  • 7 Answers
SOURCE: Dyson dirt collector base won't click shut--gasket?
HI,
IS THE BASE OF THE WASTE BIN ATTACHED OR HAS IT SNAPPED OFF?THE BASE OF THE WASTE BIN JUST CLIPS BACK ON THE ONE END SO THAT IT CAN SWING.IF HOWEVER THE BASE IS ATTACHED BUT WONT STAY SHUT OR LOCK THEN ITS POSSIBLE THE LATCH INSIDE THE CYCLONE HAS SNAPPED OFF.IF ANY " DIRT CHEAP " ( EXCUSE THE PUNN )SPARE PARTS AR REQUIRED THEN PLEASE FEEL FREE TO EMAIL ME DIRECT: DYSONLOGISTICS@AOL.COM
Posted on Jan 01, 2009
ButtFuzz
  • 463 Answers
SOURCE: dirt smell
If this thing has a fast-spinning belt in the "head" of the unit, you are smelling the dust that is being collected in the back of the little drive "chamber" and is being heated up by the motor and the friction of the belt. This is a pretty common thing on vacuum cleaners designed like the Oreck. If it is huge bunnies of dust, well then that means there is a leak somewhere...
Posted on Mar 11, 2009
  • 4 Answers
SOURCE: The purple cylinder on my Dyson 14 Animal vacuum smells terrible
Make sure that the filter is completely dry before you reinsert it. If not, it will mildew, emitting a horrible smell. When you clean your cylinder, you must wait for at least three to four days to make sure that it is completely dry.
Posted on May 30, 2009
Dyson dc 40 loses suction
Hello, this is Ava with Think Crucial.
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty the it. If your vacuum is still not picking up dirt after emptying the dust cup, there may be something blocking the airway. There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
Uncleaned filters may also the reason why your vacuum has lost suction. To clean the foam and felt filters, remove the dust cup and pull out the two filters that are on the top of the motor base. Rinse the filters with lukewarm water until the water is running clear. Let the filters dry fully before putting them back into the vacuum. If your vacuum is still not picking up dirt, you may need to replace it.
Unfortunately, if none of the other solutions worked, your motor is going bad. Most of the time a new motor costs as much as the vacuum itself and it is not easy to replace the motor. It may be time for a new vacuum.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Oct 20, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC29 smell since new
An electrical smell means trouble and can be dangerous. I would take it in for warranty service.
Sep 25, 2017 | Dyson DC29 Allergy Bagless Canister...
A smell like burning rubber comes out of the vents whenever it is used. It starts as soon as the vacuum is turned on. I've emptied the filter, but maybe I need a new one? I don't think the suction...
Hi sevillekathe...
The problem is that you have is that hair,strings,etc has gotten wrapped around the beater bar of the vacuum and it is trying to slow down the motor but the motor will not slow down so the smell you smell is the belt burning up because it is slippling and creating smoke and smell
You will need to remove the beater bar from the bottom of the machine and clean the hair,strings,etc from around the bearings on each end of the beater bar.
Also check your filter bag, check the hose going to the vacuum if you have one for blockages, and once you have the beater bar off check your belt condition and look for blockages going to the bag.
Please take time to rate me
Aug 30, 2011 | Dirt Devil M083405 Versa Power Stick Vac...
I HAVE A DYSON DC27 AND NOW IT IS MAKING A NOISE AND THE SUCTION IS NOT AS STRONG ANYMORE IT IS LIKE A SQUEALING NOISE
Check your belt & check for a blockage. Does it smell like anything is burning (like a stuck belt)?
Jul 29, 2011 | Dyson DC27 Bagless Upright Vacuum
When my dyson dc14 hoover is on it has a strange burning smell, and a noise like air popping, there seems to be suction from beater and it spins. and definitley suction from extension. Filters are clear...
It could be the belt. However, the popping sound does have me puzzled. The popping could be coming from a partially broken belt slapping against plastic.
Jim
Sep 09, 2010 | Vacuums
Dyson DC07 keeps cutting out and smells of
does it smell like an electrical burning smell? sounds like your motor has went bad.
Mar 06, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
The roller for my dyson does not turn and it does not pick up anything. Howevever, the hose suction is fine and I have checked all the places for dust blockages.
That means that the belt is stretched, worn or broken. You need to replace the belt. You can get replacement belts and view the manual with instructions here:
Dyson DC07 Belts and Manual
Dec 07, 2009 | Dyson DC07 All Floors Bagless Upright...
DC07 Low Reach Vacuum smells like a belt is burning and is making
The roller is likely jammed, or there is debris around the belt area
Jul 05, 2009 | Dyson DC07 Low Reach Bagless Upright...
Dirt Devil Jaguar Bagless Upright Burning Smell
take the belt off again you will see burnt rubber from the old belt stuck to the motor shaft.you can take a fine piece of emery cloth and clean the shaft down to its polished finish.always good to do this after each belt.check the brush roller and see if there are any signsd of plastic melted.make sure it turns freely if not the brush roller might be siezing uo on youhave you cleaned the hepa filter?does it smell like wires burning or rubber.with it unlugged take it apart to the motor and take a fine iece of emery cloth and go over the motor armature .then try it again.you can take all the filters out and run it without the filters.that will help you narrow it down.please leave feedback
Mar 15, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Dyson won't pick up heavier particles -
check the hose line from the base to inlet of the canister, there may be a blockage, like hair or plastic (i had a lego block and hair)
clear obstruction, and check the belt.
hope this works !
Jan 30, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 All Floors Bagless Upright Cyclonic Vacuum Logo
610 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
