Question about LG L1730S 17" LCD Monitor
Lcd is not on the connect power cable
Moniter not on
  • 11,361 Answers
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Posted on Aug 04, 2010
I have lg flatron l1730s lcd black color monitor. I have problem with this. Power not come. some time when i connect it power LED blinking once then no display. Some time when i connect it power LED...
Oct 14, 2010 | LG L1730S 17" LCD Monitor
The moniter blacked out, blue light is saying the moniter is still on, but screen looks like there is no power. When you turn on the moniter, the screen shows up for a few seconds, then blacks out again!...
Unplug power. Unplug VGA cable. Remove back of monitor. (four small Philips headed screws along the bottom rear. Remove screws attaching Monitor to it's base. Carefully, lean the screen away from back of case. Gently unplug 25 pin cable from the screen.
Connect AC power.
Screen should power on Gray to White. Ble light comes on Blue.Flickers then changes to Amber.
Reconnect VGA cable. Monitor should work.
Close up the monitor in reverse order to opening it.
If these steps don't solve your monitor, consider replacing as cost of repairs may shock you.
Sep 09, 2010 | Proview PL926WBi 19" LCD Monitor
I have an HP Pavilon, Laptop and an Acer Monito
you can buy a lcd cable to connect your laptop and your acer moniter.
if your moniter is a crt then no need to buy you can use the default cable.
if its a lcd the cable is given in that package. you can use it.
you can see a vga port in your laptop with blue colour that is the connector for moniter and your laptop
Jul 14, 2009 | Acer AL1721 17" Flat Panel LCD Monitor
No power to moniter
This kind of problem needs an isolation. Please try the steps below:
1. Check the physical connection and make sure that the power cable is properly seated to the monitor.
2. Connect the monitor into different power outlet.
3. Try using different power cable.
Otherwise, you need to bring your monitor to the repair shop if none of the steps help.
Have a great day!
May 09, 2009 | HP L1702 17" LCD Monitor
Moniter very lightly flashing
Problem was not solved. I am returning to Samsung. Thanks.
Jan 05, 2009 | X2Gen MG19MY 19" LCD Monitor
Screen black
Take the post (power on self test) disconnect vga cable and connect power cable if monitor shows no signal check signal cable massage then monitor is ok fault is in cpu. open it and clean the dust
by vaccum cleaner you will get the display again
Oct 17, 2008 | X2Gen MG19MY 19" LCD Monitor
Mark in lcd so i want to view in vga other moniter which cable i should i use
connect through the vga port of your laptop to the monitor, the cable is present on the monitor itself
Oct 06, 2008 | Sony VAIO SRX99 Notebook
Using lcd tv as pc moniter
What model tv are you using.
Aug 07, 2008 | Televison & Video
Power Supply cord
The power cord plugs into the end of the connector that plugs into the PC.
Nov 04, 2007 | Proview PL456s 14" Flat Panel LCD Monitor
Moniter Vga cable
You need a vga to dvi cable, your local PC shop should be able to help.
Oct 06, 2007 | Gateway FPD2275W LCD Monitor
LG L1730S 17" LCD Monitor Logo
53 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
