I have a F&P Smartdrive excellence 7.5kg when turned on the water stops and starts then the machine stops and continuously beeps. the lights that stay on are the 3rd, 5th, 7th and 8th on the wash progress display
  • Anonymous Mar 21, 2014
    The 5th n 8th light keeps coming up n beeping
  • 343 Answers
The machine has diagnosed that the 'out of balance' switch needs to be checked...It may be wiring, but most likely the oob switch has failed or the connections have become 'dry'..
The oob switch is situated under the motor controller module.
A very simple job for a tech.
Good luck....Nomess
Posted on Aug 03, 2010
My F&P Smartdrive 9 Excellence 5.5 GW509R will not start water fill.
no power to turn on the tap solenoid
could be a problem water lever control or program board
call in a technician for a proper diagnosis and quote
Aug 14, 2016 | Washing Machines
Hello. Recently my fisher &PAkel smart drive 703 was removed from its connections as we renovated our laundry. When it was reconnected by our tiler, it stopped working properly. This is what hap
Need to know the error code to help you. When it beeps, take note of the top row of lights & count from right to left. Tell me exactly which lights are on & which are off. Also, tell me if any other lights are blinking. The only thing the tiler would of disconnected are the inlet water hoses. Check that the hose from the cold tap is on the cold inlet & hot tap is on the hot inlet. Marked C & H on back of panel.
Mar 06, 2017 | Fisher and Paykel Washing Machines
I have a Fisher and Paykel Smartdrive 9 washing machine that won't fill. It starts then stops and continues to do so, then stops altogether and beeps. Can anyone help??
The error code is displayed when its beeping.
I don't know the error code, so It can only be three things,
Out of balance switch,Lid magnetic reed switch,Or Rotor position sensor,Your error code would help me work out witch one of these are faulty. to work out your error code look at picture below.
Add up the lights that are on.
Jan 08, 2013 | Fisher and Paykel Washing Machines
Washing machine doesnt work kelvinator smartdrive 085 0.5kg
you have to check 1- water pressure switch (wps) , 2- the hose which fixed between wps and drum may disconnected or broken.
Jun 12, 2017 | Kelvinator Washing Machines
My fisher & paykel 7.5 kg excellence smart drive doesn't spin
Check the out of balance switch (under the larger Grey board)
for corrosion on the terminals and replace if faulty.
Jul 03, 2012 | Fisher and Paykel Washing Machines
Fisher Paykel washing machine Smartdrive 703 Advance, Power and Start buttons are non responsive when pushed. Is there a part that can fix this. Does the control panel have to be replaced?
Fisher & Paykel Smart Drive beeps and stops during rinse cycle. If I hit pause and wait and restart it eventually continues. It seems like it has problems detecting water level.
Apr 13, 2011 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel Frigidaire Excellence 7.5 clothes washer Model: GW709NZ Ser:NPL579002 the clothes washer starts as normal, water runs for approximately ten seconds and then stops, runs for two to...
May be one of the fill valves are not opening when it is calling for either cold or hot water. Have the solenoids checked with an ohm meter
Feb 26, 2011 | Washing Machines
Fisher & paykel GW 703-U water flow and the engine sounded choked
sounds like out of balance switch is faulty. does the water start stop start stop then machine beeps. if it does it is most likely out of balance switch.please reply 4 more help
Mar 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
261 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
