Question about Kitchen Ranges
Fan assisted oven does not get to temperature set. There is some heat but it is minimal regardless of temp set.
  • 24 Answers
Heating element possibly going out
Posted on Aug 03, 2010
Motor working sound when our new Frigidaire electric range is heating to selected temperature. Is this normal?
some fan assisted ovens turn on the fan to get up to temperature, its an energy efficiency thing, also mean pre heat is quicker. if you need more info on this unit here is web page
http://www.frigidaire.com/Owner-Center/Product-Support--Manuals/?productCode=LGEF3045KF
hope this helps you.
Jun 11, 2017 | Frigidaire Kitchen Ranges
Fan assisted oven not heating to correct temp
Assuming the fan is working, then are a couple of possibilities.
1- the oven element is not working.
2-the themostat or regulator is not controlling the temperature properly.
If you put your hand in front of the blower fan, you should feel hot air blowing, if you can't, then it is probably the oven element that has failed.
This is located at the rear of the oven compartment behind a removeable cover.
Hope this helps.
Jan 04, 2010 | Baumatic Ovens
Got a fan assisted gas oven. Trying to bake a cake
Temperature control with gas ovens is not an exact science. However the control should be better than you say.
Have you tried reducing the set temperature to compensate for the 'overshoot'. It may be worth a try.
Jan 04, 2010 | Ariston Technologies Ovens
Stoves new home fan assisted oven. do you reduce heating time and or temperature
It is usual to reduce temp and or time for a fan assisted oven, as opposed to a conventional convection oven.
Please rate my solution.
Thanks.
Nov 24, 2009 | Stoves Ovens
Oven heats up very slowly
That usually means that you have either a faulty temperature probe , or a faulty oven control.
The oven is probably fan assisted, also check that the fan is coming on.
Aug 09, 2009 | Frigidaire FGF378AC Gas Kitchen Range
Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Jul 08, 2008 | Ovens
    NEFF Oven Model B1430NOGB/02 Oven Temp not heating above @50 degrees
    probably the element. to save wasting money, check continuity with a multimeter
    Jun 25, 2008 | GE Profile JT912 Electric Single Oven
    Temp display shows 444
    If everything on your B1691N0GB oven seems to be working, i.e. all the lights are on and fan comes on in fan oven setting, but there is no heat from fan oven, conventional oven or grill, try turning your oven off at the mains, then turn on again. If the temperature display then shows 444, your oven is locked. To unlock, make sure the central control knob is in the "out" position, then press the fan oven and light buttons simultaneously for 10 seconds or so, until 333 appears on the display. Your oven is now unlocked.
    Apr 08, 2008 | Neff B1641 Single circotherm super...
    Kitchen Ranges Logo
    80 people viewed this question
    Top Kitchen Ranges Experts
    Oloyede Monsuru
    Marvin
    Marvin
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
