Question about Whirlpool Washing Machines
Whirlpool AWO D/4505 - How do I split / remove drum to change drum bearings ?
  • tony_cole199 Aug 03, 2010
    Whirlpool AWO D/4505 washing machine. I need to find out how to split the outer drum to be able to remove the inner drum to change the bearings. The outer drum is constructed from two plastic mouldings, pushed together. There doesnot appear to be any fixings ie screws / bolts holding the two parts together. I have tried levering apart, but no movement. Is there a technique for splitting the outerdrum on this model of washing machine?
  • Whirlpool Master
  • 12,061 Answers
    The outer drum on the washing machine in question is made from plastic, and the two parts appear to be pressed together. Current use uf wide bladd screwdrivers to lever apart is having no affect, apart from damaging the drum where the to parts **** together. How do I split them to get to the inner drum.
Where do I clean the pump filter? Light keeps lighting to clean pump. Whirlpool front loader. A+A 5kg / 1200 AWO/D 4505
You have a code telling you to clean the pump now thats a first are you sure it says clean the pump filter? more info as to why you are needing to clean the pump filter its not really easy trust me, unless you have done it before which i am guessing you havent.
Mar 07, 2016 | Whirlpool Washing Machines
AWO/D5556 NEEDS NEW BEARINGS DO I NEED SPECIAL TOOLS TO CHANGE THEM
no just a big hammer and some steel bars try to knock em out evenly take the oil seal off from inside the drum first then knock out the outer bearing from the inside out and last the inner bearing from the outside try not to miss with the hammer it hurts thankyou
Jan 23, 2011 | Whirlpool Washing Machines
My whirlpool awo/d5716 keeps ripping clothes. it looks like they are going down between the drum and door seal. its ripping mostly sleeves and i keeps losing socks which end up in the filter. if i put one...
It may be that the drum bearing has failed, allowing the clothes to get where they shouldn't be. Stop using it. Get a technician in, because it could fail and do irreparable damage
Jan 06, 2018 | Whirlpool Washing Machines
I need to clen the pump on a whirlpool washing machine awo/d 4505
hello mam you cant clean the pump but you can clean the filter of the drain line. and if you want to clean it you should use a descaling powder this will be available with the washing machine service centers.
Sep 22, 2009 | Washing Machines
Whirlpool AWO/D 4505 Washing Machine
Unplug your machine and unclip the plastic trim panel across the bottom of the machine (front) to reveal the circular pump filter cover. Unscrew this cover with your fingers and remove any debris inside. Put the cover back on, clip the panel back on and try your machine again. Should be fine.
Aug 06, 2008 | Washing Machines
Washing Machines Logo
953 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
