Question about Yamaha 2500 Watt Industrial Inverter Generator YG2800i
I have a yamaha ef600 generator. Had it running a 500watt floodlight and when i went to check, the engine still running ,but not output for a/c. Cant find a fuse etc. Looked at windings ,visually ok.
5 Suggested Answers
  • 1388 Answers
SOURCE: Suzuki SE4000SED generator with no output
There was a day and time when generators were simple. There were no capacitors, regulators to control/adjust power to magnet or ground fault outlets. Winding getting hot indicates short, however could be bad capacitors. Rectifiers and capacitors must be removed from circuit to test properly. Here is a simple test that I use to find fault area. I use a small power supply (16v AC 1 amp like doorbell transformer) into the 110v outlet of generator. This should energize the armature magnet and actually produce voltage at commutator with brushes pulled off. You can slowly pull the starter rope to move the armature into a different positon the voltage will vary. If the ac windings are shorted there will be very little or no magnet. There is a seperate 110 v circuit at the 220v outlet to test (there are two 110v windings that make up the 220v outlet, one is also used for the 110v outlet). There is another winding that products voltage for the regulator that powers the magnet thru the brushes but I think that circuit is porbably working because of the heat in the windings. You might even have 110v power at the 220v outlet. As our parents told us over and over, be careful when working with electricity. Enjoy
Posted on Dec 08, 2008
  • 24 Answers
SOURCE: No voltage output from my GA3200a generator.
needs field flashed
Posted on Sep 18, 2009
  • 340 Answers
SOURCE: Generator only outputs 6Vac. The winding measure
the cap has to be disconnected on one side to get a true readingif you remove the cap from the system and check it again and find it out of range change it
the diodes should be checked also to make sure they are working ( the current should be going in one direction only on them) last check the recdifiers to see if they are all producing if one is out the voltage will be less
Posted on Mar 15, 2010
  • 25 Answers
SOURCE: YAMAHA EF3800 GENERATOR (15 YRS OLD) POWER TOO "DIRTY" FOR ELECTRONICS
"do the Google": Line Conditioner
Posted on Apr 04, 2013
Model ef6600de. How do I decrease rpm?
Search Results
    [PDF]EF4000DE, EF5200DE, EF6600DE, YG4000D ... - Yamaha
    www.yamahamotorsports.com/assets/.../0/LIT-19626-01-15_1425.pdf
    Generator. LIT-19626-01-15. 7WV-28199-11. EF4000DE. EF5200DE. EF6600DE ...This manual will provide you with a good basic understanding of the operation and .....card listing your Yamaha model name, engine ... rpm. NO OTHER ADJUSTMENTS NEEDED. ENGINE OIL: IDLE SPEED: ..... Electric Starting Model:.
    [PDF]yamaha generator theory & diagnostics guide - Gen-Tech
    www.gen-tech.net/fullpanel/uploads/files/theory--diagnostics-guide.pdf
    Yamaha Generator Theory and Diagnostics Guide .... Conventional EF6600DE . ...models with Smart Throttle) do not rely on rpm to ... unit manages functions such as AC power modifica- ... tions means higher fuel economy at lower outputs.
    Yamaha Motor Canada :: Products :: Power Equipment ...
Dec 25, 2015 | Yamaha Electrical Supplies
Floodlights run by a generator at a football pitch are blowing up the capacitors even when the lights and generator are off ?
Blowing up capacitors where in the lights? even when off??????
Not sure of this question can you be more specific please. if you mean the gen capacitor in the alternator, it is either overloaded, or you have a short causing it to run full mfd. Don't turn off the generator with the lights on, that will also blow them
Sep 18, 2013 | Coleman Powermate Powermate 5000W...
Yamaha ef1000is was rained on, starts and runs after unplugging wire plug from generator, runs when replugged, but no electrical output
Sounds like the rectifier got fried. Moisture in these units is a dangerous thing. Even if you feel the unit sat long enough to dry ouit, it sometines will hold moisture in the electrical componants.
Jan 15, 2010 | Yamaha 1,000 Watt Portable Generator...
Onan Marquis Indiana 5000 generator
You MAY have blown the rotating diodes on the rotor.
This would require servicing.
Sep 05, 2009 | Yamaha 4500 Watt Electric Start Generator...
Yamaha 2500 Watt Industrial Inverter Generator YG2800i Logo
1,576 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
jmt
Level 1 Expert
Robert Wooley
Robert Wooley
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
