Question about Dell 922 All-In-One InkJet Printer
False paper jam
Says there is a paper jam and there are no jams.Tturn it on and it sounds like it is trying to pull paper through and then says "press power, then clear paper jam." I've done that and there was No paper jam! Still won't work! Plus the power light flashes and exclamation point light flashes.
  • mustang96csr Apr 26, 2008
    I turned the printer upside down and out flew two certified mail reciepts that had fallen into the printer! It had a "paper jam" after all-thank you for your help, bless you!
  • Anonymous Mar 30, 2014
    the paper jams light is on also, and when i check there no paper jam, what should i do to reset the printer
    Genius:
  • 2,035 Answers
If the paper is lodged too far into the printer and can't be removed:
Press the power button to turn the printer off.
Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
Close the front cover.
Press the power button to turn the printer back on.
Resend your document to print.
Ensure that:
The paper is a recommended paper for inkjet printers.
You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
The printer is on a flat, level surface.
The left paper guide is against the side of the paper.
You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
The left paper guide does not cause the paper to bend in the sheet feeder.
Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
Envelopes or the appropriate specialty papers are selected in the printer driver.
You are using a paper or envelope size supported by your printer.
Posted on Apr 25, 2008
Why do i have a false jam reading?
I understand that you're receiving what you believe to be a 'false' paper jam on your HP Photosmart C6280 All-in-One Printer. I would like to work with you today with resolving this issue. Paper jams can be real or false. The product might report a paper jam even when there is no jammed paper. A false paper jam may also be the result of having a bad paper jam at a point in time and that bad jam causing a hardware issue to the paper sensor or rollers. I am going to provide you with some additional troubleshooting steps that apply to both real and false paper jams. You did state that you already checked the paper pathway inside the printer and failed to find any evidence of paper being stuck, but please run the step-by-step troubleshooting below, even if you have already run some of the steps.
Here are the steps for clearing the path:
Photosmart c6280 False Paper Jam Messages
Try this blog for alternate clearing ideas for this printer. HP Photosmart C6280 error message Carriage Jam
Jul 02, 2014 | HP Photosmart C6280 Printer
False paper jam on hp laserjet 4345
Paper jam I suppose is the commonest of all printer problems as it can occur due to strayed, stuck bits of papers in pathway of paper tray, outlet, roller etc. I would recommend cleaning the paper inlet, outlet, and other possible areas to avoid a paper jam situation.
Follow the given steps to clear paper jam
>Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
->To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
->For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
->Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
->Try printing another document
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Feb 06, 2013 | Office Equipment & Supplies
Message appears "Paper jam".
Paper jams can be true or false. A false paper jam occurs when the error message displays, but no jammed paper is in the product. The following solutions apply to both true and false paper jam errors.
Print a self-test report Use the following steps to print a self-test report.
  1. Load plain white paper in the input tray.
  2. Press Setup , and then press 2 . The Print Report menu displays.
  3. Press 1 to select and print a Self-Test Report
Solution one: Clear the paper jam Step one: Remove loose paper from the tray Remove any loose sheets of paper from the input tray and the output tray.
Step two: Clear the jam from the back of the All-in-One
  1. Figure 2: Remove the rear access doorc01562020.gif
  2. Gently pull any jammed paper out of the rollers inside the product.
  3. Carefully remove any scraps of paper that are still stuck in the product.
  4. Reattach the rear access door. Insert the two posts on the right side of the door into the holes on the product, and then push the door in until it snaps into place.
  5. Reconnect the power cord to the back of the product, and then press the Power button (c01602202.gif ) to turn on the product.
Step three: Clear the jam from the front of the All-in-One Follow these steps to remove the paper jam from the front of the product.
  1. Without opening the cartridge access door, check the tray for jammed paper that you cannot remove from the back.
  2. If you see jammed paper, gently pull it out.
Step four: Print a self-test report
  • If the issue persists , continue with the next solution.
Solution two: Make sure that the carriage can move freely Follow these steps to make sure that the carriage can move freely. Step one: Check the paper path
  1. Check for any paper or object that might be stopping the carriage. Figure 4: Example of paper stuck in cartridge access areac01950807.gif
  2. Remove any paper or objects you find.
  3. Reach inside the product, and then manually move the carriage.
    • If the carriage is stuck on the right side , move the carriage to the left side of the product.
    • If the carriage is stuck on the left side , move the carriage to the right side of the product.
    • If the carriage is stuck in the middle , move the carriage to the right.
  4. Remove any paper or obstructions found.
  5. Make sure that the carriage can move freely across the width of the product by gently pushing the carriage to the left, and then to the righ
Step two: Print a self-test report
  • If the self-test report does not print , continue with the next solution.
Solution three: Clean the rollers and the rear access door Dust, paper fiber, and other debris might accumulate on the paper feed rollers and cause paper jams and paper feed issues. Follow these steps to clean the paper feed rollers inside the product. Step one: Clean the rollers
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Disconnect the power cord from the back of the product.
  3. Press in the tab on the left side of the rear access door, and then pull the door away from the product to remove it. Figure 6: Remove the rear access doorc01562020.gif
  4. Lightly dampen a clean, lint-free cloth with bottled or distilled water, and then squeeze any excess liquid from the cloth.
  5. Press the cloth against the rollers and rotate them upwards with your fingers. Apply a moderate amount of pressure to remove any dust or dirt buildup. Figure 7: Rotate the paper feed rollersc00212278.jpg
  6. Make sure that the paper feed rollers on the rear access door are clean, free of paper bits, and rotate freely.
  7. Clean the surface and the rollers of the rear access door the same way you cleaned the large rollers inside the product.
