Question about Sharp LC32D44EBK 32 in. LCD TV
Tv is automatically switching to stanby mode after a few seconds
Tv is powering on and then switching automatically to stanby mode
    President:
  • 1,099 Answers
Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope this helpout......
Posted on Aug 03, 2010
Testimonial: "your a star thank you"
SOURCE:
Hi i have sharp lc-32a37m lcd tv it switch on but only stays on for a few seconds then it goes on stanby could it be the power supply
Chances are good its the power board..you can test the voltages after it goes into shut down to see if some are missing or not correct, if they are replace it
Dec 11, 2017 | Sharp Televison & Video
When tv goes on stanby it starts scanning
The firmware corrupted. Contact the authorized service centre.
Apr 09, 2014 | Televison & Video
SONY LCD SWITCHES OFF BY ITSELF
From my experience with sony tv it's normal.The set is going through update mode.Leave the set for about 10 minutes and it should be back to normal.
Jan 06, 2014 | Sony BRAVIA KDL-40S2010 40 in. LCD...
When i on my tv after a few seconds it shut downs automatically and on after a few second makes a loud noise help.............
Hello, it sounds like a problem with the switch mode power supply. Theres a good rule to go by, any noise,switch it off and leave it that way. You need to get a technician to look at it.
Mar 23, 2011 | Televison & Video
I have a 19'' baird tv that is staying on standby.
your h.o.t. horiz. output transistor is more than likely shorted and this is how a switching power supply protects itself it does a self test and if parameters and current/voltage aren't correct this is what happens
Sep 12, 2009 | Televison & Video
Turn off tv power
First your tv will always go into "Standby" when it receives a "Power off" signal. Made that way. Second, It is never a good thing to have your tv power plugged into a "Switched" outlet on a Cable ot Sat box or some other Component. The tv should be always be plugged into the wall outlet or through a very good surge protector.
Jul 12, 2009 | Televison & Video
Can't turn on from Stanby mode
I would assume the power board has a problem. A tech could possibly repair it without replacing the whole board.
Nov 13, 2008 | Pioneer PDP-5070HD 50 in. Plasma...
Stanby mode
1st... try a different controller, or operate from the tv panel.
Oct 29, 2008 | Televison & Video
VCR automatically goes into standby mode
If this unit shuts down after you turn it on, it is going into stanby because the microprocessor is not seeing the proper pulses from the mode switch. this could be due to an out of time mechanism because of a broken gear, bad mode switch, the loading basket is out of time or broken, or the capstain motor or the cylinlinder motor is not sending the PG and FG pulses to the microprocessor. These can also be due to a power supply voltage missing. You can check the voltages with a service manual and make sure they are not low. You will also need to get the mechanism manual and check the timing of the mechanism. Then check the mode switch you can get a manual from here http://www.servicemanuals.net/results.aspx?brand=15&model=HRS&type=SM&pos=281 Good Luck
Mar 21, 2007 | JVC HR-S9900 S-VHS VCR
Sharp LC32D44EBK 32 in. LCD TV Logo
961 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
