Question about Canon Cameras
How do I recharge the battery. Do I just conect to a computer or a USB connection to mains power as with my ipod???
  • kakima Aug 03, 2010
    That depends. Some Canon cameras do incorporate charging circuitry, allowing you to charge via the USB connection. Other Canon cameras do not, relying on either disposable batteries or a separate battery charger.
    Would you care to specify the model in question?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
With no response in over a month, I assume this is no longer a problem.
Posted on Sep 17, 2010
How to recharge the Apple iPod Shuffle Silver MP3 Player
According to the manual found here: http://manuals.info.apple.com/en/ipodshuffleuserguide.pdf
"Remove the USB cap and connect iPod shuffle to a high-power USB port on your
computer. The battery status light on the back of iPod shuffle turns on.
The iPod shuffle battery is 80-percent charged in about two hours, and fully charged in
about four hours.
When the battery is charging, the iPod shuffle status light is amber. When the battery is
fully charged, the light is green until you disconnect iPod shuffle. If you don't see the
status light, try another USB port on your computer"
Batteries also wear out from time to time, so if you find that it's not charging no matter what you do, it's likely that you need a new battery. Here's a link to more info on iPod batteries: http://www.apple.com/batteries/ipods.html
May 10, 2011 | Apple iPod shuffle MP3 Player
Tip
The battery of my iPod is not charging
<p>When you buy an iPod, the device comes with cables that connect the charging device to the computer. When the iPod battery is low, you can recharge by plugging into your desktop or laptop. But sometimes, when you connect your iPod to your computer, the battery charger. According to Apple's site, some problems may prevent your iPod from charging properly. <br /> <p><br /> <p>1. Connect your iPod USB charging cable only one USB port on the computer itself. External port devices, such as a USB hub, do not provide enough power to recharge your iPod. <br /> <p><br /> <p>2. Connect the iPod firewire charging only one firewire port on your computer. Like USB, Firewire ports are not enough of a load to the battery of your iPod. <br /> <p><br /> <p>3. Disconnect the computer from sleep when the computer set to sleep after a certain time. An iPod can only load on a computer that is connected and not in sleep mode. To enable sleep mode on most computers, you can move the mouse or press the power button once. Hold the power button, which usually turns off the computer. <br /> <p><br /> <p>4. Turn the iPod off and on when the unit is frozen. A frozen iPod is not charging. If the unit is still frozen when you turn it on again, restart the iPod by pressing the "Hold" switch to "On" and then back to "Off" and press and hold a "Menu" and "Select" buttons simultaneously or " Start "and" Menu "button. Hold the buttons until the Apple logo appears on the screen. <br /> <p><br /> <p>5. Set the system up-to-iPod charger so that when using a Windows 2000 computer. In preparation for the system to load the iPod device to the unit with the charging cable, launch iTunes and "iPod" in the left pane to "Settings" tab to go, check the box next to "Enable Disk use", and click the "Apply" button. Once the configuration is in place, the iPod will charge as normal. <br />
on Aug 09, 2011 | Apple iPod touch
Tip
How do I charge my iPod touch for the First Time
<p>Apple iPod touch is a personal audio player with the ability to store and play MP3 files, digital video and downloadable games and applications. The unit is powered by a rechargeable battery. When charging the battery for the first time, ensure that the battery is fully charged. From there you can turn it on or removing the device from the charger, if desired, regardless of battery level. <br /> <p><br /> <p>1. Enter the main connection for the iPod cable to the socket at the bottom of the iPod touch. <br /> <p><br /> <p>2. Insert the small plug into a USB port on your computer. Turn on the computer. Alternatively, an iPod charger, sold separately, you can recharge your iPod touch with a socket. Connect the wall charger into an AC outlet. Insert the plug on the door of the small wall charger. The battery icon located in the upper right corner of the screen, the battery is charging. <br /> <p><br /> <p>3. Let the battery fully charged. When the battery icon to indicate the device is fully charged, remove the iPod from the cable. <br />
Ipod won't power on.
