Question about Intel D845PESV Motherboard
No beeps, no video, fans working,
I have Intel D845 PESV, when connected to mains powers up immediatelly (do not need press ON button) no beeps, no video, fans working. Removed RAM - get 3 beeps. CPU heating up as should. Green power indicator on the motherboard is ON, HDD turning, floppy disk drive light is ON (but it just could be indication that floppy drive is faulty),
    Sergeant:
  • 191 Answers
No the floppy disk is not faulty, it is normal and required that the floppy disk drive light blink to indicate that the drive is working. And about the power on the power button might be stuck inside that is why it keeps turning on immediately you connect to main power
Posted on Aug 03, 2010
Switch on problem no processor running
845gvsr no display given ram beep but ram ;ram ic and bios is ok what can i do sir
Jul 27, 2009 | Intel D845GVSR Motherboard
Hi i have a intel D845 PESV motherboard
hi im josh in cebu phils.may i help you? Friend try to read these.ths may help you.
Your PC uses beeps to communicate with you when something is wrong with the video setup. Check the settings on your video card to make sure that they're correct for your system. Also check any switches on the motherboard to make sure that they're set up correctly for your type of video card. (You should consult your system's instruction manual for details on this procedure.) Check to make sure that your video card is seated properly in its slot; you may even want to try inserting the card in another slot. If none of these suggestions works, try a new video card, or have your system examined by a professional.
In a pre-Windows 98, system, if you have two video cards installed at the same time, they can sometimes interfere with each other and cause neither to work properly. Try removing one of the cards; if this results in the remaining card working, you need to reconfigure one or both of the cards to better work together. (With Windows 98 and later you can install two video
Remember these points when you have a video-related problem:
  • Most display problems are caused by video card/monitor mismatches, bad or outdated display drivers, or improperly connected cables.
  • One good way to determine whether a video problem is card-related or monitor related is to connect a different monitor to your system. If the new monitor works fine, the problem is in your old monitor; if it doesn't, the problem is with your video card.
  • Most video card–related problems will manifest themselves before Windows launches.
  • Most driver-related problems will manifest themselves after Windows launches. good luck.
Mar 04, 2009 | Intel D845PESV Motherboard
No Dispaly Intel D845 GLLY
check the all power cable. change the motherboard battery. remove the ram, agp, then add togther. change the power supply.
Jan 23, 2009 | Intel Desktop Board D845GLLY Motherboard
Desktop won't start.
Try to replace the power supply with another known working power supply from another P4 desktop and then reconnect your wires from the front panel led lights, changing them around until they are in the correct position. I had an almost similar problem and I did the above, it is working now. All the best ! sirjohn
Oct 13, 2008 | Intel Desktop Board D845WN Motherboard
Moterboard problem...............
hi buddy!
1. check the monitor if working normal & the wire
2. check the video card also and try to clean
3. check the ide cable or sata connected to the HDD
4. try to chance another cd-rom or use a paper clip to open a emergency eject button, you see to your cd-rom have a small hole ok thnx
PS:
pls rate me if my solution solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Jun 24, 2008 | Intel Motherboard
Intel 845 gvsr no display
Intel d845 gvsr no display ,but the ram is ok when i incerted the ram there is no beep and there is no sound. may be bios corupted and how to solve the problem
Mar 09, 2008 | Intel Motherboard
Intel D845PESV Motherboard Logo
183 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
