Question about Samsung LN-T5271F 52 in. LCD Television
My Lexus 37inch tv takes 30mins to come on
My Lexus 37inch TV takes 30mins to come on, I only had from new 3yrs.
    President:
  • 1,099 Answers
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Posted on Aug 03, 2010
The on/off switch doesn't work on our 37inch Panasonic plasma tv
There should be some fault with its main power supply regulator board. Check it. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Feb 05, 2013 | Panasonic Viera TH-42PX80U Plasma TV
I have a LG 32LG3000 LCD TV and the power light continually flashed red and the tv does not turn on.
Tries tv unplug,replug it back like about an hour later.See,if the tv will resetting self and working again.Not.The tv power supply board it is the causes and the problems.That the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Sep 06, 2011 | LG 32LG30 32 in. LCD HDTV
My son hit our 37inch LG flat screen TV with a
THE SCREEN WILL COST YOU AT LEAST 80% OF WHAT YOU PAID FOR THE TV, MAY BE MORE COST EFFECTIVE TO BUY A NEW ONE
Dec 30, 2009 | Samsung PS50A466 50 in. Plasma HDTV-Ready
Missing or weak signal
try a outdoor antenna on the roof for digital signal use.also the main digital PCB is defective which has the tuner on it if the antenna does not work.you may try taking the
tv to a friends house and see if the tv works better.
Sep 04, 2009 | JVC LT37X787 37 in. HDTV LCD Television
Orion 42inch plasma screen tv problem
most likely a bad Plasma Display Panel. Costs more than a new TV
Jul 22, 2009 | Televison & Video
37inch Vizio TV making buzzing sound from back
my tv is new too and also makes a buzzing sound and i turned the DCR off and it worked to thanks for the help!!
Jan 03, 2009 | Vizio L37 Television
GE D52GW12 52 in. Rear...
You need a new replacement flyback. They cost about 50 dollars at the following link , and they provide free tech support so you can do the repair yourself which takes about 30 minutes from start to finish and requires only basic soldering skills. Heres the link.
http://servicemanuals.vstore.ca/
May 16, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
Bush 37inch HDMI
I've ran into this before and all that was wrong was the RCA hookups from my dvd player. The colors are very similar and I found it by unplugging one jack at a time and the buzz stopped when I found it.
Hope that's your only problem,
SkipofSaturn
Dec 17, 2007 | Philips 25PS40S 25" TV
SANYO 37 INCH TV
Check for cold or crystalized solder joints on the board that is connected to the CRT.
I would also check the solder joints around the high power resistors near or around the horizontal section.
Good Luck.
Oct 13, 2007 | Sanyo AVM-3659S 36" TV
Samsung LN-T5271F 52 in. LCD Television Logo
49 people viewed this question
Jerry Greenberg
Jerry Greenberg
