Question about ViewSonic VA1912wb Monitor
View sonic lcd power problem - ViewSonic VA1912wb Monitor
    Problem Solver:
  • 6 Answers
My Company tossed out 3 of these, and so far I have 2 working, and expect the third to be fixed tomorrow. Bad caps are the cause, but they cause the mosfet transistors to run hot and eventually short, which takes out the fuse for the back light circuit. See the solution below complete with digi key part numbers. This is provided for personal use and not for someone to make money selling the repair. It took some time to research the parts to fix this without a schematic. I am posting it here for others to fix their monitor and keep it out of the landfill. You must know something about electronics, or you can contact me, or someone else to perform this repair. Please help yourself but be considerate at the same time. Best regards, Ryan N7QJ
Repair for Viewsonic VA1912wb-3 widescreen monitor
Symptom: Dead.
Fix: Replace the following components on PS board:
IC201, IC202: AOP605 P/N Mosfet, Digikey 785-1140-5-ND
C200, CE101, CE105: 220uF 25V Cap, Digikey P5541-ND
CE102, CE103: 1000uF 25V Cap, Digikey P5544-ND
F200: 3A Pico Fuse, Digikey F2315-ND (modify to fit by bending leads and mount on backside)
Posted on Aug 26, 2010
  • 11,361 Answers
Check the DC filter caps first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Posted on Aug 04, 2010
Sonic qasa lcd tv no power
Check and replace its main power regulator board, as card basis. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 13, 2014 | Televison & Video
View Sonic TV wont power on
If the problem is same with different input devices and you have ensured there are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 25, 2012 | ViewSonic N4060w 40 in. LCD TV
POWER ON ISSUE IN LCD
I do not know where service center is, but at least you can tell them what to look for: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA721/
Apr 01, 2010 | ViewSonic VA721 17" LCD Monitor
Need a power supply for View Sonic VX922. Where
Here is a link for your View Sonic power supply:
http://www.shopzilla.com/laptop-power-adapters/viewsonic-power-supply/9177/products
It should have a replacement for you.
Jan 30, 2010 | ViewSonic VX922 19" Monitor Flat Panel
View Sonic VA720 monitor goes out after power goes
replace the logic board, not the power supply board. you can find logic board on ebay as low as $29...
Nov 15, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
View Sonic VX910 LCD Monitor - Power Supply Board
I have been repairing them through ebay due to the fact that they are not available to buy right now.
They've been out of stock for what seems like forever !!
bammbammfran
Oct 20, 2008 | ViewSonic VX910 19" LCD Monitor
Sound on the View Sonic Monitor
Yes, they are on the front of the screen. There should be a volume up and down button right on the front (usually to the left of the power). If there isn't a separate up and down, try the Menu or 1 and 2 buttons.
Aug 18, 2008 | ViewSonic 19.0" VG910B 1280X1024 TFT LCD...
ViewSonic TV sound but no picture
I have same problem (power light is on, and I have sound, but no picture ) and found that a small capacitor on back of power supply is blown. Seems to be common problem. But viewsonic doesnt stock. Part number is b-00005352 and im trying to find one too
Jul 29, 2008 | ViewSonic N3251w 32 in. LCD HDTV
In my 15" view sonic
If you don´t have any mechanical problem with the push botons, try individually :
Power Off the monitor and press the "menu" switch, over 20 sec after the power in turned on!
v15307086
Jun 07, 2008 | Gateway FPD2275W LCD Monitor
ViewSonic VA1912wb Monitor Logo
142 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
