Question about Dishwashers
Water does not drain from the dishwasher. I'm suspecting a blockage or pump problem. What should i do first
    Problem Solver:
  • 11 Answers
If you have a garbage disposal take the drain off and check the end of the hose and the port on the garbage disposal for blockage. If the drain is clear then you will need to get to the bottom of the unit. on the side of the motor there is a little solenoid attached to a stainless steel rod this is what changes the valve when the pump is running to drain instead of spray. That is probably the issue
Posted on Aug 03, 2010
    Problem Solver:
  • 18 Answers
You will need to remove the pipe from the pump to see if there is a blockage first, if no blockage a new pump should do the trick, I have had this happen twice to me and a new pump fitted by me done the trick.
Lights 2+4 flashing on dishwasher & won't drain
Doe the pump make a sound as if it's trying to pump out? As it sounds as though your pump is either obstructed, or the outlet waste water pipe from back outside of the dishwasher to the drain, maybe bent somewhere or blocked & not allowing water to exit the dishwasher, if both are clear of blockages & no noise of the pump kicking in to empty the dishwasher then I would definitely say the pump has failed...
I hope this helps....
Feb 22, 2018 | Dishwashers
Dishwasher completes programme but does not pump water away
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Feb 13, 2011 | Bosch Dishwashers
I bought my bosch dishwasher just over a year ago and it is not working at the moment because there a red light on the say to check water
flow sesor problem, blockage in drain pump, or a leak all will cause check water light to come on i suspect a blockage as your appliance is new.
Jan 09, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
WATER WILL NOT DRAIN OUT
Sounds like either you have a blockage in the drain pump or the drain hose is blocked.
The washing machine will run the drain pump for about 2 to 3 minutes to empty water from the drum then stop automatically.
If the pump is blocked or the drain hose blocked or kinked then water will be left in the drum.
Blockages are usually caused by buttons, bra wires or metal objects from pockets eg coins.
The pump can be popped open using simple tools ie screwdriver and any obstruction removed easily. The drain hose can be detached and a metal object eg knife dropped through to test for a blockage.hope this helps
Jun 01, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
My dishwasher will not drain
Check drain hose first.
If you do not find any blockage, then you will need to access the pump, remove pump hose and look for blockage in there.
If there is no blockage at all, then either the water level switch, a faulty pump, a wiring problem, or a faulty timer board can be cause the machine not draining.
Apr 27, 2009 | GE Adora GHDA654LBG Dishwasher
Water is not draining
Apr 08, 2009 | GE 24 in. GSD1000G Built-in Dishwasher
My dishwasher doesnt drain water or wash the dishes in the dishwasher.
Water not draining - sounds like a blockage (food content)
Does not wash - - I suspect there is some LOGIC in the dishwasher that knows that it can not drain - therefor will not fill with more water until that problem is resolved..
Good luck
Aug 17, 2008 | Dishwashers
Bosch classixx dishwasher not draining
try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
Feb 23, 2008 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Dishwasher doesn't drain
suspect not draining properly all the time. if plumbed into the trap under the sink, then check there is no blockage there. (quite common) . hold drain pump into a bucket so you can see the rate of flow. hold the bucket about 3ft off the floor. if poor flow, then you either have a blockage at the pump or the pump is faulty
Apr 30, 2007 | Frigidaire 24 in. FDB635RF Built-in...
Dishwashers Logo
50 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
