Question about Fisher and Paykel Washing Machines
When using the smart drive 051 the machine attempts to start filling (on a cold wash) then the water flow switches off after a few seconds and timing is inconsistent of the attempts to fill. After 3 attempts to fill a warning light comes on and the machine beeps and stops. Hot water fills fine. Please advise!!!
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now when the machine beeps a series of lights will light up.They will be in a row of 8 lights.Starting from the left to right which ones are lit.Is it the 2nd and 4th or the 1st and 6th ---etc---?Please reply with additional information and I can help you rectify this fault.
Posted on Aug 04, 2010
  • S Rademaker Nov 07, 2012
    Hi, I have the same problem. It's the 6th light from the right that flashes and no other lights flash. I'd love some advice please! Thank you
Machine wont fill with hot water
problem in hot water tap
hot water solenoid not activating to let water in
to prove either switch the hoses on the taps and press cold water wash
that proves the tap
then press hot wash and that proves the solenoid
Jul 21, 2016 | Fisher and Paykel Washing Machines
Hello. Recently my fisher &PAkel smart drive 703 was removed from its connections as we renovated our laundry. When it was reconnected by our tiler, it stopped working properly. This is what hap
Need to know the error code to help you. When it beeps, take note of the top row of lights & count from right to left. Tell me exactly which lights are on & which are off. Also, tell me if any other lights are blinking. The only thing the tiler would of disconnected are the inlet water hoses. Check that the hose from the cold tap is on the cold inlet & hot tap is on the hot inlet. Marked C & H on back of panel.
Mar 06, 2017 | Fisher and Paykel Washing Machines
Smart drive 051 error code 32
Have you tried unplugging it and plugging it in again?
Nov 22, 2013 | Fisher and Paykel Washing Machines
Fysher and Paykel smart drive 051. takes ages to start. cold water flow seems ok. takes 2-3 times longer for full cycle. sometimes stops and hot water light flashes. yours, jagrat.
Hi just read your posting.Now what water temp have you selected for wash?Is it cold, warm, or hot?Sounds like a water flow problem to me.The water valves on your model of machine sometimes sound like they are filling correctly but they only let a little bit of water in.How long does it take to fill your machine and start agitating when you have selected low water level?Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Aug 18, 2010 | Fisher and Paykel Washing Machines
Slow cold water flow won't go back to full flow
I think the water inlet valve is nearly stopped up with sediment in the screen filter where the supply hose screws to the valve.Cut the water off at the hose and disconnect and look for the screen. The hot water usually doensn't do this because the water has time to settle everything out while it's in the hot water heater.
Aug 15, 2009 | Washing Machines
Fisher&Paykel Smart Drive 051 keeps beeping/not draining
Hi, I have the same problem and for my wahsing machine it is block pump, so I turn the machine on and advance it to spin and turn the pump fan to help clear the block, the pump locate at the buttom of the basket of the machine...
Mar 31, 2009 | Fisher Washing Machines
Whirlpool top loader
You either have a defective pressure switch or water inlet valve. Start to fill the machine with warm water so that both solenoids on the water inlet valve (hot and cold) are activated. After about 30-60 seconds, push the timer knob in to stop water flow. If the water continues to flow, replace the water inlet valve. If this is the case, it may take a few times of starting and stopping water flow to allow solenoid to heat up and become symptomatic. If water flow stops abruptly each time knob is pushed in, you most likely have a defective pressure switch (water level switch).
May 09, 2008 | Whirlpool LXR9445JT Top Load Washer
Fisher and Paykel 6.5 smart drive washer
My F & Paykel washer did this. There was a baby sock under the wash basin. I called for repairman and he found the problem.
Jan 05, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
379 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
