Question about Dell 5100MP Multimedia Projector
How can i clean the filter of my dell 5100 projector could somebody tell me please
  • 89 Answers
Take out the filter cover and remove filter. Use a small vacuum cleaner to clean the dust from the filter. Put it back and reset the filter timer
Posted on Aug 10, 2010
All the lights on my projector are blinking except for the power and lamp.
I would try cleaning the filter(s). It may be overheating. I used my air compressor to clean them out. The filters can get very dirty and the unit overheats.
Good luck,
Paul
Dec 04, 2015 | Dell 1510X Projector Projector
This is probably the lamp. If you replaced the lamp then you need to reset the lamp counter in the menu settings. You should clean the filter out as well.
Feb 24, 2015 | Dell 1409X DLP Projector
Turn off on screen message
follow this steps and fix it. God bless you
  • Secure the lamp cover and the air filter cover of the projector body if the projector does not power on. Ensure that the power cable is firmly connected to the projector and an active power plug. If the projector was turned off and then on quickly--let it sit for 90 seconds before trying to turn it on.
  • 2
    Replace the projection lamp if the projector will not power on or if the lamp indicator is flashing. Turn off the projector and let it sit for at least 30 minutes. Locate the lamp cover and remove or loosen the lamp cover with a screwdriver. Carefully remove the projection lamp from the projector housing using the handle, if available.
  • 3
    Place the new projection lamp into the projector housing and secure it to the projector. Replace the lamp cover and reset the lamp timer. Power on the projector to ensure the new lamp is working correctly.
  • 4
    Remove the projector from the enclosed area to allow air circulation if it constantly overheats. Place the projector into an open area and make sure there is no blockage for the ventilation holes. Unplug the projector for at least 45 minutes to allow it to soft reset.
  • 5
    Clean the air filter to allow the projector better air circulation. Turn off the projector and unplug it from the outlet. Remove the air filter cover and use a vacuum to remove dust from the area. If the filter is unable to be cleaned correctly or is damaged, then replace it. Pull the air filter from the projector and place the new one in the now empty slot. Close and secure the air filter cover.
Oct 28, 2013 | Dell 4310WX Projector
Hitachi CP-X400 tells to me to clean filter. How do I do this?
you go to the menu where there is an option to reset the filter.  once you hit enter it will show 0h, meaning 0 hours until the next filter cleaning needs to occur.
Jun 15, 2009 | Hitachi CP-X400 LCD Projector
Need asistent
my sony vpl ex3 will not light up, has a lamp/cover light on all the time can somebody help
Jun 21, 2008 | Sony VPL-EX1 Multimedia Projector
NEC Model VT48 - need to clean filter
This is a solution for the VT 480 by NEC for filter clean. on the left side there are two slots that have dust filters which can slide vertically to reveal micro screens that one can blow, tap vigorously, or vacuum to remove any dust build up. I hope this helps you with your unit.
Tech-no
Nov 11, 2007 | NEC MultiSync VT48 Multimedia Projector
Overheating
Please clean the filters for the air and the air circulation path for cooling the lamp.
This will definitely work, pls also check that the condition of lamp is okay or not as sometimes lamp goes with the ballast unit of the lamp and that damages the new lamp.
Viren
Nov 06, 2007 | Dell 1100MP Multimedia Projector
Projector Reset
Hi Here is the info for you :: Caring For The Air Filter The air filter should be cleaned about every 100 hours. If the indicators or a message prompts you to clean the air filter, clean the air filter as soon as possible. If the soiling will not come off the air filter, or it becomes damaged, then it needs to be replaced. Please replace the air filter as soon as possible. memoWhen you replace the lamp, please replace also the air filter. Turn off the projector, and unplug the power cord. Allow the lamp bulb to cool for at least 45 minutes. Apply a vacuum cleaner to the top of the filter cover and the air filter to clean. If the soiling will not come off the air filter, or it becomes damaged, it needs to be replaced. If the air filter needs to be replaced, contact your dealer to prepare a new air filter. Tell the dealer your air filter type. Turn on the projector power, and reset the filter timer. (1) While the projector running, press the MENU button to open the menu. (2) Choose the ?OPTION? on the menu using the / button, then press the button or ENTER button. (3) Choose the ?FILTER TIME? using the / button, then press and hold theRESET button for 3 seconds. (4) Choose the ?RESET? using the button. memo Incorrectly resetting of the filter timer (resetting without replacement, or neglect of resetting after replacement) will result in incorrect message functions. Here is the link to the users manual :: http://www.aboutprojectors.com/Hitachi-CP-X1250-projector.html Further Questions ?? Email Me hartmansp@inbox.com Have a great evening.
May 03, 2007 | Hitachi CP-X1250 Multimedia Projector
Dell 5100MP Multimedia Projector Logo
536 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
