Question about LG WD-1280FHD Front Load Washer
Error code de - LG WD-1280FHD Front Load Washer
    President:
  • 1,554 Answers
The code means the main control board (PWB) detected that the door is open when the machine is started or while it is running. It may indicate a loose connection between main control board and door lock/switch assembly, the door is not all the way closed, or the door lock/switch assembly is faulty.
Make sure the door is closed firmly and the machine is not overloaded which may cause the load to push the door and cause the intermittent deactivation of the door lock/switch assembly. Check to make that the wire harness connecting the door lock/switch assembly and the main control board is intact and fully inserted to both. You need to take the panel off to access the main control board in the left rear side of the cabinet. The door lock/switch assembly can be accessed by removing the spring clamp that is securing the door seal to the outer lip of the door opening. Once it is removed, peel off the part of the door seal near the door lock/switch assembly to gain access to it.
Remove the screws securing the door lock/switch assembly to the front panel then take it out of the cabinet. The door lock/switch assembly connection can now be checked or replaced if no issue is found in the troubleshooting outlined above. Simply connect the new door lock/switch assembly and secure it back into position. Put the door seal back over the outer lip of the door opening and secure it with the spring clamp.
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You can continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Aug 03, 2010
What is the error D3
I think that should be a "DE" error code. On LG machines the DE error code is for a "Door Open Error".
Check the condition of the door lock, door hook and switch as this will give the error code above, the switch can be checked with a multimeter for condition. You might need to replace the door hook or the internally mounted switch.
May 25, 2014 | LG WM-2077C Front Load Washer
Sc 536 error code
Ol? tudo bem! o erro funcional (SC 536) trata-se de um cooler ou do sensor de temperatura que parou de funcionar levando o sistema a parar de funcionar por medida de seguran?a, infelizmente trata-se de um daqueles problemas que s? a autorizada resolve.
Jan 14, 2013 | Ricoh Toner for Aficio 1060, 1075, 2051,...
De error code
DE is a drain error
Check to be sure the drain filter is clear.
Nov 30, 2012 | LG WM-2277HW Front Load Washer
What is the code " de" for?
I'm going to assume you meant DL error code because there is no DE error code for this model, If you have anymore questions please feel freeto ask, Rich
Jan 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Canon IR1510 error E000
there is a problem in the fixing assembly something to do with the thermoswitch if i am not mistaken without the full error code it is hard to say exactly what is wrong with it
Jun 10, 2010 | Canon imageRUNNER 2000 Copier
LG WM-2277HW Front Load error code dE
de error code means the door is open. If code does not clear when door shut then could be door interlock or main pcb fault
Oct 24, 2009 | LG WM-2277HW Front Load Washer
Getting error 0xc18a0206
Aquí es el contenido de la charla, espero que te ayuda también! Christina es la persona de soporte técnico.
Cristina: Vamos a realizar algunos pasos para aislar el problema y encontrar una solución para ello.
Christina: Por favor siga los siguientes pasos y que me haga saber el mensaje que se mostrará en la impresora.
Christina: A. - Mantenga pulsado el "*" tecla.
B. - Presione la tecla "#" y suelte ambas teclas.
La pantalla debe decir "Intro Especial clave Combo"
C. - Presione y suelte en la secuencia de "1", "2" y "3" botones.
CustomerName: ok
CustomerName: pantalla dice "apoyar" R0631M
Christina: Fine.
Christina: 2. Oprima y suelte el botón de flecha derecha hasta que la pantalla dice "Menú de configuración del sistema".
Christina: 3. Oprima y suelte el botón "Aceptar".
Christina: 4. La pantalla debe decir "estado de error de hardware". Si no existe ya, tecla de flecha a "estado de error de hardware",
Christina: 5. Oprima y suelte el botón "Aceptar".
Christina: 6. La pantalla debe decir "estado de error de hardware: Despejado. Pulse OK para borrar ".
CustomerName: yup
Christina: 7. Oprima y suelte el botón "Aceptar". Mensaje a los cambios "estado de error de hardware Resueltos. Pulse Cancelar para continuar ".
CustomerName: ok
Christina: 8. Pulse y suelte el botón "Cancelar" tantas veces como sea necesario, de modo que, o bien el "Bienvenido a Photosmart Express" aparece la pantalla, o, el "fallo del sistema de tinta" aparece la pantalla. POR FAVOR, NO intente imprimir en esta etapa.
CustomerName: ok
Christina: 9. Utilizando el botón de encendido, apague la unidad y desenchufe el cable de alimentación de la parte posterior de la impresora y la pared.
CustomerName: hacer
Christina: Fine.
Christina: 10. Espere 30 segundos para obtener el poder de vertido y, a continuación, enchufe el cable en la toma de corriente y, a continuación, en la parte posterior de la impresora
CustomerName: hacer
Christina: 11. Encender la unidad. La impresora puede mostrar mensaje "BOTóN PARA PODER UTILIZAR LA IMPRESORA SHUTDOWN" seguido de "Pulse OK para continuar". Pulse Aceptar. La impresora comenzará la "TEMNE UNA TINTA proceso de inicialización". Permitir que este proceso para completar y no interrumpir. Una vez que el proceso de inicialización se ha completado, la impresora imprimirá una página de diagnóstico.
CustomerName: hizo una buncha ruido, y no imprimir una página de diagnóstico
Christina: Bueno.
Christina: ¿Es todavía el mensaje de error que se muestra en la impresora?
CustomerName: No
Christina: Bueno.
CustomerName: debo intentar imprimir algo?
Cristina: Vamos a imprimir una página de prueba libre, para comprobar la funcionalidad de la impresora.
Christina: Pulse sobre el menú de configuración "todo en uno" luego desplazarse utilizando la tecla de flecha y seleccione la opción Imprimir a continuación, seleccione Informe de Autoevaluación Informe de ensayo.
Oct 22, 2008 | HP Photosmart C5180 All-In-One InkJet...
Cuales son tus fuentes?
Primero que nada, muchas gracias por tu pregunta y por darme la oportunidad de despejar (o ampliar) una duda tuya.
Cuando en un modelo de hardware dice que es la Serie 5100, significa que hay mas "subseries" de modelos en esa misma base de hardware, digamos que la 5100 es la básica y la 5160 la tienes tu y tiene un puerto de USB cuando la 5120 no la tiene. Es un ejemplo.
Otro, en cuanto a laptops HP. La serie Pavilion dv8000 tiene varios modelos, la dv8360 tiene 512 MB de RAM mientras que la dv8600 tiene 2GB y cuenta con bluetooth.
Las placas de hardware son una base para crear mas modelos, le quitan o le aumentan algo, pero fisicamente son similares.
Esto contesta tu pregunta?
Recibe un cordial saludo desde Mexico.
- CoolDragon.
Sep 10, 2008 | HP Photosmart D5160 InkJet Printer
Error code E02B05
Error Code E02D02 = Clean de coding tape behind the rubber belt.
Error Code E02B05 = Problem with de ink cartridge door.
Oct 23, 2007 | Canon imagePROGRAF W8200 InkJet Printer
Error code de
DE is a error code for your door switch. The door is not locking properly. You need to get a new door latch mechanism.
Sgt 48
Mar 29, 2007 | LG WD-1280FHD Front Load Washer
LG WD-1280FHD Front Load Washer Logo
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
