Question about Canon PIXMA MP190 All-In-One InkJet Printer
Printer maintenance i can't scan and print. it says printer is in maintenance. scan after it is completed. error 2,114,0
  • Canon Master
  • 12,061 Answers
Manual Reset for Canon Pixma MPC190 Printers
  1. Enter the service mode SERVICE MODE – pressing buttons Menu, Copy, Scan, Copy, Copy
  2. Choose TEST MODE.
  3. Select 8 PRINTER TEST TEST MODE.
  4. Choose 3, EEPROM CLEAR
  5. Select 0, INK COUNT
  6. Press the Set button.
  7. Click Stop / Reset button (return to item 3), and again press the ON / OFF
Try doing this...
Posted on Aug 03, 2010
  • Canon Master
  • 6,826 Answers
Http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp190#ServiceAndSupport
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press the <ON> button. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
    Note: It may be necessary to unplug the power cord and retry if the above steps do not clear the error.
(This is for 2,113,0 error not 2,114,0 error which isn't listed.)
4 Suggested Answers
rulds2008
  • 3866 Answers
SOURCE: troubleshooting in scanning and printing
You have to reset that cart. before you fill it there should be instructions on how to do this on the refill kit you bought, you cannot just fill the cart and put it in the printer you will dmage the print head if you have not already done so. I cannot see what was done so I could not give you a solution but only tell you that the ink needs to be charged before you put it into the printer!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Apr 30, 2009
SOURCE: printer maintenance is in progress. scan after it
printer maintenance is in progress. scan after it is completes. code:2,114,0
Posted on Apr 04, 2010
  • 78 Answers
SOURCE: displaying error E and 5
The e2 error os no paper, e5 is improperly or damaged ink carts, as is the e14 error code. Make sure that there is plently of fresh paper, and replace the carts with new canon carts. If you are using refilled carts in this machine, the failure rate of this series of carts is nearly 60%. Last step to try would be to unplug the printer from power and let sit for at least 10 minutes, plug back in and power up.
Posted on Sep 29, 2010
I want to scan, but there is printing operation error. Ink has run out. And I can't scan because it says printer maintenance is in progress, scan later. Is it possible to cancel printer operation and...
Yes you can cancel the maintenance process of your printer..just do this steps 1. Click the start menu on the left side of the taskbar then click control panel 2. On the control panel click devices and printers 3.double click your printer icon 4. on the printer window right click the documents you want to be stop printing the chose cancel print.. after doing these steps you can start now scanning. that's all! hope it will help you
Jul 12, 2011 | Canon PIXMA MP160 All-In-One Printer
Displaying error E and 5 (In Blinking) and error code 2,114 while scanning........help me out of this...........thanx
Sep 29, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Hi, I need your help with this problem: the Canon MP210 ran out of color ink. I have removed both the cartridge. Anyway, the problem is not in the E5 error. The problem is, that the scanner does not work,...
The scanner and the printer are connected together.Both need initialized for printing or scanning.You can't scan if you haven't cartridges in printer and you can't print if the scanner not initialized.Put cartridges back and press and hold the resume button for 5 seconds.If you still have E5 error that mean you have a defective cartridge and you need to replaced.
Oct 19, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Troubleshooting in scanning and printing
Apr 30, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon MP210
Im going through the same exact thing and I just hooked it up. I have only printed a picture but can't scan. Any help you find will be appreciated!
May 04, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Printer message: Unable to Print
5A: encoder disc or encoder strip or main circuit board or printhead circuit board or power supply defective!
Sorry, cant be fixed by yourself!
Feb 20, 2008 | Brother MFC-440CN InkJet Printer
5A means that the purge cam stopps abnormally when it is in use. This could be of a broken cam shaft. You have to replace the whole purge unit. This is a service job to do!
Aug 27, 2007 | Brother MFC 420CN All-In-One InkJet...
Canon PIXMA MP190 All-In-One InkJet Printer Logo
480 people viewed this question
old marine
old marine
