No picture no audio - Televison & Video
    President:
  • 1,099 Answers
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
Note that you can do this if you have knowledge on basic electronics.
Hope this work......
Posted on Aug 03, 2010
I hooked up my wii on av1 with a component cable with audio on audio 1 and i have sound but no picture.
If I am reading this right, you are only hooking up one cable for audio. There is another cable needed for video. This jack is normally color coded yellow and labeled video out/in. You can use your audio cable to try this and then you will picture but no audio.
Feb 16, 2014 | Yamaha RXV371
Powers on but no picture
Does the audio stay working and just the picture goes out, or does everything drop out picture and audio?
Oct 24, 2012 | LG 42LC2D 42 in. LCD HDTV
No speaker audio Magnavox plasma TV
Re check all connections on the boards that you worked on. Make sure they are tight.
Jun 18, 2012 | Televison & Video
Hdmi audio not working when conected to tv
Follow these steps to change the audio output settings for the HDMI option.
  1. Follow steps 1 through 8 above.
  2. From the Windows Vista™ default Start menu, click Control Panel.
    View Picture
  3. In Control Panel, using the default Control Panel Home setting, click Hardware and Sound.
    View Picture
  4. In the Hardware and Sound window, under Sound click Manage audio devices.
    View Picture
  5. In the Sound dialog box, click to select Digital Output Devices (HDMI).
    View Picture
  6. Click Set Default, and then click OK
    View Picture
Note: The default audio setting for your notebook is Speakers / Headphones.
You must change the audio output back to the Speakers / Headphones option for the computer to once again be able to use the internal speakers and headphone jack.
Sep 24, 2009 | Gateway T-1620 Notebook
Audio Yes, Picture No
From your description, it could be the back light has 'gone'.
Feb 16, 2009 | Sony BRAVIA KDL-40V3000 Television
Soyo dylto32c
The DVI input on this set is meant for picture only.. ex. to display computer picture.
if you want audio with your picture. you must connect to either inputs YCBCr or YPbPr which both of those inputs has audio inputs.
Mar 19, 2008 | Soyo DYLT032C 32 in. LCD Television
There audio but no picture
I don't know how you connect the unit to the tv.
Let's just start on basic:
composite video/audio(yellow-video, white/red-audio) connect to TV composite video/audio input behind the TV.
If the audio works but no picture,try to use another video input behind the tv.if that still doesn't work,use a different video cable!
Jan 20, 2008 | Toshiba SD-V392 DVD Player/VCR
No Audio on Primary Screen
HELLO . WELL THE DIFFRENCE BETWEEN THEM IS THAT THEY ARE TUNER'S AND THEY ARE SEPRATE FROM EACH OTHER.!!! JUST LIKE THE VHS TUNER'S YOU HAVE .!!! THERE IS THE PRIMARY WITCH .!!! WOULD BE (A) AND THEN THE SECONDARY WITCH WOULD BE (B) IT SOUND'S LIKE YOU NEED TO REPLACE THE AUDIO BOARD. OR THE (IC'S) ON THE BOARD. IT WOULD BE CHEPER TO DO. IF YOU KNOW HOW.? " WELL "GOOD LUCK"
Aug 28, 2006 | Sony KP-61V75 61" Rear Projection...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