  8. Replace the rear access door. Insert the two posts on the right of the door into the holes on the product, and then push the door in until it snaps into place.
Solution four: Service the product
Aug 08, 2011 | HP PSC 1610 All-In-One InkJet Printer
I have a 18 mo old 8500 OJPro wireless that won't advance the paper, makes a clicking sound and gives a false paper jam error. I have seen a split white gear within a black clutch assembly on the left end...
Follow these steps in the order presented to resolve the paper jam. Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Remove any loose paper Do not pull jammed paper c02073375.gif c01994705.gif Step two: Clear the jam from the rear of the product CAUTION: Never pull jammed paper from the front of the product. If you can pull it from the rear of the product or the tray, always try the rear first. Pulling paper from inside the front cover can cause mechanical damage to the product.
  2. Disconnect the power cord from the rear of the product.
  3. Unplug the power cord from the wall outlet.
  4. Turn the product around so that you can access the rear side. Figure 1: The rear side of the productc01617574.gif
  5. Push in the button on either side of the two-sided printing accessory (duplexer), and then remove the duplexer. Figure 2: Remove the duplexerc02051407.gif 1 - Press the buttons on the sides of the duplexer 2 - Pull the duplexer out of product
  6. Gently remove any jammed paper or bits of torn paper from the rollers inside the product. Use both hands to pull any whole sheets of paper to avoid tearing them. Figure 3: Gently remove the jammed paperc02073376.gif CAUTION: Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure 4: Remove scraps of paperc02073377.gif
  7. If you do not see jammed paper in the rear access area, push the buttons on the latch on the rear of the duplexer, and then lower the cover. Figure 5: Open the duplexerc01617577.gif 1 - Latch on rear of the duplexer 2 - Duplexer cover
  8. Remove any jammed paper from inside the duplexer.
  9. Close the duplexer cover.
  10. Gently push the duplexer into the product until it snaps firmly into place. Do not press the buttons on the end of the accessory while you reattach it. Figure 6: Reattach the duplexerc01617578.gif
  11. Reconnect the power cord to the rear of the product.
  12. Plug the power cord back into the wall outlet.
  13. Press the Power button (c01602202.gif ) to turn on the product.
Step three: Print a self-test report Follow these steps to print a self-test report. Printing a self-test report verifies if the hardware functions correctly.
  1. Load unused, plain white paper in the input tray.
  2. Press the Power button (c01602202.gif ) to turn on the product.
  3. Press the Setup button (c01726396.gif ).
  4. Press the Right Arrow (c01185072.jpg ) to select Print Report , and then press OK .
  5. Press the Right Arrow (c01185072.jpg ) to select Self-Test Report , and then press OK . The self-test report prints.
Oct 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I had a paper jam and cleared but I still get the paper jam message. I cannot see any evidence of paper.
Where was the paper jamming at? On this model printer there are several things that could cause a jam or false jam. You paper pickup roller or sensor could be be bad, The fuser could be bad and prevent the paper from pulling thru or one of the paper ath sensors could be failing giving a false trigger. If you would like to call us at 318-769-9040 we would be glad to help you.
Corporate Computer
www.ccl-la.com
Aug 17, 2010 | HP LaserJet 4 plus Printer
HP 2575 printer - paper jam message
Resetting the product may help with some false error messages. Press power button to turn printer off, unplug the power cord, wait a few seconds, plug it back in, press power button to turn printer back on. Any luck?
Dec 13, 2009 | HP Photosmart 2575 All-In-One InkJet...
When powering up printer receive message "press power then clear paper jam" I cannot find any paper jammed in the printer
Power your printer off and unplug it. Try manually feeding a sheet of heavy weight paper (cardstock) through the paper path to help push out any torn scraps of paper left from a previous jam, or any staples or paper clips etc that may have fallen into the paper path.You may need to do this multiple times. You can also try blowing in canned air to remove and paper dust that might be laying on the sensors causing a false jam message. Good luck!
Aug 08, 2009 | Dell A940 All-In-One InkJet Printer
Says Paper Jam but ther is no paper jam
It appear from here that the exit sensor may be dirty and you can use canned air and blow it out.
You may also be missing the paper out sensor that is located at the bottom of the printer oposite of the paper tray when you pull it out. When the flag arm has fallin out, it will give a false paper jam error when the last sheet has printed from the tray, not knowing or detecting that the tray is now empty.
Jul 02, 2009 | HP LaserJet 4 plus Printer
Paper jam warning icon flashes but there is no paper jam.
Well I would take a can of air and blow off the sensors, especially where you began to have problems. The sensors (over time) become coated with paper dust and now reflect back on themselves thinking there is paper there all them time. From your description of the problem, it seems like the issue-intermitten jams/intermitten false jams, until a total false jam.
Apr 17, 2009 | Xerox 8830 Copier
Problem
Paper jams can be real or false. The all-in-one may report a paper jam when there is not any jammed paper, however, the solution to a real paper jam or a false paper jam is the same.
To fix the paper Jam errors please try the following steps:
1. Confirm that no foreign materials are inside the machine.
2. Confirm that usable paper is set.
3. Confirm that the paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
5. Disconnect the printer power cord as well as the printer cable form the printer.
6. Turn the printer upside down and shake the printer in order to remove any obstacle which is stuck inside the printer causing the paper jam error.
Open the printer cover and remove the cartridges and check carefully if there is any small piece of paper which is stuck inside, if so carefully remove it.
7. Disconnect the printer power cord and press and hold the power button on the printer for about 15 to 20 seconds( this will release the flee power) and reconnect the printer and check.
Regards
Malik Khan
Jan 26, 2008 | Canon PIXMA MP160 All-In-One Printer
Dell 922 All-In-One InkJet Printer Logo
430 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
