Question about Vizio Televison & Video
Won't turn on,it was gradual process it'll turn on and off until it warmed up.now it won't turn on.
  • Vizio Master
  • 12,061 Answers
This is a classic switchmode power supply, shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand
Posted on Aug 03, 2010
Silverado won't start without starting fluid
Check your fuel pressure it should be 60-66 psi with the key on and engine off.Sound like you might have a weak fuel pump.
Feb 13, 2013 | 1998 Chevrolet Chevrolet silverado
My Computer Kepps Turning off!
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Aug 15, 2012 | ASUS Computers & Internet
I have a 1985 mercedes 500 sl. It starts fine but when the engine is cold it has no power until 300 rpm. as the engine heats up this condition gradually goes awy. I have tested the EGR valve and it op
Friend, you have a faulty temperature sending unit. Change THAT and you'll have this problem no longer. The temp sending unit, when cold, will put the engine, by the computer, into cold start mode, the engine starts getting a bit more fuel until is warmed up, then the sending unit tells the computer it's warmed up and shuts down the cold start mode. Only makes sense, Right?
Nov 03, 2017 | Cars & Trucks
What causes the TV to go on and off when first turned on, until it warms up for 5 to 10 minutes
Try turning the volume all the way down then power the TV an see how
long it takes to bring a screen up if you still hear a popping sound then you have a bad part with a bad connection most likey a lamp and wiring.
Call to have it serviced a must if so.
Jun 08, 2012 | Mitsubishi LT-3280 32 in. LCD HDTV
When I first turn on the Toshiba projection tv the color has a strong red hue to it which clears up gradually
I would suggest when turning set on cold---turn color all the way off and examine screen as set warms up---if red to some degree but gradually becomes black and white the issue is either a "touchy" red screen control on the screen/focus block or a problem on the circuit board plugged to the bottom of the red tube.
I guess the real question is how long until it is normal?
May 20, 2012 | Toshiba Televison & Video
Hi, my swimp3 was not used for the last 2 months. I charged it up full yesterday and when plugged into the computer it plays well (i.e I can format it, change songs, actually have it "play",...
Hello nehajo88,
Thank you for contacting us. I work in the FINIS Technical Support department and would strongly recommend that you go to our support page and create a ticket so we can process you for a replacement as it seems to be a defective unit. So please visit our support page (http://www.finisinc.com/support/) and create a ticket and I will be happy to further process your case there.
Thanks!
Aug 02, 2011 | Finis Swi MP3 Player
When my 2006 FLHP gets warm the clutch doesn't fully disengage when you come to a stop I have to hold it back with the lever pulled in fully. What can I do to solve this problem.
The clutch is not releasing properly. You need to adjust the clutch. To do this, follow the clutch cable down until you find the clutch cable adjuster. It's usually covered by a rubber bellows cover to protect it. Slide the cover up or down exposing the adjuster. Loosen the lock nut and turn the adjuster barrel inwards getting as much slack in the cable as you can. Then stand the bike up fairly straight by putting a block under the kick stand. Make sure the bike is stable and won't fall over. Remove the derby cover. In the center of the clutch assembly you'll see an adjuster. Loosen the lock nut and turn the center screw inwards just until you feel a resistance. Do not force the screw. If you do so, you'll damage your inner clutch hub. If necessary back the screw out and back in until you feel the resistance several times until you get the "feel" for what you're doing. Once you get to the point of resistance, turn the screw back out 1/2 turn and lock the lock nut down. Replace the derby cover. Now, go back to the cable adjuster and turn the adjust barrel out until you have about 1/8 inch of free play at the pivot point of the lever. Squeeze the lever a few times and recheck the free play. Lock the lock nut and replace the protective cover. This should solve the problem.
Good Luck
Steve
Jul 03, 2011 | Harley Davidson FLHT Electra Glide...
Bike wwould not run today without choke pulled all the way out. yesterday much colder choke only half out then pushed in when warm....bike did sit for 5 yrs. added seafoam and 92 octane fuel yesterday...
You are correct, the mixture needs altering.
Start up with the choke in position were it will start, run a few minutes to warm up engine.
Turn mixture screw all the way in, don't screw hard in (Gentle) could damage screw seating, listen to engine when it starts to faulter gradually turn screw out, listening to the engine sound till she is running smooth on tickover. Reve up quick shut down on throttle, and if setup correctly should return to tick over without stopping. Lucky person.
May 26, 2011 | 2005 Triumph Triumph Bonneville
How to change the 'Contrast' and 'Brightness' on the monitor screen
Bootup your computer and display your Windows Desktop. Make sure yourmonitor stays on for at least half an hour before you begin, so that itis properly warmed up.
Seta pure black image on the monitor so you can adjust the brightness. Toget a pure black image, do the following: Choose Start, then ControlPanel, then Display. This will open the Display Properties dialog box.Click the down arrow next to the representation of the desktop color inthe Color field. Choose black from the color palette, then click OK.
Maximizethe Brightness control on your monitor, then slowly reduce it until theblack of the image perfectly matches the black at the edge of thephysical screen. This puts the brightness at the proper setting.
Open a screen with a plain white background soyou can adjust the contrast. One of the best ways to do this is to open aword-processing document without any text in it. Gradually reduce the contrastsetting of your monitor until the white area of the screen begins to lookslightly gray or off-white. Then gradually increase the contrast until thewhite area on your monitor is pure white. This will give you the proper whitebalance. Now you've got your monitor ready for peak performance.
Hope this may help you solve your problem.
Nov 12, 2010 | Computers & Internet
Hi i just replaced my evap fan in my amana mod bbi20tpsw i have 120 v at the motor leads until i hook up the motor then the voltage drops to 9 v
Replace the defrost thermostat , not the motor . The defrost thermostat ( bimetal ) sends power to the fan motor when bimetal is cold ( 35 degrees maybe ) . When first plugged in , the compressor cools the coils until the bimetal clicks on . Then the fan comes on , blowing cold air into the fridge . If the fan came on when first plugged in , it would blow warm air , gradually getting colder . Amana is the only brand using this process of coolant .
Sep 02, 2009 | Amana Refrigerators
Televison & Video Logo
59 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
