Question about Samsung S3650 Corby / S3650 Genio Touch Cell Phone
How to back up the phone data to PC - Samsung S3650 Corby / S3650 Genio Touch Cell Phone
  • 332 Answers
If your phone came with a USB data cable, plug thecord to your phone and connect to your PC via the USB port and backup your phone. It will show on your PC as a removable drive. Then you can transfer your files to your system.
Best regards
Posted on Aug 03, 2010
Will i be able to restore the backed up files saved on my lg volt after factory resetting
Yes! If you have saved your data from the LG phone externally..... Use LG PC Suite software that came with your phone, after factory resetting transfer the saved data back to your LG phone! If you have not saved the data externally you can do it with LG PC suite before factory resetting!
Jan 04, 2015 | Computers & Internet
Tip
How To Format(flash) Nokia Phones.
Formating is required only when your phone hanging,switching off automatically,forgotten the security(resets to 12345) code and when you want update your phones software.(formating delete all data including messages,contacts,etc... So i suggest you to back up all the files before formatting You can back up file using Nokia PC suit)
To back up your files
*Install the Nokia PC suit
*open Nokia PC suit >Select Back up
To restore Backed up data
*Open PC suit>Tools tab>Restore>Select Restore>select a restore point(restore point is file in which all data's are saved)>Ok and wait for 5-10 mins.
To flash you need
*USB cable compatible with your handset
*A Computer
*Nokia PC suite of your handset
*Internet connection(Min speed 1Mbps)
*Nokia software updater(you can download by using Nokia PC suit)
To flash
*Install the PC suite
*Connect to USB
*Open the PC suit
*Select UPDATE PHONE SOFTWARE(dowload the Nokia Software updater by selecting this option)
*Install the "NOKIA Software Updater"*Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
Thank you
on Jan 29, 2011 | Cell Phones
Back up information
back up means to save ur data on other devices.so if u have data that u want to back up connect ur phone to pc and using respective softwares for the corresponding phone will save all ur data and thats it
Mar 10, 2012 | Cell Phones
A general: memory full close some applications and try again appears everytime i send a message
Hi....
Try the following... *Restore your Phone once (To restore Goto Menu>Settings>Restore Factory Settings>OK(default security code is 12345)
*Clear some memory of Phone and Memory
*Scan your Phone and Memory
If problem persists you need flash your phone
(formating delete all data including messages,contacts,etc... So i suggest you to back up all the files before formatting You can back up file using Nokia PC suit) To back up your files *Install the Nokia PC suit *open Nokia PC suit >Select Back up
To restore Backed up data *Open PC suit>Tools tab>Restore>Select Restore>select a restore point(restore point is file in which all data's are saved)>Ok and wait for 5-10 mins.
To flash you need
*USB cable compatible with your handset *A Computer *Nokia PC suite of your handset *Internet connection(Min speed 1Mbps) *Nokia software updater(you can download by using Nokia PC suit)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokia Software updater by selecting this option) *Install the "NOKIA Software Updater"*Select Update**....(It takes 10-30 Mins)
I hope this helps... Thank you have a nice day
Feb 03, 2011 | Nokia E63 Cell Phone
Taking back up
When you are backing up your phone data thru Nokia PCSuite then it gives you an opportunity to select what all data from where all to be backed up. Select whatever you want.
Aug 10, 2009 | Nokia 3110 Cellular Phone
Nokia E51 - data transfer / back up problem
when u connect data cable phone ask choose option choose nokia pc suit
Jul 07, 2009 | Nokia E51 Smartphone
How to get data back in nokia E63??or are there some softwares for recovering data???
yes there is a software called "recuva" through which u can recover all your deleted data.
even those which u had long time back too.
u can download it freely from www.filehippo.com
just install it on ur or ur friend's pc/laptop and then connect ur mobile with latop/pc via cable.
its fairly easy to use ,bt look the software will ask u to where to save the recovered data,for that use any drive on the laptop for saving it otherwise all the the data wld nt b recovered.
and after recovering save it back on ur mobile phones chip.
tht's it
u r done .
Jul 06, 2009 | Nokia E63 Cell Phone
Reformat se w850i
if u can not do it urself  visit sony err. outlet for then but if want to reset ur mobile then follow the below given steps but 1st take the back up of the data
For reset
Menu>>settings>>master reset>>reset settings (default code :0000)
Gizmo1
Sep 28, 2007 | Sony Ericsson W850i Cellular Phone
Motorolla v3i
yes. there are different ways. 1. send it to your pc via bluetooth 2. if it's stored in your memory card, buy a card reader and copy it directly to your pc 3. intall motorola phone tools in your pc then using your usb cable, you can now sync files between the pc and phone hope this helps...good luck! ^_^
Aug 10, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Samsung S3650 Corby / S3650 Genio Touch Cell Phone Logo
35 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