Hello
Plug the iPod USB cable into the iPod and then connect it to the power adapter to recharge the iPod's battery. The iPod Shuffle may not be turning on because its battery has fully drained.
Move the button on the back of the iPod to the "off" position.
Wait five seconds with the iPod in "off" mode before switching the device back on. This process will reset the iPod memory.
Connect the iPod Shuffle to your PC computer if it still will not turn on.
Open the iTunes program and sync your iPod with your computer. When you unplug your iPod from your computer, it should turn on normally again.
Oct 23, 2010 | Apple Audio Players & Recorders
My ipod won't charge. keeps saying "please wait. very low battery" what's wrong with it?
I had the same problem. Went to the Apple store and the technician said that the IPOD battery ran down to low (battery level showed red) and the USB port on the computer was not strong enough to recharge it. He used a rechargeable adapter that pluged directly into the wall (adapter cost about $30) and recharged it enough for me to take it home and recharge it on my computer.He said to never let the battery level drop below 5% unless you are going to recharge it using the adapter that pluged into the wall. I bought an IPOD rechargeable travel kit from Target for $20 and used it to recharge my IPOD. My IPOD works fine now. The Technician also said at some point the battery will need to be replaced (in a year or two depends). Will cost about $59 to replace it (don't quote me on the timeframe or price of replacement, this may have been just for my IPOD but thought this would be useful info for someone.
Nov 24, 2009 | Apple iPod MA446LL/A MP3 Player
Tip
The iPod USB Charger
<p>The USB cable that came with all iPod has two purposes: to your device to your computer so you can update and add music, and iPod to charge. All iPods have a lithium ion battery stops charging when the battery is full, the total life of your battery is not affected if you leave the iPod is connected to a power source. It usually takes four hours to recharge most iPods. <br /> <p><br /> <p>1. Connect the USB connector into an available high-power USB 2.0 port on your computer. Low-power USB ports, such as those in external keyboards and hubs do not work. <br /> <p><br /> <p>2. Connect the 30-pin connector at the other end of the USB cable 30-pin connector on your iPod. If you charge an iPod shuffle, there is no dock connector port. Instead, use the connector on the other end of USB cable that fits in the headset. Set the iPod down and let it recharge. <br /> <p><br /> <p>3. Unplug the USB cable when the iPod battery indicator is full. If you charge an iPod shuffle, the green light will appear. <br />
I plugged in my i pod and came back a hour later and the screen was black and was frozen and none of the buttons would work
you will need to reset your ipod this will not delete songs. 1 Toggle the Hold switch on and off (slide it to HOLD and then back again).
2 Press and hold Menu and the Center button for at least 6 seconds, until the
Apple logo appears.
If iPod nano won’t turn on or respond
â Make sure the Hold switch isn’t set to HOLD.
â The iPod nano battery might need to be recharged. Connect iPod nano to your
computer or to an Apple USB Power Adapter and let the battery recharge. Look for
the lightning bolt icon on the iPod nano screen to verify that iPod nano is receiving
a charge.
To charge the battery, connect iPod nano to a USB 2.0 port on your computer.
Oct 21, 2009 | Apple iPod nano MP3 Player
Soon as USB is connected to computer - It freezes up and will not repond until the ipod is reset, using menu and center button. Freezes up also, when IPOD Power Adapter is connected for charging battery....
check your usb drivers are upto date
using the latest usb driver. its your pc that is at fault
not the ipod try connecting to another pc.
Ray
Oct 01, 2009 | Apple iPod touch
Ipod won't work unless plugged in to computer or mains
alison65,
good day, the only possible cause why your player can only power up using it's own charger or through pc connection is:
1) The connection of the rechargeable battery inside the player is loose or out of contact
2) The rechargeable battery itself is faulty
3) The connection from the charging line is loose or out of contact
most likely your problem is within the internal of the unit.
cheers,
mark
Jan 29, 2009 | Apple iPod nano
Cameras Logo
23 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
